Blog entry by stefang posted 01-22-2011 11:17 PM 1788 reads 6 times favorited 23 comments Add to Favorites Watch
1
23 comments so far
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3168 days
#1 posted 01-23-2011 12:07 AM
great blog and picturebook as usual from you :-)
looking forward tothe next installment
take care
Dennis
View canadianchips's profile
canadianchips
2602 posts in 3049 days
#2 posted 01-23-2011 12:23 AM
You doing a very good job of explaining and pictures. I am very interested in hand planes, maybe one day I will try one myself.
Thanks !
View daltxguy's profile
daltxguy
1373 posts in 3966 days
#3 posted 01-23-2011 01:07 AM
Mike, thanks for this, I will scrounge for some appropriate material.
Step 9:
When sizing the opening, you use the blade and the sole. I notice your blade is already rounded. I’m assuming that if this is not the case, then you still size the opening the same way and make sure the flat end of the blade comes within 1/16” of the bottom of the sole? and if it already rounded, then you add 1/16” to the closest part of the blade to the sole? I guess this is obvious but I just wanted to make sure since many of us might not have the blade rounded yet ( since it has not been covered yet :)
-- If you can't joint it, bead it!
TopamaxSurvivor
18310 posts in 3728 days
#4 posted 01-23-2011 01:11 AM
Another awesome blog Mike! I may be an enlightened purist flip flopping as time allows ;-))
View BigTiny's profile
BigTiny
1676 posts in 2941 days
#5 posted 01-23-2011 07:12 AM
Hi Mike.
Wouldn’t it make more sense to drill the dowel holes before cutting the cheeks off the body, thus ensuring perfect alignment?
-- The nicer the nice, the higher the price!
View Houtje's profile
Houtje
311 posts in 3024 days
#6 posted 01-23-2011 08:08 AM
Hi,
That’s a great blog…
Thanks for sharing it.
daltxguy
#7 posted 01-23-2011 09:25 AM
Big Tiny – that would only work for the back half, since the front half has to be moved to create the plane opening but it sounds like a 1/2 good idea to me :)
View stefang's profile
stefang
15881 posts in 3387 days
#8 posted 01-23-2011 12:14 PM
Thanks for the supportive comments everyone. I find it difficult to be short and concise and I’m always worried about going overboad with the text part.
Steve This was an excellent question. On my test sole, I just put the tip at the 1/16” line, and this worked fine, but the front of the opening on the sole has to be reworked later (rounded) to fit the curve of the blade and to provide an even opening with enough room for the chips to come through, but still small enough to allow for fine cuts. I haven’t yet worked out a sure-fire way to do this rounding. I just took it a little at a time. I will show you how I did this in the following blog, but I admit, there must be a better and more accurate way to do this.
Big Tiny Steve is right. The front body will be shifted to the front relative to the cheek to provide a throat opening.
TopamaxSurvivor
#9 posted 01-23-2011 12:34 PM
Mike do you know the radius of the staves yet?
stefang
#10 posted 01-23-2011 01:26 PM
Hi Bob, No I haven’t worked out exact measurements yet. I have the measurements in centimeters, but I can’t convert them directly as this will lead to a lot of odd fractions of inches. However, the radius of the stave’s will be the same radius as the inside bottom.
To clarify, the bottom will have to different radii. The inner radii for the inside bottom and the outside radii which will be inserted into the groove at the bottom of the stave’s.
BigTiny
#11 posted 01-23-2011 04:29 PM
If you cut the front and back a little apart, the mouth gap is formed while keeping the alignment the same. This is the method shown in most articles I’ve read on the subject.
Not trying to be argumentative, just offering an optional method that might be a little more accurate..
stefang
#12 posted 01-23-2011 06:37 PM
True enough BigTiny, but as you can see from blog, the mouth opening is determined by a combination of plane iron projection and sole thickness. This method is easy to do without measuring and/or calculating. Drilling and putting the dowels in took about 10 minutes altogether, which I consider a reasonable amount of extra work to insure accuracy. That said, I fully realize that there is always more than one way to skin a cat.
View mafe's profile
mafe
11734 posts in 3142 days
#13 posted 01-23-2011 09:02 PM
Hi Mike,
Looking good, you have done a fantastic job on the blog here, thank you.
Few questions from me also… Sorry.
Are there any reason for the sole, cant it just be the same wood?
What about this problem we spoke of, that the moth would get more open in the sides if we did not change the layout… The plane I see in the background, is that one you allready made? Did this one show it was so little that it was not any problem?
Ok I’ll shut up… lol.
Can’t wait, to get started, always dreamed of making me a plane.
Best thoughts,
Mads
stefang
#14 posted 01-23-2011 09:35 PM
Good questions Mads. You have a plane body that includes the sole. To do this you will have to have a way of making an accurate mouth (throat from now on). Chiseling a hole out at an angle accurately and smoothly is certainly possible, but not easy unless you do it all the time.
The other alternative would be to cut the plane workpiece in half and then saw the angles and chisel out the waste between the cheeks (multiple saw cuts down to the inside cheek sides would help here). This is what I did with the smaller plane. You could then also cut the throat opening and then glue the two halves together again. I didn’t show this way, because it somewhat limits the wood you can use for the plane body, which might be suitable for the body, but not hard enough for the sole. Birch would would be a good choice for this type of construction with it’s tight grain which will work well under compression during use without wearing quickly.
I will warn you though that when I made the other plane many years ago, I had a devil of a time getting the throat opening right. In the end I just glued in a new piece in the bottom to get it rounded to somewhat match the blade. I have never built the plane in this blog, but I do think it is much easier to build it accurately, and I’m certain that will also affect it’s performance.
View Roz's profile
Roz
1699 posts in 3839 days
#15 posted 01-24-2011 05:40 PM
Great instruction, makes it all seem simple and clearly demonstrates for me how a plane works.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
showing 1 through 15 of 23 comments
