Blog entry by stefang posted 03-06-2013 06:22 PM 2494 reads 3 times favorited 32 comments Add to Favorites Watch
Welcome to my shop. Yes, today I will show you how to make color copies with your bandsaw.
1. Just take what you want copied and place into your bandsaw blade like this.
2. Now push it slowly through to the other side of the blade like this.
3. Separate and now you have a perfect copy! Well, book matched anyway, nothing is perfect.
This is the outcome after some hand sanding with 80 grit paper. I rubbed on some ethanol to bring out the colors, but it evaporated so fast that the first one on the right was almost dry before I took the pic.
Two 1/2” birch Plywood panels were glued to both sides of my dragon marquetry which was about 1/4” thick. I pressed the lamination in my newly finished veneer press .
Counter veneers still have to be glued onto the backside of each copy to prevent warping. I plan to do that tomorrow so it can dry while I clean.
Paul ‘Shipwright’ advised me to sandwich the dragon between two platters before resawing. This advice virtually guaranteed a good outcome. The cut went perfectly and I’m sure this was due to the sandwich. I will (almost) always heed any woodworking advice from someone who can build beautiful yachts and master marquetry, as Paul has done! Many thanks Paul!
I am equally indebted to Mathew Nedeljko another marquetry master who shared his veneer press in an excellent blog and which I unashamedly copied. He was also kind enough to supply me with the dimensions and his good wishes. It made the glue-up quite easy! Much thanks Mathew!
My wife has been pleading with me not to attempt this resaw after using so much time to make the dragon. However, I never had a doubt that it would go perfectly well. That dryness in my mouth just before beginning the cut was probably just due to a little dust in the shop!
A finish has to be decided on. I honestly don’t know what would be be best. I want to use something that will enhance the colors and provide good contrast. Any suggestions are welcome.
Frames have to be made for the dragons and then I have to decide who to give one of them to. That will be a little difficult because I really don’t have any favorites in the family. They are all quite lovable. I would like to keep the other since I like it and I’m a little proud of it too, especially since I used a somewhat unconventional method to produce it, and though it isn’t that special, it is good enough to have given me the confidence to go further with this kind of work.
But before doing the finishing and frames, I am dying to show you all the stuff that I’ve purchased just to get started with marquetry. I plan to do that in my next blog in this series. But first I have to clean up the shop a bit. A woodworkers work is never done!
Thank you for joining in and I hope you found something interesting or at least informative here.
32 comments so far
View grizzman's profile
7836 posts in 3233 days
#1 posted 03-06-2013 06:41 PM
yea!!!!!!!!!!!!!!ya whooooooooooooooooooo!!!!!!!!!!!!!!!!!!, im so happy all went well. i was really scared with the cut, but you and paul did it, thank you all for the help you gave to mike. but mainly thank you mike, you did a project that was sorta stacked against you , and you made it happen..and now you have two beautiful dragons…congrats mike…now i can sleep…lol…grizz
-- GRIZZMAN ...[''''']
13598 posts in 3271 days
#2 posted 03-06-2013 06:44 PM
this is great news mike
what we have all been waiting to see
excellent work !
maybe names in a bowl
and the wife picking the winner
of the gift one
18224 posts in 3606 days
#3 posted 03-06-2013 06:47 PM
Congrats! Beautiful job and a great accomplishment.
View stefang's profile
15859 posts in 3264 days
#4 posted 03-06-2013 07:17 PM
Thank you Grizz, David and Bob. The bowl idea is good David, thanks for the suggestion. Right now I am leaning towards my son in Sweden. We plan to spend quite a long time with them in Sweden and I though it might be a nice thank you gift to them, especially since they like all that fantasy stuff. I am also hoping I can teach my son to do some marquetry work while we’re there. That is if I can learn it myself before our visit.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2786 days
#5 posted 03-06-2013 07:35 PM
Mike it took me a while to look, I found the thought of cutting such
wonderful piece terrifying. I might have been tempted to follow your
Wife’s thoughts.
Very well done Mike and thank you for sharing the whole process as
always it was very educational.
I look forward to your next adventure
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View AJM's profile
86 posts in 2050 days
#6 posted 03-06-2013 08:11 PM
Wow.. Looks like I will have to read some of your other posts..I would not trust my band saw to do that.
-- Englishman in Finland I am guessing that i am Finglish.
View PASs's profile
595 posts in 3028 days
#7 posted 03-06-2013 08:15 PM
Beautiful marquetry, and nice job sawing it to pieces…
So….if you made it an inch thick you could cut enough for the whole family.
-- Pete, "It isn't broken, you just aren't using it right."
View DS's profile
2865 posts in 2350 days
#8 posted 03-06-2013 08:23 PM
Color copies on the bandsaw… who woulda’ guessed?
I’ll bet you were very nervous resawing that—I would’ve been.
Your marquetry is amazing!
That is one of the areas of woodworking that I’ve yet to explore.
Thanks for sharing!
#9 posted 03-06-2013 08:26 PM
Thanks Jamie, AJM and Pete. I think I’m finished with the thick stuff Pete, now I want to try regular thin veneer.
View lanwater's profile
3111 posts in 2864 days
#10 posted 03-06-2013 08:58 PM
That’s an excellent copy. Mabe can copy money Hmm…
I think the color looks terriffic. No need for tweeking there.
-- Abbas, Castro Valley, CA
View  woodshaver Tony C   's profile (online now)
woodshaver Tony C
5831 posts in 3283 days
#11 posted 03-06-2013 10:02 PM
I’m so happy that your color copy turned out as planned. It’s Grand to say the least! I would of been up all night just thinking about that cut. All I can think is WOW you did it!
I’m glad you had the support you needed to accomplish this beautiful work. My hats off to you Mike and all that helped you, Congratulations!
-- St Augustine FL, Experience is the sum of our mistakes!
View Brit's profile (online now)
7366 posts in 2773 days
#12 posted 03-06-2013 11:07 PM
Fantastic work Mike. I admire your courage running that through the bandsaw, but it turned out great. Well done.
-- - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View shipwright's profile
7935 posts in 2728 days
#13 posted 03-06-2013 11:59 PM
Mike, as someone who likes to re-invent the wheel as much as the next guy (at least as much) I fully understand and applaud your re-invention of the venerable art of marquetry. Who could argue with these results.
You have planned, designed and executed a whole process that has worked out perfectly and you have every right to be as proud of it as any peacock. My hat is off to you my friend, Bravo.
For a finish, IMHO you can’t beat simple shellac.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View littlecope's profile
3071 posts in 3432 days
#14 posted 03-07-2013 12:09 AM
Just do it, right Mike!?
After all, what could go wrong?
If the cut goes off or wanders, you’d only be out ??? hours and days worth of work, thought, and planning… :)
You’ve got Nerves of Steel my Friend!!
Great Job on the “Twins”, and thanks for taking us all along for the journey!!
View Mathew Nedeljko's profile
Mathew Nedeljko
715 posts in 3760 days
#15 posted 03-07-2013 03:30 AM
What a great outcome to this wonderful journey…you have successfully arrived at your destination!
It looks like the resaw worked out great Mike and you have an excellent book matched pair.
I’m with Paul, I would go with a simple shellac finish, have you tried french polishing? That is another skill a marqueteur needs to have. Looking forward to the pics of your press!
-- Aim high. Ride easy. Trust God. Neale Donald Walsch
showing 1 through 15 of 32 comments
