Sailing Downwind
Blog entry by stefang posted 01-14-2013 07:54 PM 3144 reads 1 time favorited 10 comments Add to Favorites Watch
TODAYS WORK
Today was better. I bandsawed a background piece about 3/8” thick and a thinner piece 1/32” thick to be cut with the background as a pattern to mark the pieces to be cut and inserted into the background as shown in the photo below.
Here is the pack with the dragon pattern attached.
After cutting out the main body parts, I detached the thin platter and used it to trace the parts onto the insert pieces, then I inserted them into background piece.
RESULTS
The inserts were a pretty good fit this time, but not as good as I would like. There were some gaps. Most of these can be eliminated by trimming some areas that are too tight and the rest might close when glued in place, I’m not sure yet. I think I made my pattern piece too thin at 1/32” and it was a little difficult to work with while I was tracing. I have to make another pattern piece for the other inserts, so I will make it about 1/16” to see if that helps.
The cut stayed at 90deg. this time from top to bottom, so that part worked out very well thanks to using a thinner background piece. Once all the inserts are glued into the background I can resaw it into two finished pieces to double the return for my effort. I should then wind up with two marquetry works which are each 1/8” thick and about the size of an A4 piece of paper.
10 comments so far
13594 posts in 3245 days
#1 posted 01-14-2013 08:00 PM
looks like you are working out
all the bugs
and the dragons
well done
TopamaxSurvivor
18189 posts in 3579 days
#2 posted 01-14-2013 08:09 PM
Nice work Mike. I saw your comments about inspiring other. You and Shipwright are getting me interested ;-)) But I have too many interests already and I’m way behind!
View cosmicturner's profile
cosmicturner
403 posts in 3299 days
#3 posted 01-14-2013 08:25 PM
Looks great Mike nice work
-- Cosmicturner
View shipwright's profile
shipwright
7894 posts in 2702 days
#4 posted 01-14-2013 09:09 PM
Getting better each time Mike.
BTW, you seem to be doing some quite fine re-sawing there. Kudos for that too.
View stefang's profile
stefang
15784 posts in 3238 days
#5 posted 01-14-2013 10:18 PM
Thanks guys. I appreciate the resaw comment Paul. I love that big bandsaw! I can resaw down to whatever thickness i want with that thing. It really amazes me. I found that I can handplane real thin veneers too. I use my little Stanley block plane with a small mouth opening and a light setting. It smooths very quickly. I finish up with a couple of passes with sandpaper diagonal and one pass with the grain. I just carpet tape the thin piece to a piece of ply that is held between my bench dogs. Works great and very accurate too.
I don’t know how this will turn out. I thought I might use it on something for the grandkids if it isn’t too bad.
View Brit's profile
Brit
7364 posts in 2746 days
#6 posted 01-14-2013 10:45 PM
I’m really enjoying this blog series Mike. It is all new to me, but I’d like to try my hand at some marquetry some day. Thanks for sharing your journey.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Tim Dahn's profile
Tim Dahn
1564 posts in 3469 days
#7 posted 01-15-2013 12:11 AM
Hi Mike, I’m with Andy on this one not sure I will be doing marquetry any time soon. I have enjoyed reading this series and I always seem to pick up some tip that will come to me when working on some other type of project. Keep on climbing the learning curve.
How is the winter in Norway this year?
View kiefer's profile
kiefer
5618 posts in 2571 days
#8 posted 01-15-2013 03:39 AM
Hi Mike
I have been following your new adventure with interest but must say I know beans about this subject ,so no advise from here .
Also read your Birchy blog and I can relate to it very much ,I planted a tree for every grandchild and here is a pic of the oldest ( Manchurian ash ) about 15 years old .
This tree is for the next generation and I shutter very time we get a wind storm .
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
stefang
#9 posted 01-15-2013 11:33 AM
Thanks Kiefer. That’s a beautiful little tree. As you can tell from my blog I don’t know beans about marquetry either. If want to see real marquetry and learn something you can follow Shipwright’s projects and blogs. My efforts here more exploratory tinkering than anything else. But that can be fun too with all the drama!
View ruddy's profile
ruddy
541 posts in 2843 days
#10 posted 01-15-2013 09:46 PM
Thanks again for sharing this work. Very interesting how you resaw the finished piece.
-- And my head I'd be a scratchin'
