MAKING A WOODEN GEARED CLOCK #5: Escapement Gear, Minute Gear and Idler Gear - Day 5
Blog entry by stefang posted 11-20-2015 07:08 PM 2397 reads 0 times favorited 19 comments Add to Favorites Watch
« Part 4: Day Finishing Up The Clock Dial - 4 Part 5 of MAKING A WOODEN GEARED CLOCK series Part 6: Recut One Gear and Made a Sanding Jig »
A Wonderful day
I was going to begin the task of converting my 6mm thick ply to 6.5mm. My plan was to sand down the 6mm enough so that I could add a veneer to bring it up to 6.5mm. The first thing I did though was to use my digital calipers to measure the actual thickness, and lo and behold it was exactly 6.5mm. What a relief! It made me very happy.
Today’s Work
I made the 6.5mm work pieces for the escapement gear,, the minute gear and the idler gear and some other pieces. The pattern for the fork like thing is the piece that runs on the escapement gear and it is attached at the upper end of the pendulum. It alternately locks and releases the escapement gear at each swing of the pendulum. see below
The escapement gear (the smallest one) is the gear which is alternatively locked and released with each swing of the pendulum to control the speed of the clock.
The minute gear regulates the movement of the clock dial as far as I know, but I won’t be sure of that until I have the clock assembled and running. Remember, the hour hand is stationary while the whole dial moves on this clock.
The idler gear
Another gear I’m not sure about regarding it’s purpose or name, but as far as I know it has nothing to do with the time, but is placed there to transfer power between other time keeping gears. So it is a kind of assistant to the essential gears and helps to keep the placement of the gears compact.
Just my take on it so far. I will get back to you on these gears as soon as I can after I have actually learned enough about them, meanwhile if any of you have a more accurate description please don’t hesitate to comment on it. see below
I changed a couple of things today. Instead of cutting and leaving a thin line to file off on each gear tooth, I just cut right to finished size. I was feeling more confident with my cutting after getting some practice with the first cuttings. It worked out well except for the escapement gear. I will have to recut that one because I got some chipping on the gear tooth tips and the back on a few teeth too. For that reason I put a zero clearance auxiliary table onto my scroll saw. It’s not 100% zero clearance, but close enough to solve the problem. The others gears came out perfect (my perfect).
Unfortunately I didn’t have time to cut the other items in the first photo. Believe it or not I have used only one blade for every thing I have cut for this project so far. A #5 Nicqua reverse tooth blade. This one must have super strength or something and it’s still cutting very smooth to boot!
Thanks for joining in the fun.
19 comments so far
View shipwright's profile
shipwright
7897 posts in 2707 days
#1 posted 11-20-2015 07:17 PM
You sure aren’t using much of your stock. The scrap must outweigh the parts ten to one. :-)
I know these are not extreme close ups but please allow me to be in awe of your scrollsaw skills anyway. The photo is plenty close enough to tell me you are far better than I am.
This is going to be a sweet machine Mike. Thanks or the ride.
Have you thought of paper backing before cutting the intricate bits?
View Mosquito's profile
Mosquito
9216 posts in 2202 days
#2 posted 11-20-2015 07:22 PM
I agree with Paul. A wooden gear clock is something on my “want to try” list as well. Thanks for sharing the process with us!
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View robscastle's profile
robscastle
4787 posts in 2114 days
#3 posted 11-20-2015 07:42 PM
Hello Mike,
I have been watching your posts, and from what I see all is progressing very well, its a very interesting concept clock, and enhanced by the way you go about producing it, both physically and the reporting aspects as well.
You are correct regarding idler gear, they are there simply there to transfer motion you can have as many as you want and they have no effect on the gear ratio from the driving gear and the driven gear, they simply power transfer and reverse the direction dependent an how many you use in the transmission.
I am also pleased to see a good result on the ply thickness, ply is in particular a product here that has definately had a severe loss of quality in regards to manufacturing processes used and final gradings available for use.
Finally I also have to fully agree with Paul and the other LJs in regard to your skills in scroll saw work and in particular gear cutting precision. A tilt of the hat is applied there.
-- Regards Robert
View Texcaster's profile
Texcaster
1271 posts in 1583 days
#4 posted 11-20-2015 08:39 PM
Nice work Mike, I’ve been following as well. A geared clock is great fun to watch taking shape.
