New Method Open Segment Turning Construction
Blog entry by stefang posted 1345 days ago 7130 reads 13 times favorited 21 comments Add to Favorites Watch
Hi folks, here is the blog I promised which describes my new method of open segment construction. Before I begin, let me just say that this project is my first normal open segmented construction. I am not an expert or even experienced with open segment construction and turning. This is more of a woodworking journey to tell about my experience than a tutorial.. I hope you will join me and enjoy yourselves. I warn you though, it’s lengthy, so I hope you have the time to stay with.
What is it all about?
I had been looking at some open segment turning websites and after having tried regular segment turning I wanted to try the open type too. The only problem was that after looking at the websites it looked like I would need a lot of special equipment to do it, which was either shop-made or purchased. This equipment included the following items:
1. Indexing wheel for my lathe: fairly easy to make
2. Drum sander: I didn’t have room for one, didn’t want to make it and couldn’t afford to buy one
3. Segment gluing jig: Could make one, but takes space and time to make
Ok, it looked like I was finished before I started, but I began thinking how wonderful it would be if I could just glue it up into rings like the regular segment construction. Then I started thinking about how this could done, and to make a long story short, I came up with the solution pictured below. This blog will describe how I managed to construct these rings and still stay true to the “normal” construction result without needing any of the above mentioned special equipment. For some of you this picture will be enough of an explanation. Others might want to see the steps I went through to make them. The solution was to make a ring using spacers which would be turned off while shaping the vessel. Here was the goal as pictured below. An open segment ring glued into a ring using temporary spacers as shown below.
what are the advantages to the ring construction?
- You don’t need perfectly sized segments (talking about height only here) because you can flat sand the ring on the glue-up side with a disc sander and then turn and sand the other side flat after it has been mounted on the lathe.
- You can construct rings from thick materials and then split them into two or more rings to make more than one work piece. This at least effectively almost halves your construction work. It doesn’t take much time to saw a ring in half.
- The lathe isn’t tied-up during construction as in the “normal method” and it would be easy to share the work with another person. One cutting and sanding segments and the other gluing-up for example.
Summary of the whole process;
1. Prepare segment stock
2. Cut segments
3. Sand segments in sanding jig
4. Prepare spacer stock
5. Cut spacers into segments
6. Cut spacers from spacer segments
7. Glue-up rings
8. Flatten one face of each ring on disk sander
8. Glue rings onto work piece. Use the sanded side for the glue joint
9. Turn and flat sand the the top of the ring to prepare it for gluing to the next ring.
A List of things you will need
1. A lathe ( I’ll bet you knew that)
2. A disk sander to dimension your individual segments with. A 6” disk sander work fine for this.
3. Another disk sander with a little larger diameter than the diameter of the the largest ring you will be making. I made a 12” one that mounts on my lathe and which equals the swing of my lathe. This is used to flatten one face of each ring
4. A tablesaw, mitersaw, or bandsaw. If you use a bandsaw, you will have to do more segment sanding.
5. A segment cutting jig for the tablesaw or something like Tibbett’s mitersaw set-up which I use, or a bandsaw jigof some kind. Sorry, don’t have a reference for that one, but would me similar to a tablesaw jig.
6. A segment turning computer program. This will give you detail drawings of the rings and stock dimensions for each ring. You can mark your stock right off the drawings, and check the actual cuts the same way. Not an absolute must if you can and are willing to figure everything out on your own. (very time consuming).
7. I recommend you buy a segment turning how-to book. I have Malcom Tibbett’s book “The Art of Segmented woodturning. This book doesn’t cover the open segment method, but it is packed with how to info which you will find very useful. It might also be interesting to buy Smith’s book on open segment work. He is at Smith Art on the web, although you won’t need it for this method. Also it would allow you to compare the two different methods in order to weight the merits of each. I’m sure I will be buying this book soon for that reason.
The following text and pictures mainly describes the process of producing the rings. The first photo shows the stock I prepared by cutting the ring widths described on my segment computer program. You don’t absolutely need one, but it sure makes life easier and they are relatively cheap. Just pay for it and download it from the web. My stock was just pine used to experiment with (again!)
Here I am cutting the segments on my miter saw using the Malcom Tibbetts set-up .
I found that it was more efficient to cut all the segments for all the rings at the same time. I then put the segments into recycled sour cream containers, one for each ring. I cut a piece of sandpaper into strips (durable) and wrote the ring no. on each, and then I put the ring numbers into the appropriate containers with their segments. Organization is important for me as I get easily confused. What were we talking about? Oh yeh, here’s a picture of them organized.
The next job is sanding the segments in my Malcom Tibbetts designed sanding jig. The segments won’t be glued together but they will be joined by spacers, so accurate sizing is essential here in order to get the ring round as possible and with the right diameter. Also the inside edges need to look smooth and nice.
