| Forum topic by dbhost | posted 85 days ago | 368 views | 0 times favorited | 7 replies | ![]() |
85 days ago |
It seems like the first thing after setting up and aligning all the things that need aligned on the Ryobi BT3×00 series saws, one of the first things new owners do is “paint the red line”, meaning they literally take, usually model paint, or a paint pen, or even a sharpie, and make a thin red line exactly in line with the blade in the piece of table between the front rail, and the blade… I have never seen this done on any other table saw. Just the Ryobi BT3×00 (and its Craftsman cousins). Why is that? This seems like such a no brainer. If you can see the red line, you know if you are crossing it with anything that you might not want sawn through like your thumb… This seems to me a HUGE safety feature that others might want. Do owners of other saws do this? I mean other saws other than Ryobi? (I have seen a few BTS-21 owners do this as well…) BTW, if you are unfamiliar with the top of the BT3×00, it is not smooth / flat, but rather ribbed with the tops of the ribs milled flat, the paint line is in the valley between two of the ribs. -- Trying to follow the example of the master. |
