Cabinet bottom
Forum topic by Mark posted 05-27-2015 04:29 PM 766 views 0 times favorited 6 replies Add to Favorites Watch
View Mark's profile
Mark
871 posts in 1848 days
05-27-2015 04:29 PM
Morning all. I’m kinda concerned about how to attach the bottom of the hutch portion of the Hutch and Buffet project I’m working on. The bottom will be solid 3/4 Cherry. 4 pcs 3”wide glued up as like a table top. This will rest inside a frame. My concern is . How do I compensate for wood movement with out having unsightly gaps on the front and back. Any thoughts would be great. Thanks.
Mark
-- Mark
View Kazooman's profile
Kazooman
914 posts in 1826 days
#1 posted 05-27-2015 04:35 PM
Recess the panel in a rabbit that is deep enough to allow for the wood movement.
View waho6o9's profile (online now)
waho6o9
8070 posts in 2450 days
#2 posted 05-27-2015 04:44 PM
Make it a floating panel as suggested by Kazooman.
View AandCstyle's profile
AandCstyle
2950 posts in 2130 days
#3 posted 05-27-2015 04:46 PM
Mark, just to add to Kazooman’s response, you can estimate the required depth of the rabbet groove using the Shrinkulator. If you need more depth than a back rabbet, you can also make the front one extra deep. If you use only a back rabbet only apply glue to the front of the panel. If you use front and back rabbets, then only apply glue to the middle 2” of each end. I would finish the panel before assembling the carcass.
-- Art
waho6o9
#4 posted 05-27-2015 04:53 PM
http://www.leevalley.com/US/hardware/page.aspx?cat=3,44296&p=58675
I know it’s not a door but someone may benefit from the Panel Barrels.
“These spacers keep floating panels centered.
Made from non-staining natural rubber, they have excellent elasticity, allowing them to compress or relax as the wood moves, keeping panels rattle-free.”
View jdh122's profile
jdh122
969 posts in 2691 days
#5 posted 05-27-2015 05:32 PM
Won’t you have the same issue with the top? How is it attached to the case?
-- Jeremy, in the Acadian forests
View Mark's profile
Mark
#6 posted 05-27-2015 07:52 PM
Thanks for the fast and excellent suggestions gents.
Jeremy. Yes I have/ had the same issue with the top.
I like the wabbit idea.
Art. Thanks again for the Shrinkulator.
-- Mark
