Leaving SawStop "on" when not in use?
Forum topic by JeffP posted 05-28-2015 12:22 AM 904 views 0 times favorited 5 replies Add to Favorites Watch
View JeffP's profile
JeffP
573 posts in 1391 days
05-28-2015 12:22 AM
Topic tags/keywords: tablesaw
Ok, for the un-initiated, a saw stop saw has more “modes” than an ordinary “binary” saw.
A SawStop saw can be off, on, and running (and a few more error and temporary status modes I won’t go into here).
The “on” state involves a separate switch that activates the saw’s start-up tests and gets it ready to “run”.
A few times I accidentally turned the saw to “on”, then hit the big switch to make it “run” and used it, and hit the big red switch to make it stop “running”, but left it on. Then I came back the next day and noticed it was still “on”.
After that happened about 3 times, I stopped bothering to turn it all the way “off” when not in use.
My shop is locked up tight when I’m not there and there are no children around here to get into trouble. Since there is no significant safety issue with leaving it in that “almost on” mode…why not just leave it that way?
So I ask the forum here…why bother?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
5 replies so far
View TheFridge's profile
TheFridge
9477 posts in 1486 days
#1 posted 05-28-2015 01:07 AM
Fine by me
View GT350's profile
GT350
368 posts in 1981 days
#2 posted 05-28-2015 01:20 AM
I just think it is best to turn it off when I am done for the day. While I am in the shop I leave it on so it doesn’t have to go through the startup checks that take about 15 seconds or so.
I was also concerned about forgetting and leaving it on so I called the Sawstop support line and they said it would not harm the machine to leave it on.
Mike
View helluvawreck's profile
helluvawreck
31096 posts in 2866 days
#3 posted 05-28-2015 01:29 AM
I have a saw stop and my shop also stays locked up unless I’m in there. I have the only key to get in. I haven’t looked at the circuit blue print on the sawstop so I’m not sure how it works. However, on some circuits that are left on can have a relay on when it is on. It’s not good for the relay to be on in these cases for long periods of time for no reason. However, this is probably not the case with a sawstop. It probably has a different type of system. I still cut mine off when I’m not going to use it in the next few hours. It may not make any difference. I just don’t know. More than likely the answer to the question is in the manual or on their website.
helluvawreck aka Charles
View bonesbr549's profile
bonesbr549
1549 posts in 3067 days
#4 posted 05-28-2015 01:56 AM
Won’t hurt anything. I leave mine on from time to time
View DKV's profile
DKV
3940 posts in 2504 days
#5 posted 05-28-2015 04:09 AM
Leave it on. If a kid gets in, raises the blade, turns on the saw, selects a board to cut, pushes the board through the blade and then runs his/her hand into the blade the saw will stop. No harm, no foul…although from what I understand there is a cost for replacement parts. If this scenario is your biggest fear then turn the switch off. Simple dimple…
-- This is a Troll Free zone.
