MAKING A WOODEN GEARED CLOCK #6: Recut One Gear and Made a Sanding Jig
Blog entry by stefang posted 11-21-2015 05:46 PM 2532 reads 1 time favorited 18 comments Add to Favorites Watch
« Part 5: Escapement Gear, Minute Gear and Idler Gear - Day 5 Part 6 of MAKING A WOODEN GEARED CLOCK series Part 7: Bits and Pieces - Day 7 »
Got a late start today so not much done.
Todays Work
You might remember that I messed up the escapement gear. The sharp tips of the teeth were very fragile and I broke a few out on the tip and back edges. I made a replacement today and found a good cutting technique that preserves the tips of the teeth and I also used a close to zero blade clearance auxiliary table for my scroll saw which maybe helped too.
Improved Cutting Technique
Instead of cutting fragile tooth tips close to the pattern line I angled the entrance and exit cuts away from the tooth tips as shown in the photo below A good reason to leave some extra wood outside the pattern. This worked very well and no teeth were damaged this time.
Sanding Jig
After the completing the replacement escapement gear I wanted to sand it to perfect round and thereby also get rid of the excess tip material. When cutting gears it is a good idea to leave the pattern lines on the very tip to leave a sanding target.
To get accurate sanding, A sanding circle jig was made for my disc sander. If I didn’t have a disk sander I would have used it on my lathe disk sander. The jig is simply a couple of pieces of plywood with the top two pieces cut at an angle of 15deg. on one edge and then glued to the ply base to form a dovetail slot.
A sliding piece was cut at the same angle on each side to fit the dovetail slot and holes are drilled in the slider the same diameter as the holes drilled in the gear center. The drill bit is used as an axel to keep the gear running accurately. It took about 15 minutes to make.
It’s just to mount the gear, shove it into the sanding disk until you just sand away the pattern line on one tooth, then the slider is clamped as shown and the gear is revolved by hand until all the teeth are sanded. Very simple and effective. photo below
A test to Confirm Smooth Running
After sanding the idler and minute gears I mounted them temporarily to a board to see if they would run smoothly. This was a worthwhile test. I could feel a little drag in a couple of places so I marked with a pencil where it was binding and then filed down those areas.Very little filing was necessary to eliminate the drag. I don’t know if this is normal practice, but I thought it was a good idea Photo below
That’s it for today. Have a nice weekend and thanks for reading.
18 comments so far
View shipwright's profile
shipwright
8000 posts in 2848 days
#1 posted 11-21-2015 06:35 PM
Well done on the DIY “wheel balancer”. I’ll bet it saved you a lot of head scratching later.
This all looks so good it makes me want to build one but I’m a rubbish plan follower, too independant by nature, and I also have way to many ideas for this lifetime. :-)
Looking just sweet!
View Jim Jakosh's profile
Jim Jakosh
20743 posts in 3155 days
#2 posted 11-21-2015 07:17 PM
Nice going Mike. I’d call them Mercedes gears!!
We area ll learning from you!!
Cheers, my friend….............Jim
View stefang's profile
stefang
15881 posts in 3384 days
#3 posted 11-21-2015 07:18 PM
I can relate to that Paul. I’m not much of a plan guy either, but unlike you I have way to few ideas and especially when it comes to anything like gears. This is what happens when you spend your working life as an office rat with no useful skills for retirement. I am spending the rest of my life as the perennial apprentice. I feel lucky and privileged though to be in the company of so many skilled and creative people like yourself. Some of it rubs off once in awhile.
stefang
#4 posted 11-21-2015 07:27 PM
Yes Jim, the blind leading the blind. Remember, this clock might not work and then all my tips would be pretty questionable.
View CFrye's profile
CFrye
10272 posts in 1890 days
#5 posted 11-21-2015 10:28 PM
Mike, there is no doubt in our minds. It will work and work well!
-- God bless, Candy
View doubleDD's profile
doubleDD
7487 posts in 2093 days
#6 posted 11-22-2015 01:18 AM
I believe your ideas and sanding jig will bet you there. Can’t say what I would do in that case, only experience would tell. Looks like the battery back up mechanism is not needed yet. ha ah. I’m with you all the way.
