Awhile back I had to do some scroll sawing with the table tilted. I found it difficult to hold the workpiece and move it around on the tilt, so I started trying to figure a way where I could keep the table flat and still saw at an angle. That required that I would have to be able to tilt the whole saw.
I also wanted a scrollsaw table that was easily adjustable in height. This feature was important because my grandkids use the scrollsaw too, and they are still a lot shorter than me. I don’t have a lot of room in my shop, so I couldn’t use a dedicated table for this, and all my bench heights are quite high.
The idea I came up with was to use my drillpress. I mounted my scrollsaw to a piece of 3/4” thick plywood. I placed two cleats on the bottom of the plywood. The cleats just fit over the drillpress table and help to keep it on the table before clamping.
Here is how it works: I set the tilt angle on the scrollsaw table. Mine only tilts up on the right side. I then tilt the drillpress table to the same angle, but in the opposite direction (left up in my case). Next I mount the scrollsaw onto the drillpress table. The left hand cleat holds it in place while I clamp it down. The result is a level scrollsaw table which can be adjusted to whatever height you want (within reason). Of course you can also use the scrollsaw without the tilt and still use the height adjustment feature. The reason I used two cleats on the scrollsaw mount board is so that it can sit level on any level surface when detached from the drillpress.
I have been using this set-up for some time now, and I really like it. I hope you do too. The only disadvantage is that it requires a floor model drillpress, so I hope you have one. Here’s a photo of my set-up. I’m sorry I couldn’t get more into the photo, but my drillpress sits in tight space. I have my drillpress mounted on wheels so I can swing to a good position when scroll sawing.
-- Mike, American in Norway
18 comments so far
home | projects | blog
14156 posts in 1054 days
posted 20 days ago
where there’s a will, there’s a way. Very creative thinking.
degoose
1986 posts in 248 days
posted 20 days ago
First David and now you Mike.. looking outside the box to use tools in a different way successfully.
stefang
1645 posts in 227 days
posted 20 days ago
Thanks for the nice comment Debbie. Hey Larry, I am forced to use the tools I have, because there isn’t any more room in my shop! If I had the space and the money, I sure would like to have one of your wee beasties.
16683 posts in 470 days
posted 20 days ago
Slick Idea Mike thanks
Timbo
282 posts in 458 days
posted 20 days ago
Good one Mike, I would not have thought of that. I think this can come in handy, Thanks.
-- Tim: Remember, if it doesn't say Binford, someone else made it.
toyguy
715 posts in 730 days
posted 20 days ago
Mission acomplished….. That’s the way to think outside of the box.
” A tip of the Hat to you sir”
nmkidd
381 posts in 66 days
posted 20 days ago
Great idea Mike. In terms of Twinkies…..how many Twinkies and coffees did it take to conjure this one up?
I’d still be chomping away!
-- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke!
TopamaxSurvivor
3014 posts in 569 days
posted 20 days ago
Great idea Mike!! Glad to see you haven’t lost your Yankee ingenuity in Norway :-))
Jim Bertelson
264 posts in 57 days
posted 20 days ago
Gad Zooks Mike…...that is clever. No I don’t have a floor mounted drill press, but that idea will stick in my brain.
That is straight out of the blue….............
-- Jim, Anchorage Alaska
littlecope
582 posts in 395 days
posted 20 days ago
That’s a wild idea, Mike! I do as few angled cuts with the scroll saw as possible, because of their difficulty. It’s a situation where my intuition blatantly lies to me! Feeding the wood the way my mind and eyes are telling me to doesn’t work on a tilted table… That set-up looks like it eliminates the problem! Smart Thinking!!
-- Mike in Manchester, NH---Unpleasant tasks are simply worthy challenges to improve skills.
stefang
posted 20 days ago
Thanks for all the flattering comments. I will show them to my wife to prove to her that I’m smarter than she thinks (or knows?)
My inspiration was not ingenuity or even twinkies, it was sheer desperation plus you have a lot of time on your hands when you are retired to think up little solutions to little problems. I’m still working on how to keep my wife happy and still spend a lot of time in the shop! Any suggestions?
2376 posts in 234 days
posted 19 days ago
good idea , mike .
i don’t have a floor drill either ,
but your idea opens new possibilities .
you could always pay her to be your apprentice ? (LOL)
Jim Bertelson
posted 19 days ago
Keep your wife happy while spending a lot of time in the shop…......let’s see:
You could invite her to clean your shop while you are working in it, just for togetherness…......
You could have her budget your hobby costs, perhaps at a computer center you built, just for her…....
You could make new broom and mop handles that are real fancy, justifying your shop time…......
You could install an intercom that broadcasts all the shop noises throughout the house, so she would feel part of the action….......
You could install a vent into the house, so that she could share in the beautiful aromas and ambience of wood dust, saw smoke, paint fumes, and the soft romantic haze of sawdust in the air…......
Think that might help?
notottoman
449 posts in 123 days
posted 19 days ago
Mmmmm.
Gives me many ideas…....
Thanks
-- "Even small steps makes a distance." (Shawn Phillips, musician)
stefang
posted 19 days ago
Thanks for the suggestions guys, but I think I will have stick to house chores for the time being. I did get into the shop for few hours today. I am currently working on a little project and I had planned to finish it today, but everything I did was wrong. In 3-1/2 hours I managed to mess everything up that I did. If I were doing this for pay I’m sure I would have been fired. Guess I’ll have to give it another go tomorrow.
Jim Bertelson
posted 19 days ago
Working hard this week, so not much time for the shop. Did get in about 30 minutes this morning. The switch is coming along nicely, and I haven’t screwed it up yet…yet….......yet….............yet….....
TopamaxSurvivor
posted 19 days ago
Hope it works better for you tomorrow. The great thing about LJs is we won’t fire you Mike ;-))
stefang
posted 19 days ago
Thanks Bob, that is comforting.
