CHRISTMAS GIFT BASKETS #2: Material Preparation (Continued)
Blog entry by stefang posted 10-15-2014 06:25 PM 2081 reads 1 time favorited 11 comments Add to Favorites Watch
« Part 1: Materials Preparation Part 2 of CHRISTMAS GIFT BASKETS series Part 3: Chase to the Cut »
Yesterday the basket side blanks were prepared. Today was used to prepare the materials for the bottoms, the top rims and the bottom wrap around feet.
I’ll take each item in turn to explain and show with photos how each part is prepared together with dimensions, but first a little general info just to give you a little insight into the pieces that go into the build.
Angles summary
  • The sides are angled outwards from bottom to top at 15 deg. with top and bottom edges angled at 15 deg.
  • The feet angled outwards from top to bottom at 15 deg.
  • The inside and outside edges of the top rim are angled outwards from bottom to top also at 15 deg.
  • All corners will be mitered at 45 deg.
  • The 4 outside edges of the bottom piece will be angled outwards from top to bottom
  • Sides & Feet
    The angle configuration requires that the top and bottom edges of the sides and the feet be ripped parallel at a 15 deg. angle . When placed into position the result will be a flat surface to join the sides with the feet.
  • Top Rim
    The top rim is requires a 15 deg. cut along the inside and outside edges and the top and bottom are flat.
  • Corners
    All of the above components will be joined into 3 squares cut with 45 deg. miters. These miters will in fact be compound miters, but the cuts will require only one 45 deg. saw setting because the parts will be positioned on the saw just as they will be in the finished basket. An auxiliary fence with a 15 deg. angle on it’s face will be used to correctly position the pieces for cutting.
  • Bottom
    Only the outside edges are angled at 15 deg. outwards from bottom to top.
PARTS PREPARED TODAY
The components have all been cut a little larger than final dimensions to allow for any necessary adjustments.
  • Bottoms
    The bottoms will be prepare with two matching pieces with a glue joint down the middle. I first ripped a 2.1cm board to a width of 10cm and then resawed it into to 2 pieces and planed them smooth to 5mm thick. The were then cut to a finished length of 20cm ready for joining. I will do some very light sanding on a sanding board prepare the inside edges for joining. The 15 degree angle on all the outer edges will be done after the bottoms are glued up. See below:
  • Top Rims and Feet
    The top rims and feet were prepared in the same way and with the same machine set ups except that the feet pieces are shorter than the rim pieces as the basket is angled inwards from top to bottom so only the stop on the miter saw had to be readjusted for that difference.
First a boards were resawn and planed to 7.5mm The first photo shows the parallel angles marked for the strips which were the ripped at a 15 deg. angle with a width of 17mm per strip on the table saw. The strips were then cut to lengths about 1cm longer than the finished length in the miter saw with the same set-up used for the bottoms in photo 3. An angle fence with a 15 deg. angled face was then cut on the table saw and attached to the miter saw fence and a zero clearance auxiliary top added to miter saw table. The miters were then cut on one end of each rim and foot piece at a 45deg. setting while resting agains the angled fence in the same position they will occupy in the finished basket. This cut yields a compound miter angle with only the one saw setting. Once the basket sides have been scrolled, mitered and glued up, I will cut the other end miter on the rim and foot pieces measuring directly from the basket sides to ensure accuracy.
  • Results so far
    All the materials are cut as shown or at least rough cut. The ends of the side pieces will not be mitered until after the scroll work is finished. This makes it easier to accurately stack them for cutting. The top and bottom edges of the sides will also have to be angled at 15 degrees. This will be done on the hand sanding board after the the sides have been glued up to insure a consistency flat surfaces for gluing the rim and foot pieces to.
About 3 hours were used for today’s work. A total of 5 hours on the project so far or 1 hour per basket. This is a great project for production work. Setting everything up takes a little time with three machines involved, but the set-ups are used for more than one part and it all goes pretty quick considering we have now prepared 70 blanks altogether.
I guess the text is a little over the top but I am always worried I will leave out important info or steps. I will include all the dimensions for each component as I cut them just prior to assembly. I suggest you wait until the blog is finished before you begin making them yourself so you will be able to better evaluate the process and perhaps do it in a way better suited to your own preferred methods and tools at hand. I will be more than happy to answer any questions you might have. Thanks for following with.
11 comments so far
View poospleasures's profile
poospleasures
734 posts in 2481 days
#1 posted 10-16-2014 12:04 AM
Really nice. I missed the first blog but have gone back for it. I appreciate your showing in such detail. I am not a very good scroller but would probably give this a try and hope to get it done by Christmas. Thanks
-- I,ve had amnesia for as long as I can remember. Vernon
View shipwright's profile
shipwright
7980 posts in 2795 days
#2 posted 10-16-2014 12:15 AM
Very nice gift idea Mike.
Good build description too.
Thanks.
View grizzman's profile
grizzman
7836 posts in 3300 days
#3 posted 10-16-2014 12:53 AM
i think these are terrific gifts to give, they sure to bespeak a craftsman has been at work, they would be so enjoyable to make as they require quite a few different skills and whoever receives one should feel blessed…
-- GRIZZMAN ...[''''']
View hunter71's profile
hunter71
3178 posts in 3184 days
#4 posted 10-16-2014 02:10 AM
Very nice.
-- A childs smile is payment enough.
View kiefer's profile
kiefer
5619 posts in 2664 days
#5 posted 10-16-2014 02:48 AM
Nice project Mike
I don’t have a scroll saw but may give something like this a go using a router and pattern .
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
TopamaxSurvivor
18269 posts in 3673 days
#6 posted 10-16-2014 03:29 AM
Nice work Mike. You are a master wood worker and a master blogger, too! ;-)
13603 posts in 3338 days
#7 posted 10-16-2014 04:32 AM
well done mike
and a great gift idea
you do inspire
and the tutorial is excelent
View stefang's profile
stefang
15881 posts in 3331 days
#8 posted 10-16-2014 07:42 AM
Thanks much everyone. Even I get a bit confused reading that text, but I hope the folks reading it are smarter than me and can understand it better.
Of course to make one of these baskets this whole project could easily be done with just a hand fret saw, a back saw and a hand plane and a rip saw and it could be done rather quickly using just those tools. I might try that sometime just for fun. Otherwise the project could be done with just a table saw, or a bandsaw and scroll saw.
View Schwieb's profile
Schwieb
1857 posts in 3458 days
#9 posted 10-16-2014 10:43 AM
This is a delightful project. Following your description here I could build this.
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
stefang
#10 posted 10-16-2014 12:57 PM
Thanks Ken. It would probably have been a much better blog to just build one basket. I have complicated it quite a bit describing how I am handling a production run on it using all those machines, but I hope it will work out ok anyway.
View Roger's profile
Roger
20928 posts in 2801 days
#11 posted 10-20-2014 10:25 AM
A really nice gift for anyone. Good stuff Mike.