Ok, now it’s time to prepare the spacers which will be glued into the ring. In order for the the permanent segments to be positioned correctly you need to have to have spacers that will maintain that thin pie shaped space between the segments, In these rings I have used 30% space to 70% segment length.
The spacers on the outboard and inboard sides of the ring must be exactly the width of the space between your segments as specified by your computer program. My program only tells me the length of the opening on the outer side of the ring. But if you cut it at the correct angle it will be the right width on the inside edge too.
In order to meet the above criteria, I performed the following steps:
1. Cut the spacer segments based on the width of the ring (outside edge to inside edge of ring). The resulting spacer should just fill the space on your ring printout. Make sure you have marked the two top edges on your stock with a very thin line. This line will tell you which way to place your spacers. The wider spacers used on the outer edge of the ring will have the blue line facing outwards, and the narrow spacer inwards towards the center of the ring. This is important because the spacers are angled on the long-grain glue joints.
2. Cut the actual spacers from the spacer segment wdges. I made a simple bandsaw jig to insure accuracy, speed and safety. Here are some photos of the process. You have to cut both sides along the blue lines.
Spacer width setting on tablesaw based on the segments they will be glued to.
cutting spacer stock. Before cutting these segments you will need to know the the length of the opening between the the permanent segments. Do not confuse with stock width. The length runs around the circumference.
Finished spacer stock with outside edges marked
Spacer segments are cut with the grain. Make sure they are of uniform and the sides as close to vertical as possible. Perfect would be good. If they are not vertical it will affect the accuracy of the ring glue-up.
Spacers placed in the bandsaw cutting jig in the same order they were cut on the mitersaw, that is: wide-end, narrow-end, and so on in order to make them rectangular for putting through with the jig.
16 spacers from the first cut
16 spacers from the second cut
“Making !the second cut after turning the stack around to cut along the other blue line for the
You now have 32 spacers, 16 wide ones and 16 narrow ones. All the spacers are then sorted by size. The wide ones for the outer edge of the ring and the small ones for the inside edge of the ring ready for glue-up.
Glue-up process
1. The ring segments have to be have to be de-burred after sanding. It pays to do a good job on this because burrs will tilt your segment to a wrong angle as you glue up and also might prevent the glue joint from being being tight. I do not de-burr the spacers as these are cut as long-grain glue-jointed segments. I do the de-burring on a sanding board as shown below.
2. Starting the glue up. All rub joints, first two, then combining the twos to fours.
This last picture shows that I have glued spacers onto the same end of each the 4 segments sections(make sure the spacers are glued onto the same end of each spacer). I did this after letting the 4 section glue-up set for a few minutes. After gluing the spacers onto the ends, I let them dry for an hour or so and then I sanded those spacers with the segments laying flat on the sanding table on my sanding disk as necessary to make whatever adjustments were needed to insure that the rings were as round as possible and to get good enough glue joints with the permanent segments to insure strength for turning.
Here I have applied glue and put a steel hose clamp around it to dry for an hour or so. Another new ring is born!
Let’s see if it is in accordance with the computer image printed from my segment program. Eureka! It fits.
NowI am finished making the rings. I could have made one nice vessel out of these rings as they are, but I wanted two for all my work, so I doubled the number of rings by splitting them in half with my Japanese handsaw. It took not more that 3 or 4 minutes for each one. I held them clamped between the movable tops in my Work Mate folding bench. I took my time and cut very carefully. You don’t want a ring that took 1-1/2 hours to make destroyed in just a few seconds!
Here are the two work pieces resulting from splitting the rings.
Next, I disk sanded one side of each ring flat on my lathe mounted sanding disc.
The other side of each ring will be trued up after being glued to the workpiece and mounted on the lathe. After that the next ring with one side pre-sanded flat side will be glued on to the ring and so on. Here are the rings being glued on, etc.
Here I have begun turning to get top ring flat and ready to glue the next ring on.
Captain Hook enters perilous waters!
The still unfinished result. But I did get the blog out there.
Before I go, I would just like to thank you for reading this. I hope it was a little interesting if not useful. I am not claiming this is a better method, because I have never done the usual method and so can’t compare. This is pioneer work. I’m sure a lot of improvements could and will be made. Especially if you LJ’ers help out.
I hope that those of you who are knowledgeable about this kind of work will join in and discuss the pros and cons of the method and the process. I’m not even sure if I am the first person to have done open segment construction this way, so if you have already been doing this let us hear from you. I hope there will be a good discussion, about this, especially with us turners.
I probably left a lot of questions unanswered but please don’t hesitate to contact me either on the blog comments or a PM. and I will be happy to answer you.
