What is it?
Blog entry by stefang posted 07-01-2012 06:34 PM 8298 reads 2 times favorited 43 comments Add to Favorites Watch
I just finished making the item pictured for my oldest son Steven. I wondered if others had made something similar and I thought it might be fun to see if others would know what it is used for. One thing I can say up front is that it is not being used for a woodworking project, although it could be.
I feel that a big hint is in order her, as it is very specialized, and fairly obscure. I can tell you that it is related to a fly fishing equipment project.
The white bit is a hollow plastic tube and the lid at the top would be removed while being used and the bottom end would be sealed with a cap. The black tape will be thrown away and has no use. The stand itself could be made in different ways and it’s sole purpose is to hold the tube steady and straight up.
I hope you will give a guess or even better just tell us what it is. Good luck!
Mike
43 comments so far
117128 posts in 3606 days
#1 posted 07-01-2012 06:47 PM
A holder to help you tie giant 4’ flys ? LOL
View Brit's profile (online now)
Brit
7387 posts in 2871 days
#2 posted 07-01-2012 07:15 PM
No idea Mike, but I can’t wait to find out.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View grizzman's profile
grizzman
7836 posts in 3332 days
#3 posted 07-01-2012 07:25 PM
its a fly fishing rod tester, you fill it with water and insert the fishing pole, if it bobs up to the top, then you know your fly rod is sealed and will float if it gets away from you…:)........or you fill the tube with water and you stand back and cast at it, if your fly goes into the water in the tube, then you know you have a dead on aim and can place your fly where ever you choose to…so its a fly aiming casting device…......so are any of us close yet…lol
-- GRIZZMAN ...[''''']
View johnstoneb's profile (online now)
johnstoneb
2943 posts in 2201 days
#4 posted 07-01-2012 07:30 PM
I think it’s a dip tube for applying finish to bamboo rods.
-- Bruce, Boise, ID
View daltxguy's profile
daltxguy
1373 posts in 3943 days
#5 posted 07-01-2012 07:38 PM
It’s obviously a very large test tube holder
....or a piano stool
....or a christmas tree stand
-- If you can't joint it, bead it!
grizzman
#6 posted 07-01-2012 07:39 PM
Needle Tube Fly Vice
Assuming I would find it hard to fix these slim tubes with my existing tying gear, Grays sensibly sent me their Needle Tube Fly Vice. The assumption (and it’s a good assumption) is that I already have a vice, so this came without a clamp or pedestal. The shaft is 8mm diameter so should fit the clamp already supplied with most vices and does fit mine. The head is simply a pin-vice fitted to a block which rides on the shaft. One screw fixes the block on the shaft and sets the tying height, the other locks the pin-vice in position – release that and you can turn the vice or remove it from the block.
The pin-vice head is like a small drill chuck: four sprung jaws inside a threaded collar, tighten the collar and the jaws are forced closed, unscrew and they open.
Take a step back and the design of this vice is not particularly pretty, however, this is an utterly practical solution to the problem of holding a slim tube in position while I tie on it.
Obviously, this vice head can hold other tubes if they are slim enough and a larger ‘optional’ vice head accepts tubes up to 3mm diameter. This method of holding tubes really only suits metal tubes and even then I would be wary of tightening on an aluminium tube. However, I can fix a darning or sewing needle into the standard jaws and that can hold softer tubes, eg plastic and aluminium, so this is more than a one-trick tool.
View mafe's profile
mafe
11732 posts in 3118 days
#7 posted 07-01-2012 07:42 PM
Potato gun.
13609 posts in 3370 days
#8 posted 07-01-2012 07:49 PM
coat rack
View Dave's profile
Dave
11429 posts in 2869 days
#9 posted 07-01-2012 07:56 PM
A butter churn
A fishing pole holder
A quad pod
A form for thatch brooms
A taxidermist fish holder
New an improved Harry Potter Quidditch Firebolt Broom
View longgone's profile
longgone
5688 posts in 3337 days
#10 posted 07-01-2012 07:59 PM
It is for holding up an umbrella
View NH_Hermit's profile
NH_Hermit
394 posts in 3125 days
#11 posted 07-01-2012 08:39 PM
Mike, this is a good quiz! My first blush guess is something to do with bamboo rod building, like holding it while the strips dry.
You’re talking me into a fishing trip to Norway which is already on my bucket list.
-- John from Hampstead
View GMman's profile
GMman
3902 posts in 3726 days
#12 posted 07-01-2012 08:50 PM
Fishing rod case, the stool is just to hold it.
View Schwieb's profile
Schwieb
1858 posts in 3490 days
#13 posted 07-01-2012 09:37 PM
No fly fisherman here. I’ll be interested to hear what it is
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
Brit
#14 posted 07-01-2012 09:39 PM
A periscope to see where the fish are.
View Joe Lyddon's profile
Joe Lyddon
10123 posts in 4081 days
#15 posted 07-01-2012 10:08 PM
Open sided Butter Churner… ?? (LOL)
One Hat hat rack?
showing 1 through 15 of 43 comments
