Video Quick Tip
Blog entry by Todd A. Clippinger posted 02-13-2013 07:32 PM 3424 reads 2 times favorited 22 comments Add to Favorites Watch
I ran into a situation where my clamping needs exceeded my clamp capacities. I did a quick video to share my solution because it might help someone else in their shop.
This video is “quick & dirty” because I wanted to try recording it on my iPhone. I don’t see myself doing that again, but the information is still good and clear.
I hope you find it helpful.
Your friend in the shop,
Todd A. Clippinger Share the Love ~ Share the Knowledge
22 comments so far
View grizzman's profile
grizzman
7836 posts in 3327 days
#1 posted 02-13-2013 07:43 PM
great tip todd..good to see ya…grizz
-- GRIZZMAN ...[''''']
Todd A. Clippinger
8901 posts in 4123 days
#2 posted 02-13-2013 07:50 PM
Hey Griz – Thanks! Ran into this little situation this morning and I just had to share;) Made me feel good to get out a little video again.
View unisaw2's profile
unisaw2
209 posts in 3059 days
#3 posted 02-13-2013 08:14 PM
Hi Todd,
Love your videos. Good tip, just don’t let the glue get loose and glue the frame to your bench!
-- JJ - Northern Illinois
Todd A. Clippinger
#4 posted 02-13-2013 08:36 PM
Thanks JJ – I just looked at your projects, you do great work.
You do make a valid point. I have to unclamp & move the project before it bonds to the bench but at a point when the wood has joined good enough.
I have laminate on the work table so bonding is not too much of an issue and it is also easy to clean off.
View stefang's profile
stefang
15881 posts in 3358 days
#5 posted 02-13-2013 08:41 PM
Excellent tip Todd.
Todd A. Clippinger
#6 posted 02-13-2013 08:45 PM
Thanks Mike – It is but one solution. But that is the thing with a quick tip video, you have to stick to a simple point and not expand too much on it. Or then it is not a quick tip!
View jaykaypur's profile
jaykaypur
4017 posts in 2432 days
#7 posted 02-13-2013 08:49 PM
Good idea and an easy fix by just improvising to get the job done!
-- Use it up, Wear it out --------------- Make it do, Or do without!
23997 posts in 3875 days
#8 posted 02-13-2013 10:03 PM
Great tip Todd
Beginningwoodworker
13345 posts in 3696 days
#9 posted 02-14-2013 12:14 AM
Great tip, Todd.
View Dusty56's profile
Dusty56
11819 posts in 3711 days
#10 posted 02-14-2013 01:01 AM
Thanks for sharing that tip with us , Todd : )
View jcwalleye's profile
jcwalleye
306 posts in 3096 days
#11 posted 02-14-2013 05:22 AM
My Todd, your videos are really top notch. If they are easier with the iphone use it. I can’t tell the difference. Thanks for sharing your knowledge.
-- Trees, a wonderful gift --Joe--
Todd A. Clippinger
#12 posted 02-14-2013 05:30 AM
Thanks for the kind words of support everyone.
Joe – If you noticed like 3 “glitches” in the video, I think that was a result of taking 24fps footage and converting it to 30fps in the editing process. I was not happy with that at all. I cannot figure out how to remove them in the editing process. And if they are just too time consuming then that will also deter me.
I definitely get a better picture and audio off my Canon HD video cameras. My best audio comes from using the wireless mic.
I am still in exploratory mode to see what works best, fastest, and easiest. Like my woodworking, I am striving to produce a good product. Part of that goal will even be achieved by doing it more regularly to hone my skills, also just like in woodworking. It is all about doing it;)
View ItalRowe's profile
ItalRowe
5 posts in 1951 days
#13 posted 02-14-2013 03:38 PM
Good tip! Although you may have a good reason for doing so, most people butt their rails into their stiles, not stiles into their rails…….thus eliminating the need for long clamps
Todd A. Clippinger
#14 posted 02-14-2013 03:42 PM
ItalRowe – good point, but this project called for the stile into the rail. Maintaining brevity for a quick tip video did not allow me to go into more detail. I just hoped that sharing my situation might help others find solutions in their own shop.
View Richforever's profile
Richforever
757 posts in 3744 days
#15 posted 02-14-2013 06:57 PM
Todd, thanks for sharing. I’m sure it is one of those things that will pop into the brain cells when needed.
-- Rich, Seattle, WA
showing 1 through 15 of 22 comments
