Barnsley Reproduction Build #11: Diagonal Tenons Almost There
Blog entry by stevo_wis posted 12-24-2014 03:57 AM 1847 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 10: Straight Tenons Finished Part 11 of Barnsley Reproduction Build series Part 12: Final Fitting and Draw Boring »
The diagnonal tenons can be shaped on the table saw almost identically to the way a 90 degree tenon would be made. I cut the inside cheek cut very carefully and then quickly nibble out to the tenon’s tip.
Because the shoulder will hide where the tenon actually enters the mortise, i can cut the tenons to width with the bandsaw. The tenons can slightly narrower than the mortises as they will match up to end grain which gives little glue strength, and they are covered in any case. after cutting, I trimmed the entire shoulder with a chisel to get a nice line that does show.
One joint at a time I tried each tenon into it’s mortise. They had a way to go, so it was time to break out the shoulder plane.
An old trick to fit dovetails (and dental work), is to color one surface with something that will rub off onto it’s mating piece when fit together. A pencil blackens the mortise here and the joint is pushed together as tightly as it will go.
Pulling the joint apart shows the black transferred to the high spots on the tenon. These tight areas are holding the joint apart and need to be shaved down.
A few light cuts with the shoulder plane readies the joint for another trial fitting. I repeated it until the joint seated all the way.
The joint is not perfect yet but very close which is good enough until the next step.
After each joint is fitted and compared to the plan it is time to assemble all the joints for a first fitting together with it’s neighboring pieces. The geometry of the assembly requires all of the joints be assembled at the same time with not a lot of clearance.
Some of the junctions actually fit worse than they did when the joints were fitted alone. A final tuning of all the joints will be the topic of the next blog entry.
-- Stevo
3 comments so far
View lightweightladylefty's profile
3241 posts in 3736 days
#1 posted 12-24-2014 05:57 AM
Stevo,
Nice work! All those angles and joints look pretty tricky. I’m having a hard time getting four mitered corners of a rectangular box to fit together!
L/W
-- Jesus is the ONLY reason for ANY season.
View Brodan's profile
Brodan
142 posts in 1326 days
#2 posted 12-24-2014 01:59 PM
Looks terrific Stevo. Pretty complicated assembly. I really appreciate your step by step detailed description of the mortise and teno layout and construction. I am using mortise and tenon joinery in my current build ( first time). I find your post very helpful. Thanks.
Dan
-- Dan, TN
View bunkymarie's profile
bunkymarie
4 posts in 1303 days
#3 posted 12-24-2014 04:09 PM
Beautiful work!
