This is what I am attempting to make
CUTTING TOOLS DETAIL
I took a few photos to show you some of the smaller details of the cutters. Unfortunately after all the praise heaped on me for making such fine tools, I will now be exposed as less skillful than you might have thought. The details reveal some pretty sloppy cutting and also centering of slots. However, they do work well.
Tip
The slots are centered on the tool with a center line. Drill points are marked on the centerline at the start and finish of the slots. the holes are drilled and the slots are cut out. This is very simple in theory, but I found it much more difficult in practice. I did get better at it with improved technique, but I’m not thrilled with the result. The good news is that I can make these over again whenever I want.
Note the light blue color still remaining on a couple of the tips shown above. This is the color to look for when tempering. According to the charts it should be more straw colored, but the book said light blue. This works, so it’s ok.
This image (above) is to give you some idea of the shape of the cutting tips.
Another shot of the cutter ends standing on edge. If you were Looking at the cutter laying flat as it would on the tool holder the width of the cutting tip is 1/8”(3mm) on the top and 3/32”(2mm) on the bottom. As you can see, the very end has the bevel ending in a sharp point. This is where the cutting takes place. It is important that this tip is as wide or wider than the rest of the radiused cutting end to prevent jamming as cutting progresses.
BALL CUTTING JIG
The ball cutting jig is somewhat optional. If you can cut balls freehand then you probably won’t need it. The one pictured is made from the plan in the book ‘Woodturning Wizadry”. The cutting tool is adjustable so it can be adjusted in for each small cut. This jig will only cut one radius, the 62mm ball used for my project. I have adapted it to my lathe so it is easily positioned or removed. It’s rather a pain in the neck to manually adjust the cutter after each cut, especially since each cut is so shallow (by necessity).
The knob on the top is to lock the cutting tool.
Here is a detail photo of the cutting tip.This tool is a piece of hardened and tempered 1/4” (6mm) steel plate shown in the photo above.
The book suggests screwing the jig base onto a wooden bench under the the lathe carriage. I tried this but found it very inflexible and time consuming to set-up and remove, so instead I just use a board on the bottom (as seen above) of the platform that sits very snuggly between the carriage bars and keeps it perfectly centered. I then just use a couple of spring clamps on the backside of the lathe to keep it in position.
the above photo show that the cutting tip is perfectly aligned with the turning centerline height of the lathe. It also has to align perfectly with the tailstock centerline height.
Here is a ball that I cut freehand. I will try my ball cutting jig for the first time after changing the base for my next ball. The above ball was cut with a round nosed wide scraper. I got quite a nice cut with that. I will blog cutting with the jig later.
And last but not least the stuff I use for depth markers on my drills and also for marking out the turning tools. This stuff is much better than collars or masking tape!
My next blog with will be about the custom made chuck for holding the balls in various positions for drilling and turning. I hope you found something of interest here.Thanks for reading. The following links cover all the blogs in the series to date.
http://lumberjocks.com/stefang/blog/27858 #1
http://lumberjocks.com/stefang/blog/27938 #2
http://lumberjocks.com/stefang/blog/28079 #3
http://lumberjocks.com/stefang/blog/28240 #4
http://lumberjocks.com/stefang/blog/28512 #5
http://lumberjocks.com/stefang/blog/28536 #6
-- Mike, American in Norway
17 comments so far
home | projects | blog
12048 posts in 1506 days
#1 posted 473 days ago
great post here mike
i’m sure we will all learn quit a bit
glad you got to do this
at such an early age too !
Dave
9143 posts in 1005 days
#2 posted 473 days ago
Great Mike. I have an interest in the tempering of the tools. Did you heat below the cutting edge of the tool then quench? Or heat the tip slowly? Or maybe get another piece cherry, then place you tool on the edge and wait for the heat transfer?
Sorry, got off into to many questions.
Your freehand ball looks pretty dang perfect to me.
A wonderful blog Mike keep us posted.
Is that liquid paper?
