SHOP IMPROVEMENTS #8: FINDING A PARKING PLACE FOR MY CHEVY
Blog entry by stefang posted 05-25-2014 04:54 PM 1984 reads 0 times favorited 19 comments Add to Favorites Watch
« Part 7: ADDING A WATER SUPPLY TO MY SHOP Part 8 of SHOP IMPROVEMENTS series no next part
The problem
When I decided to build a Chevalet for marquetry work I honestly didn’t think I would be able to find a place for it in my shop. It already felt quite crowded in there. Whenever I sweep the floor every storage cabinet, and machine tool has to be moved to get the job done. That’s why all of my tools and cabinets are on wheels, even my drill press. I decided to go ahead and build a Chevalet anyway hoping that I could dream up a solution in order to create a place for it.
My shop is 7ft. wide and about 32ft. long and shaped like an ‘L’. The long part of the ‘L’ is about 22ft. long and the short part 10 ft. long. In other words about 224sq. ft. altogether. It is kind of like a wide hallway. It’s not too bad, but it has one big disadvantage, and that is, that it is not possible to have anything in the shop that you can walk around. Every machine tool cabinet or whatever is against a wall.
The goals
I’ve rearranged my shop many times during the last 13 years since I built it, usually to accommodate new and larger machine tools, so I’m used to doing that, but this time thinking up a solution wasn’t good enough. I had to draw up a floor plan sketch to scale and I also measured and drew up each tool/cabinet based on the floor space each required. Then I cut them out and placed them on the floor plan sketch to see how they could best be arranged. The priorities for placement where:
1. Operator safety and comfort.
2.The tools could be used to their full capacity (long boards could be processed, etc.).
3. The top of some tools or cabinets could double as out feed tables to the machine next to it.
4. Ample space between everything to allow for unimpeded movement for myself.
5. The dust makers, like my table saw combo machine, router, bandsaw and disk sander could hookup easily to my shop vacuum.
6. A more or less dedicated area for my marquetry work including placement of my marquetry bench, Chevalet and scroll saw (yes, I still love my scroll saw).
The solution
Luckily I found a way to accommodate the Chevy and at the same time meet my other goals much better than expected. It was all based on getting rid of a ‘junk’ corner which was about 1/2sq. yard where I had been accumulating metal parts like threaded rods, steel plating, aluminum profiles, etc. I cleaned out that little corner by storing that stuff in the loft and then everything else fell into place. My Chevy is now permanently parked in the short part of the ‘L’ with my marquetry bench and my scroll saw. I only had to move my marquetry bench, my Tormek sharpening center and drill press to new locations to get the job done. Here are the photos. The first shot shows where the marquetry bench was located before moving it to the end wall.
BEFORE
AFTER
Result
As you can see, the stool for the marquetry bench is also adjacent to my scroll saw and right next to the Chevy. the other shot shows the drill press in a better location where longer boards can now be drilled. In that same photo you can also see the new location under the window for my Sharpening station which is now located next to my bench grinder. Unseen to the left of the sharpening station is my hand power tool storage cart.
This solution actually resulted in a lot more improvements than I could have wished for. I hope those of you who have shop space problems of your own might find some inspiration here for improving your own situation. Thanks for looking in!
19 comments so far
117417 posts in 3814 days
#1 posted 05-25-2014 05:01 PM
Good thinking Mike, looks like you fought the square footage problem and you won .
View hunter71's profile
hunter71
3316 posts in 3423 days
#2 posted 05-25-2014 05:07 PM
Build a bigger shop, I always say. LOL
-- A childs smile is payment enough.
View Brit's profile (online now)
Brit
7601 posts in 3079 days
#3 posted 05-25-2014 06:54 PM
Looking good Mike. Can’t wait to see what you turn out on that Chevy.
-- Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View JoeinGa's profile
JoeinGa
7739 posts in 2244 days
#4 posted 05-25-2014 07:13 PM
I just GOTTA STOP complaining to the wife about how much smaller this new shop I’m setting up is compared to the one I had to leave behind when we left 10aSEE.
Good use of what you have there Mike!
View Dutchy's profile
Dutchy
3195 posts in 2405 days
#5 posted 05-25-2014 07:26 PM
Mike,
Thank you for sharring.
I.m almost retired and do more and more woodworking on 20 m3. Perhaps in the future I want to make a belt sander. But the same as you I don,t know were to put it. Al my machines are also on wheels, also the drill press. I know that what I,m writting don,t help you to get more space. But the meaning is to make you happy with your 67 m3. ;)
-- https://dutchypatterns.com/
View stefang's profile
stefang
16209 posts in 3571 days
#6 posted 05-25-2014 07:57 PM
Thanks Jim, Hunter, Brit, Joe and Dutchy.
Dutchy I actually have only about 20m3 too. Check out the link here
View Rob Drown's profile
Rob Drown
800 posts in 4070 days
#7 posted 05-25-2014 08:18 PM
nice Job. Well thought out!!
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
stefang
#8 posted 05-25-2014 08:48 PM
Thanks Rob, the changes have taken a load off my mind. I hope you’re not having drought there in Roseville. I read that Folsom lake/reservoir was almost completely dried up.
Dutchy
#9 posted 05-25-2014 09:19 PM
Sorry Mike I did a wrong conversion. But I really hope you are still glad with your shop.
stefang
#10 posted 05-25-2014 09:24 PM
No problem Dutchy, I just wanted to prevent you from ordering anything based on the faulty conversion as you might have wound up with more than 3 times as much as you wanted! I usually just divide the square feet by 9 which gets me fairly close.
View Roger's profile
Roger
20965 posts in 3041 days
#11 posted 05-26-2014 12:18 AM
Looks like a good solution Mike.
View Kaleb the Swede's profile
Kaleb the Swede
1880 posts in 2206 days
#12 posted 05-26-2014 12:44 AM
Mike you have a shop I dream about. Looks very nicely set up
-- Just trying to build something beautiful
Rob Drown
#13 posted 05-26-2014 05:30 AM
We had some late rains that made a big difference, now it is the driest year in like twenty years. Back in January it was lookin like it was going to be the driest year in 50 years.
Very cool shop !!!!
View shipwright's profile
shipwright
8187 posts in 3035 days
#14 posted 05-26-2014 05:38 AM
Nice reorganization Mike. I just turfed out my shop for the first time since I built it ten years ago. If it hadn’t been used in the last five it left the building…........ that was a lot of junk. The re-vamp is ongoing. I’ve even installed the window and door casings and baseboards that I never got around to originally. That’s my big shop here of course. My little shop in Az. wishes it had as much room as you do. :-)
Now stop procrastinating and cut something amazing.
stefang
#15 posted 05-26-2014 08:59 AM
Thanks Roger, Kaleb, Rob and Paul.
Paul I’m having a WOW experience before doing any marquetry. That’s ‘Waiting On Weather’, bad weather that is. I will probably be doing something amazingly simple before graduating to more difficult work. I hope you will post your shop when you get it the way you want it.
