Barnsley Reproduction Build #23: Assembling the Stretcher
Blog entry by stevo_wis posted 10-05-2015 02:54 AM 1512 reads 0 times favorited 4 comments Add to Favorites Watch
« Part 22: “A Horse, A Horse, my Kingdom for a Horse”. (Bodger's Ball Part 3) Part 23 of Barnsley Reproduction Build series Part 24: Assembling and Gluing the Undercarriage »
It has been a couple of months since I have posted but I have been slowly coming along with the Barnsley Table. The stretcher had a lot of carving and bevels, but they are finished. It had some interesting joinery issues as well.
The stretcher has almost the identical joinery that the upper frame has. I made one change here to simplify construction and that was to not have an acute point on the tenon. The pencil is pointing to the squared off tenon. Doing that made the mortise much faster to cut and also made adjustments easier. I am told that is what timber framers do.
Before carving, the diagonal joinery was given a dry run. It was easier to do that joinery while the pieces were still square.
The stopped rip cut was made on the table saw along with the end tenons. The bandsaw cut the curves.
A template was used to draw all the bevels.
Off to the shaving horse to cut all the bevels.
Next the stretcher was clamped, glued, and drawbored.
The legs were drilled, tenon ends were drilled offset 1/32 with a doweling jig. The offset will pull the joint tight.
Next is gluing the entire undercarriage.
-- Stevo
4 comments so far
View Kiwib0y's profile
Kiwib0y
89 posts in 1018 days
#1 posted 10-05-2015 07:18 AM
The tenon work looks amazing and the shaped legs are cool.
-- "It is only a silly question if it is not asked" Don,New Zealand
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#2 posted 10-05-2015 03:10 PM
You are more talented with a drawknife than I. This is coming along nicely, and it is a great project full of challenges.
View stefang's profile
stefang
15881 posts in 3329 days
#3 posted 10-08-2015 09:48 AM
Lots of great work and interesting joinery here Stevo. Looking forward to seeing it completed.
View BurlyBob's profile
BurlyBob
5491 posts in 2260 days
#4 posted 10-13-2015 05:11 AM
That is some awesome joinery!
