Which wood should i use for a workbench top, i have to choose between:
-pine
-birch
-ash
-oak
Blog entry by thenorwayteenagewoodworker | posted 11-22-2009 09:54 PM | 1039 reads | 1 time favorited | 6 comments | ![]() |
Which wood should i use for a workbench top, i have to choose between: | |||||||
Latest Projects | Latest Blog Entries | Latest Forum Topics ![]()
6 comments so far
MedicKen
home | projects | blog
1612 posts in 3428 days
#1 posted 11-22-2009 10:19 PM
I guess there are a couple of questions that need to be answered first. How much are you willing to spend for the lumber? How long do you want the bench to last? I would shy away from the softer woods, the pine and birch. So, that leaves the oak and ash. I think either of the 2 would make a nice stable hard surface for a top. I would think it would be personal preference and availability of the wood
Webb
46 posts in 3252 days
#2 posted 11-22-2009 10:23 PM
The common wisdom is hard and heavy – oak or birch. However, mine is cheap ‘ol 2×4 soft stuff and I will say that when you drop something on the bench, and the bench gets the dent instead of the workpiece it is rather handy.
Personally, I would avoid pine because of the propensity to ooze resin over time, esp for thick pieces, but that would depend on the wood you have and the type of bench design you are considering.
If you have not done so, I recommend Schwart’s book on Workbenches (http://www.amazon.com/Workbenches-Design-Construction-Popular-Woodworking/dp/1558708405/ref=pd_bxgy_b_img_c).
HokieMojo
2104 posts in 3694 days
#3 posted 11-22-2009 11:09 PM
actually, Chris highly recommends southern yellow pine
SwedishIron
142 posts in 3607 days
#4 posted 11-23-2009 12:10 AM
I used ash for my bench… overall it was the best value per bd/ft.. so being cheap and hard stuff it was an easy choice. Some people look at the biggest con of ash is this open grain characteristic but it hasn’t been in issue the past year.
-- Scott, Colorado
Kent Shepherd
2718 posts in 3252 days
#5 posted 11-23-2009 08:02 PM
My opinion:
Pine—Too soft
Oak—Not bad, but some red oak tends to splinter after banging on it for a while—white oak might be better though.
Birch—Good and hard. I personally hate working it, but will work similar to maple and should make a good top.
Ash—Good choice, as Scott said. The open grain is not the issue that most red oak is. Be carefull what ash you get, some of it is very soft. It definitely matters where it comes from. Check with your supplier. I use a lot of ash that would be suitable for a bench top.
-- http://shepherdtoolandsupply.com/
3 posts in 3277 days
#6 posted 11-25-2009 10:49 PM
hello
remember i live in norway and i live in a plase der its 1 singel hardwood delar, and they ust have this type of wood. i think i go wit ash and the resens way is they have it 2” thikness, and birch is ust in32mm(1”is 25,4mm)
