Done with the expensive white oak log
Blog entry by sw_iowa_sawyer posted 03-30-2010 12:49 AM 1331 reads 0 times favorited 5 comments Add to Favorites Watch
I was finally able to get back to the white log that has been on the saw for a while. It has been a while so I will back track a little. Here is the log it ran 32” and had to be trimmed to even start with a chain saw.
So the process is simple enough find your best side and slab then rotate and slab etc until you have a four sides cant. Well this logs runs about 3500 lbs so that presents a problem.
Three sides cut need to roll it.
Then once you have all fours sides square start cutting your best face for lumber.
This log and been down a while and was hard and dry I used a lot of water to help the blade but still used 3 blades. So it was time for a blade change
It was slow cutting but this made it worth it over 20” slabs
Here is a shot of the saw in action
Once I reached about 10” on the cant I turned it and started taking smaller boards off of that
Had to roll it first
The lumber was perfect
I stacked the boards off to the side to be edged later
Here is the straight line process
I also try not to waste any wood if I can help it so I put the first slab back on and cut a few more boards from it.
Finally the finished pile stacked and stickered. I have cut a fair amout of lumber but this size white log was tough on a manual mill, I think I like 24” ish logs better.
The high cost of the log had something to due with a new truck and a teenage son but that is another story.
5 comments so far
View OutPutter's profile
OutPutter
1199 posts in 3863 days
#1 posted 03-30-2010 08:03 AM
Makes me want to sell something and get my own mill so I can be there for the birth of the wood. Cool.
-- Jim
View Cher's profile
Cher
954 posts in 2966 days
#2 posted 03-30-2010 07:48 PM
That is just awesome!!! Thanks for the photos.
View JAGWAH's profile
JAGWAH
929 posts in 2957 days
#3 posted 03-30-2010 08:49 PM
I am absolutly jealous!
-- ~Just A Guy With A Hammer~
View bigike's profile
bigike
4053 posts in 3161 days
#4 posted 03-30-2010 10:38 PM
can u send me some please! LOL
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 2980 days
#5 posted 03-30-2010 11:06 PM
Some guys get to have all the fun. Where can I get that in a wheelchair size on concrete?
