Making a Viking Bowl Candy Dish
Blog entry by stefang posted 12-05-2014 04:17 PM 2647 reads 5 times favorited 18 comments Add to Favorites Watch
You may have seen my project post here which explains the background for this design. Several readers expressed their interest in a blog to show how to make one of these, so here it is.
Background
Since this is not a replica of any genuine historic article, but rather a project inspired by the viking ships and their old time bear mugs you should feel free to put your own twist on this. That’s what the Viking carvers did anyway and no two of the inspirational pieces are alike anyway. The main difference here is that this one is turned and constructed rather than just being totally carved from a solid piece. In fact, I used a lot of different machine tools for most of the work and then did a little carving afterward on the handles. I made 3 of these. Two for my sons families and 1 for my wife and I. These are for fun and I did not try to make a prestige project out of them.
Quality concerns
If you look in the local museums around Norway you will find very few similar items that represent highly skilled woodwork. Most are somewhat crudely done, probably by farmers during the long winter months, but what they lack in professionalism they more than make up for it with charm. My work on these is about on parr with the farmers work I’ve seen around. So the message here is to have fun and don’t worry if they aren’t perfect.
Lets get started!
  1. Prepare the workpiece
    As you can see see, a piece of pine is inserted through the middle of the bowl blank. Paper is glued into the seams to make it easy to remove the pine strip after turning. See below
  2. Plane and sand to flat and then mount a faceplate or at least mark it’s location for mounting before cutting the workpiece round on the bandsaw. I wouldn’t go to all the trouble of flattening and centering for a solid blank, but it’s important that the faceplate be perfectly centere on this 3 part blank to insure that the two bowl halves will be the exact same size after turning. See below
  3. Mount on the lathe and turn the outside perfect flat to mount a tenon using a paper glue joint. The tenon must have a low enough profile so that the chuck is snug against the workpiece when mounted on the lathe, otherwise it is likely to break off under turning. See below
  4. Turn the bottom of the bowl and reduce the height of the tenon if necessary, which I have done here.See below
  5. The workpiece is then reversed for hollowing out the bowl, or as in this case 3 bowls. See below
  6. The middle waste strip is then cut out with the band saw or you can use a chisel, but I like to saw it out staying slightly inside the glue joints and then using a knife to gently pry off the remainder so as not to risk damaging the bowl edges. After that I put some pencil marks on the edges and lightly sand them on my sanding board to remove any residual paper or glue and to ensure they are perfectly flat. See below
  7. Preparing the patterns
    First I used 1/2 of the bowl to trace the profile onto a piece of poster board which will be used as tracing templates. the profile is used to to design the heads. Just one side is drawn as the template can be flipped to trace the other side. I wanted to use vertical grained wood for the head pieces, so I divided the the profile into 3 pieces Leaving a ‘keel’ and 2 heads. I then used the head piece and attached the end bowl profile to it to make my template for the vertical grain part which I traced onto the centerpiece wood and cut out with my scroll saw.
  8. These are the pieces that have been cut out with the scroll saw and are to be glued into the center of the bowl. These strips are more narrow than the original center insert and so the bowl will now be similar to a boat shape.
  9. Note that the above pieces have been placed onto the bowl edge to determine the exact location of the ‘keel’ piece and marked with pencil lines to insure proper positioning as this will be the first piece glued in as shown. A rub joint should be sufficient and once it is set then the heads can be glued on in a similar fashion and when they are set the other side of the bowl too.
  10. After the glue is dry overnight the next step is to apply the finish. This consists of coal from the fire, ground up fine and mixed with oil. I have used sunflower seed oil, but any oil that dries reasonably well should work fine. I then let it dry overnight and then give it a good rubbing with 0000 steel wool and or some sanding with 180 grit until you get the look you want. I can see that I missed sanding off some hot glue residue off mine and I will probably have to redo some finishing tomorrow. No problem. I just left the brush in the cup and it won’t dry out overnight.
Tips
  1. it is most important that the center pieces are glued in so that they will leave the inside of the bowl smooth because it will be difficult to sand the inside after everything is glued up. On the other hand, small deviations on the outside are easily sanded.
  2. It’s a good idea to sand the bottom of the glued up bowl on a sanding board to make the bottom flat enough to sit properly upright and stable. A lot of sanding is not required for this step, but it keeps the bowl from leaning or being wobbly.