View hunter71's profile
hunter71
3195 posts in 3236 days
#7 posted 11-22-2015 03:35 AM
You’ll be making a Grandfather clock soon Mike.
-- A childs smile is payment enough.
View madts's profile
madts
1864 posts in 2390 days
#8 posted 11-22-2015 05:55 AM
Keep up the good work. I like what I see
-Madts.
-- Thor and Odin are still the greatest of Gods.
stefang
#9 posted 11-22-2015 09:23 AM
If encouragement helps then this clock is bound to be a success. Thanks all.
Doug This is a grandfather clock (made by a grandfather).
View Sylvain's profile
Sylvain
708 posts in 2549 days
#10 posted 11-22-2015 11:54 AM
The pendulum is probably adjusted in such a way that the escapement gear makes one revolution in 60” (or 1’). Then the gear train must reduce the speed to obtain one revolution in 12 hours on the hour indicating gear.
12 X 60’ = 720.
So the final ratio must be 1/720 which of course is easier to do with multiple gears.
Otherwise you would need for instance a gear with 5 tooth and the other one with 3600 tooth. Furthermore, the 3600 tooth gear would have a very very large diameter (in fact 720 greater than the small gear diameter) which is rather impractical.
Sawing the tooth on a 3600 tooth gear is a work I wouldn’t want to do.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View johnstoneb's profile
johnstoneb
2965 posts in 2222 days
#11 posted 11-22-2015 01:28 PM
Mike
I mounted the gears in their position in the clock frame and ran them against each other and marked with the pencil and filed. This saved me the worry of getting the axle centers the exact distance on a separate board. Your scroll saw abilities make mine look like a beginner. I am enjoying your blog. Looking forward to seeing the clock run.
-- Bruce, Boise, ID
stefang
#12 posted 11-22-2015 02:00 PM
Sylvain Yes, I think the so called ‘minute’ gear must regulate the hour wheel. I’m looking forward to learning more about how all these gears work together, the ratios and the reason why they are placed as they are and how the idler gear assists the power train.
Bruce Thanks for the tip. I missed the obvious conclusion that the best test would be on the assembled clock itself. The rest of the work is mostly the pendulum and weight parts plus some spacers and axle caps.
View Schwieb's profile
Schwieb
1858 posts in 3511 days
#13 posted 11-22-2015 03:17 PM
Coming along nicely Mike. I’ve had a desire to make one of these since I was a teenager. About time I get my Roundtuit going.
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
stefang
#14 posted 11-22-2015 03:38 PM
Ken The parts are actually pretty easy to cut out. I think the main challenge is in the precision of the cutting and also the drilling. I’m not sure if my work is precise enough, but time will tell. On the upside, any parts that are bad can be redone.
Possibly such a project scares some people away because they haven’t got much knowledge of how clocks actually work (people like me). However with a plan, you just have to cut the parts from printed patterns and assemble according to instructions and then you learn how it works after you get it going. It is pretty enjoyable so far.
I remove the areas between the spokes on the gear first so I have something to hold on to. That goes pretty fast. I started out cutting one side at a time on the gears, but that got pretty boring so now I cut out the whole area between two teeth in one go. More entertaining, like the difference between driving a boring straight road for 1,000 miles or a winding road that keeps you alert and active the whole time,
I think that the most essential piece of equipment for a project like this is a good magnifier lamp with a florescent tubular bulb.
View Jim Bertelson's profile
Jim Bertelson
4187 posts in 3214 days
#15 posted 11-23-2015 03:16 PM
I do not focus as close up as I used to, but without my glasses, I can focus on something perfectly without glasses at 12”. Nearsighted, of course. But I bought my magnifying lamp about 20 years ago, I think, and use it with increasing frequency. It is indispensable for removing splinters from hands…............(-:
......I also have my WorkSharp located right next to that lamp.
Very interesting, Mike, and I like your auxiliary table. It closely resembles my circle cutting jig for my band saw. Of course, shop gizmos and me are fast friends from way back…..............
-- Jim, Anchorage Alaska
showing 1 through 15 of 18 comments