Thanks for keeping to a photo only format, my youtube time is reserved for music. lol
-- Mama calls me Texcaster but my real name is Mr. Earl.
View doubleDD's profile
doubleDD
7136 posts in 1952 days
#5 posted 11-20-2015 08:57 PM
That intricate work keeps adding up. Those gears remind me of bicycle sprockets. Keep at it Mike. You know you might have just jinxed that blade.
View stefang's profile
stefang
15784 posts in 3244 days
#6 posted 11-20-2015 09:04 PM
Paul I just love it when you tell me how good I am at scroll sawing, but believe me when I say that there is an abundance of folks out there who are far better at it than I am. My accuracy is completely dependent on my magnifier lamp. I would love to use it on my chevalet too, but it doesn’t work so well there with the saw frame moving back and forth.
The backing is a great idea and one that I should have thought of myself. By the way, I used a glue stick today to glue on my patterns and it worked perfectly. The leftover pattern pulls right off afterward.
You are right about the waste factor as the gears are only about 10% of the workpiece after cutting. However, I am saving the larger cutouts between the spokes on the gears for example and any other larger pieces. I’m sure I can use them for other projects.
Mosquito Thanks. I hope you take the plunge. BTW I lived on a farm about 4 miles outside of Onamia Minn. back in 1944/45. It’s kind of a flat Norway. Lots of lakes and birch trees.
Robert Thanks for the praise and also the confirmation of what the idler gear does. The ply I’m using is what everyone calls Baltic birch ply. The different layers are all the same quality and there are no voids whatsoever. It is very expensive though. especially for clock gears as about 90% is wasted, except I can use a lot of that waste for other stuff.
Dave Talking about bicycles, I would like the make a wooden scale model of one for my oldest son so maybe this gear cutting experience will come in handy. He has built some really cool and very lightweight bikes. He buys the frames and parts and puts them all together himself.
View stevo_wis's profile
stevo_wis
127 posts in 2937 days
#7 posted 11-20-2015 10:42 PM
Wow Mike. Tremendous.
-- Stevo
View Jim Jakosh's profile
Jim Jakosh
20103 posts in 3015 days
#8 posted 11-20-2015 10:48 PM
WOW…..........I agree with Paul. you have about 10% of the stock left when you cut out the gears! That is one fine scroll saw job….........I would have had a few missing teeth in the gears!!
I can’t wait to see it running!..............Jim
doubleDD
#9 posted 11-20-2015 11:01 PM
Mike, are you talking a full scale functional bike or just a novelty model? That could be a nice on off project for me to work on through the next year or two. ha ha. It would be cool to ride.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1239 posts in 1623 days
#10 posted 11-20-2015 11:03 PM
You sure moved fast on this project. Exiting to follow along!
-- "Do or Do not. There is no try." - Yoda
View CFrye's profile
CFrye
10044 posts in 1749 days
#11 posted 11-20-2015 11:43 PM
Awesome progress, Mike! I’m taking notes on all these great tips.
-- God bless, Candy
stefang
#12 posted 11-21-2015 12:14 AM
Thanks for the encouraging comments everyone.
Dave I am just thinking a model, maybe 18” long, but one that functions. I doubt I can do the multiple gears on the back wheel, but I might be able to mock that part up. I’m not really sure I’m going to do this as the parts might be too small make, especially a functioning chain. The rest not so difficulty. I know how to make the chain, but pretty challenging at so small a scale.
View Philip's profile
Philip
1277 posts in 2448 days
#13 posted 11-21-2015 01:12 AM
Coming along nicely Mike! About a year ago I wanted to make a wooden gear clock with stained glass in the negative spaces, however baby came along and that is on the back burner. After looking though, there wouldn’t be much excitement to that because only the escapement piece has a lot of movement- all the other gears turn pretty slowly!
Can’t wait to see it.
-- I never finish anyth
View hunter71's profile
hunter71
3119 posts in 3096 days
#14 posted 11-21-2015 04:35 AM
Buying good blades is worth the investment.
-- A childs smile is payment enough.
View NormG's profile
NormG
5900 posts in 2913 days
#15 posted 11-21-2015 05:22 AM
Great progress, looking very good, congrats on the still sharp blade
-- Norman - I never never make a mistake, I just change the design.