I hope there is sufficient info above for you to do one of these, but please don’t hesitate to ask if you should have any questions. I found this project very enjoyable and I hope you will like doing it too. Thanks for reading.
PS my computer has been down for almost 2 weeks, otherwise I would have posted this sooner. I tried using my wife’s old computer, but that crashed too! I tried using my mobil phone to keep in touch on LJ, but that didn’t go very well. It’s great to be back in circulation again.
18 comments so far
117270 posts in 3749 days
#1 posted 12-05-2014 04:27 PM
Wow Mike That’s one terrific blog. The photo lay out makes it very clear and easy to follow. Thanks for taking the time.
This Viking bowl/candy dish is very unique and would be a great gift of conversation peice.
View stefang's profile
stefang
16058 posts in 3506 days
#2 posted 12-05-2014 04:42 PM
Thanks Jim. Did you ever find a new place? I remember you were planning to move and I have been wondering how that went. I hope you will be setting up a new shop there.
View Dutchy's profile
Dutchy
3120 posts in 2340 days
#3 posted 12-05-2014 04:47 PM
I always love your blog entries Mike. Glad your “back”.
-- https://dutchypatterns.com/
#4 posted 12-05-2014 04:54 PM
Hi Mike
Thanks for asking,but with the care of a family member and financial considerations,It became clear that retiring ad moving is not realistic. So We remain in the same place we have been for a number of years (unless we win the lottery :) ) .We have a lot to be grateful for where we are at,moving to the country is more of a want than a need.
Merry Christmas to you and your family Mike.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1251 posts in 1885 days
#5 posted 12-05-2014 05:44 PM
Lovely project! Like the way you inset the head and tail in the bowl. A bit like Krenow made planes..
Bra job!
-- "Do or Do not. There is no try." - Yoda
View Jim Jakosh's profile
Jim Jakosh
21504 posts in 3277 days
#6 posted 12-05-2014 06:07 PM
Nice tutorial. Thanks, Mike
6866 posts in 4151 days
#7 posted 12-05-2014 06:25 PM
Cool project!
View CFrye's profile
CFrye
10440 posts in 2011 days
#8 posted 12-05-2014 06:55 PM
Very clear and helpful tutorial, Mike. Thank you for sharing!
-- God bless, Candy
stefang
#9 posted 12-05-2014 08:06 PM
Thanks for those nice comments Jan, KHB, Jim, Lee and Candy.
View Druid's profile
Druid
1894 posts in 2967 days
#10 posted 12-05-2014 10:44 PM
Nice tutorial Mike. I can imagine a lot of these appearing around the LJ community. It would be fun to see how many countries around the world end up having one of these, so I hope you receive a lot of feedback notes and photos.
I also wonder why the new beard has gone so long without comments?
-- John, British Columbia, Canada
stefang
#11 posted 12-05-2014 11:21 PM
All right John I’ll confess. My jealous wife made me grow this beard so other women wouldn’t want me and now that I’ve got it she doesn’t want me either!
I do hope some others will make some of these. There is lots of room for personal expression and the wood carvers can have some fun doing the handles/heads.
View grizzman's profile
grizzman
7836 posts in 3475 days
#12 posted 12-05-2014 11:43 PM
now mike, you told me you had this beard because you were jealous of mine, now you better get your storys right here, or no one will want you…LOL…IF YOU GET TO THE POINT OF THAT I DO HAVE A DOG THAT MIGHT TAKE YOU…LOL…nice blog here, if i had a lathe i would make one…
-- GRIZZMAN ...[''''']
View SPalm's profile
SPalm
5325 posts in 4054 days
#13 posted 12-05-2014 11:59 PM
That is pretty neat Mike.
I had no idea that it was a split turning. I like it.
That is more beard knowledge than I need.
Steve
-- -- I'm no rocket surgeon
View doubleDD's profile
doubleDD
7766 posts in 2215 days
#14 posted 12-06-2014 05:09 AM
Hi Mike. That is a very interesting concept of splitting the bowl and adding a insert like you did. First time I ever seen anything like it. Beautiful job on the bowl with a great blog showing every detail. Don’t know if I will do anything like this soon, but will be on my list for winter projects. Thanks for sharing this.
View kiefer's profile
kiefer
5620 posts in 2839 days
#15 posted 12-06-2014 01:31 PM
Nicely done blog and project Mike.
I always enjoy your blogs as they are so detailed and full of info that is also useful and applicable to other projects as well.
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
showing 1 through 15 of 18 comments
