Wood Movement #1: The Power Of Wood
Blog entry by Todd A. Clippinger posted 706 days ago 303 reads 0 times favorited 15 comments Add to Favorites Watch
no previous part Part 1 of Wood Movement series no next part
It Can’t Be Denied-
The power of wood movement can’t be denied. It is so powerful, ancient peoples used this characteristic to quarry stones with which they built their cities.
Usually we think of wood expansion tangentially which makes a board wider. Sometimes wood will just twist.
We ran into an instance recently where a beam twisted so bad that it broke the metal bracket that is holding it in place.
Twisted Beam
Perhaps the beam would have just expanded along it’s width but it has the weight of a full sunroom structure on it. So possibly it diverted its’ energy and twisted to relieve the need for expansion. I have dealt with enough framing lumber and beams to know how bad they can twist, often dramatically enough to render them useless.
Here is an image showing the metal bracket and how it is supposed to look.
Metal Beam Bracket
And here you can see that it is broken cleanly on the welds.
Broken Metal Beam Bracket
The brackets are only 4 years old and under shelter of the room that it supports. I suppose that some may question the welds but it is clear how much the beam has twisted and the wood has won out over the metal.
This isn’t a woodworking example in the same context of most LJ projects, but it does demonstrate the power of wood movement.
Peace, Love, and Woodworking
15 comments so far
View rpmurphy509's profile
rpmurphy509
290 posts in 753 days
posted 706 days ago
Pretty amazing how wood can twist, warp, bend or otherwise do what we don’t expect it to.
Aside from the ‘expansion’ we plan into our projects that is.
-- Still learning everything
25811 posts in 1299 days
posted 706 days ago
Who says you on’t have to take movement into consideration in what you make.
In some cases we believe that a tight corset will hold everything in. That may not be the case. We may have an explosion.
View JasonH's profile
JasonH
137 posts in 727 days
posted 706 days ago
Wow, impressive!
So, what did you do to remediate the problem?
-- Living on the square...
Todd A. Clippinger
5655 posts in 998 days
posted 706 days ago
We just welded it to follow the angle and bolted it back on. It is required to have the bracket but as you can see the beam would probably not go anywhere except under seismic circumstances. I don’t cut corners though and I would put the bracket on even if not required.
View scott shangraw's profile
scott shangraw
408 posts in 968 days
posted 706 days ago
It’s amazing how much wood can always move,It’s something you always have to keep in mind when doing furniture.I’ve seen some great pieces basically blown apart because the maker did not adress wood movement.Thanks for the reminder and example.
-- Scott NM,http://www.shangrilawoodworks.com
View David's profile
David
1982 posts in 1038 days
posted 706 days ago
Todd -
The strength of wood is truly amazing. Gives you a healthy respect for movement in timber no matter what the size of the project. Great craftsmanship!
Douglas Bordner
3427 posts in 963 days
posted 706 days ago
Thanks, Todd. Nothing beats a picture to say a thousand words, and put some drama behind the example.
and Karson – the other day you spoke to a potential turner and branch-wood user about “reaction wood”. I had never heard that term, but it certainly make sense and might keep someone out of hot water if thinking about planking out a big branch.
View roman's profile
roman
1125 posts in 792 days
posted 706 days ago
no offence but the bracket looks “home made”
Hopefully “Disney” didnt buy the same ones?
Thanks for the heads up!!
View rikkor's profile
rikkor
11335 posts in 773 days
posted 706 days ago
That is a stunning example of the power of the wood movement.
View mrtrim's profile
mrtrim
1698 posts in 779 days
posted 706 days ago
great post thanks for sharing it . happy holidays to you and yours
View patrick m's profile
patrick m
179 posts in 712 days
posted 705 days ago
Awesome!!!!! WOod kIcKs A*s … For instance did you know that trees made out of wood, work as polarity magnetic gravitational devices, that help our universe stay intact. It’s true! I find metal and welding not unlike working with wood in some cases. It’s good to know how to weld and work with metals, when trying to solve problems with wood. OK , I JUST WOKE UP. ONLY ON FIEST COFFEE…. maybe the polarity theory has some flaws .
patrick.
-- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ""BY HAMMER AND HAND ALL ARTS DO STAND""1785-1974 nyc Semper Fi, Patrick M
Dick, & Barb Cain
7046 posts in 1198 days
posted 705 days ago
That is some real power!
I don’t mean to be critical, but a properly welded joint would not have done that.
It looks like it was only tacked at the corners.
Todd A. Clippinger
posted 705 days ago
It had a bead the full length. We could have used Simpson brackets. They are hurricane/seismic anchors. They hold things together but they are thin. We wanted a bracket that looked structural and by all means should have been. The Simpson Strong Tie would have bent, but on our bracket the welds broke. We had it welded at a local metal fabrication shop.
View Blake's profile
Blake
2764 posts in 773 days
posted 704 days ago
Wow. I am humbled every time when I think I have “tamed” it. Its also amazing what trees will do when they grow… roots which push up roads, buildings, etc.
14932 posts in 750 days
posted 701 days ago
Thats the power of Mother nature for you Todd.