-- Mike, American in Norway
21 comments so far
View degoose's profile
degoose
6618 posts in 1551 days
#1 posted 1345 days ago
You have worked really hard to make this a very well presented and photographed blog.. well done..
I can see now how this in done.
-- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber...
View stefang's profile
stefang
9725 posts in 1531 days
#2 posted 1345 days ago
Thanks a lot Larry I appreciate your supportive comment. I have been doing some editing while you have been reading it. But not much changed. I had hope to do a much better job on this, but reality caught up with me.
View lew's profile
lew
9035 posts in 1952 days
#3 posted 1345 days ago
Super Job, Mike!
Your steps are easy to follow and really well thought out and documented.
Thanks for taking the time to show us how it is done.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View dustbunny's profile
dustbunny
1149 posts in 1492 days
#4 posted 1345 days ago
Mike,
Excellent blog, and ingenious method for open seg turning. I would try this, but I have a fear the whole piece would explode in my face. Have you had any problems turning these?
Thank you for sharing your method, best wishes to your wife with her recovery.
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
View darryl's profile
darryl
1789 posts in 2523 days
#5 posted 1345 days ago
that’s an interesting technique, thanks for sharing.
I’ll have to give this a try.
View cabinetmaster's profile
cabinetmaster
10874 posts in 1755 days
#6 posted 1345 days ago
Nice job on the blog and the technique. I may have to give this a try after I turn a couple more segmented bowls.
View woodworm's profile
woodworm
14105 posts in 1787 days
#7 posted 1345 days ago
Neat work. I should learn to be very patient like you.
Thanks for sharing.
-- masrol, kuala lumpur, MY.
View Loucarb's profile
Loucarb
2388 posts in 1642 days
#8 posted 1345 days ago
Wow. How did you ever come up with that process. I have a hard enough time with a simple bowl. Amazing blog great detail,thanks for sharing your hard work. It was very interesting.
89049 posts in 1774 days
#9 posted 1345 days ago
Hey Mike
This is a great blog and a fantastic technique most amazing.
View Hix's profile
Hix
161 posts in 1475 days
#10 posted 1345 days ago
Great tutorial. I have experimented with different trys at open segmented turning without your success. I will give it a try!
-- ---call me---- Mark
View tomd's profile
tomd
1336 posts in 1967 days
#11 posted 1344 days ago
Thanks for the tutorial, all the pictures made it very informative.
-- Tom D
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 1787 days
#12 posted 1344 days ago
very neat blog. Thanks for sharing
stefang
#13 posted 1344 days ago
Thanks everyone for the positive comments. If you try it, please let me know how it came out.
Dustbunny You shouldn’t be afraid of these constructions. They are amazingly strong. To be honest, I did have a problem because my faceplate came a little loose on one side due to a screw being stripped and I didn’t notice it. This threw my workpiece off-balance and here is what happened. I was trading the faceplate between both work pieces. I won’t do this again and I’m sorry I used a faceplate because I have a really neat 4 jaw chuck for this kind of work. This was the result:
However, I was able to reglue it with no problem. The safest way to turn these is to use two glue blocks, one for the bottom and one for the top. This way you can turn the inside smooth and from both ends and the join them at the center. A good idea to make sure the diameter is the same on both ends where they meet. You can rough turn the outside at the same time to give you the shape you are after and then finish turning it after gluing the two halves together. I have to admit that it’s stressful turning these with the hook tool, but it does work ok. Next time I turn one of these I am going to use the two piece method. I you do that I guarantee you won’t have any issues with it. The strength in the glue-up is between the rings which is long-grain. I found that when turning the insides while still open in a bowl-like configuration that you can just use the tip of your bowl gouge on the edges of the ring until they flatten out with absolutely no problem. After that you can use a round nosed scraper with a sharp cutting edge to finish up with taking light cuts.The outside is turned just as any other vessel, just not too aggressively.
stefang
#14 posted 1344 days ago
Woodworm Just a work about being patient to do this work. There are very few people doing open segmented turning today. These vessels take about a week of work unless you split the rings as I have to get two vessels for the work of one. However, when completed you have a fairly rare object that most turners are unable to produce. So maybe the time and trouble is worth the effort?
Also I would like to say that I found the work to be varied and enjoyable. Sitting down and gluing was a nice break from the cutting and sanding. Each ring took a total of about one and a half hours total time to construct.That includes stock preparation, cutting sanding and gluing.
Another point here is that very large rings can be constructed just as fast as the small ones. So maybe you get more for your time with larger turnings than small ones.
View Kindlingmaker's profile
Kindlingmaker
2650 posts in 1723 days
#15 posted 1344 days ago
Fantastic series! Thank you!