86927 posts in 1742 days
#3 posted 472 days ago
Very interesting Mike can’t wait for more.
stefang
9435 posts in 1499 days
#4 posted 472 days ago
David This stuff is easy compared to what my wife makes me do. Age makes no difference to her. I suggest you revel in you bachelorhood. Today I’ve been working on our house ventilation unit. It’s a shame I will be kicking the bucket so soon with all the miscellaneous skills I’ve learned over the years!
Dave I hardened the whole thing from the body of the cutters forward to and including the curved tip. This was done by first heating to cherry red, dousing in a bucket cold water and then immediately reheating to the light blue color and then dousing again to temper it. That was it. I used a small butane/propane torch keeping the metal in the orange part of the flame for the quickest heat-up. There might be other/better ways to do this, but I don’t know about them if there is. And yes that stuff is what you call “liquid paper”
A couple of safety reminders: It is very wise to place your torch in a vise or some other secure holder and point it away from any objects before you light up. That way you can concentrate on holding the tool to the flame without the danger of toppling your torch. I used leather gloves and a vise-grip to hold the cutters with, as the whole thing gets pretty hot. Safety Glasses, a helmet, knee and shoulder pads is optional. Good luck and let me know how it went for you!
Dave
#5 posted 472 days ago
Thanks Mike and I will do.
sras
3222 posts in 1294 days
#6 posted 472 days ago
Fascinating! I know you have the book, but this looks to be a very significant challenge!
stefang
#7 posted 472 days ago
Thanks for your comments Jim and Steve. The woodworking parts including the turning is easy enough, but the metal work has been a lot more challenging for me. I did have some problems with the wooden chuck though, which I will explain in some detail in the next blog. I think the important thing for this project is to take each part of it, i.e., jig making, tool making, ball turning/preparation, and turning the balls within balls, all as separate projects. If each project succeeds, that should result in a Chinese ball. We will see. It is fun to try something new.
shipwright
3371 posts in 963 days
#8 posted 472 days ago
This is fascinating stuff Mike and you are just the man I’d expect to find doing it.
Your projects always seem a little different in a very challenging way but I do understand the lure of a challenge.
Keep up the fine work and we’ll be here watching.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
stefang
#9 posted 472 days ago
Thanks Paul. That’s because I am a challenged woodworker!
SisQMark
353 posts in 765 days
#10 posted 469 days ago
Very interesting blog Mike, I’ll be following with interest. I was a machinist for awhile and the shop I worked in used motor oil for the tempering process. It seamed to work well. Have you used this method at all? You can achieve some pretty good rockwell hardness. I’ve been interested in making knives, but stalled due to the hardening of the blades, I figured I wouldn’t do it good enough. Keep up with the blog we are all interested.
-- Don't waste today, it is yesterdays tomorrow!~SisQMark
stefang
#11 posted 469 days ago
Thanks SisQMark. I haven’t tried oil as I thought it would be too messy, but I have read that the tempering process used by professionals is much more scientific than the color method I’m using, but it works quite well for these small cutters. I have watched some knife videos showing the hardening/tempering processes, but it looks a lot more difficult and time consuming with so much more steel involved.
Roz
1567 posts in 1952 days
#12 posted 468 days ago
Over my head.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
stefang
#13 posted 468 days ago
I doubt that Terry. It is a woodturner’s thing. If you were a turner, then it wouldn’t seem difficult. It’s one of those one step at a time things. I have chosen to do this project the hard way by making all the tools. The turning tools can also just be purchased from Crown Tools.
mafe
8055 posts in 1254 days
#14 posted 466 days ago
Amazing Mike!
I will follow this one and enjoy your talents.
I have not had the time to look into the stuff about the lathe you send me, but it is not forgotten.
Big smile to you my friend,
mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
stefang
#15 posted 466 days ago
Thanks Mads. I am glad you are busy and living to the full my friend. My curious little project is going rather slowly, but I did get into the shop a little the last couple of days now that my eyes are pretty much healed. Meanwhile I am doing most of my woodworking from my easy chair!
View all comments »
