I thought I better post some pictures of my real workshop in case anyone thought I just had drawings. If you’ve been in on my home page work shop the following is what you saw. I put the overview in here so you could make sense of my detailed photos which follow. The shop is 220 sq. ft. and was a carport attached to the garage with a small workshop running across the back of the garage. The loft spans the garage and the workshop which is about 550 sq. ft. It’s all insulated and paneled in pine. I plan to make it into a finishing center eventually.
This is my bandsaw and drillpress right across from the lathe. It’s pretty close, but works just fine. I often use the drillpress table as an outfeed table for the bandsaw since it is adjustable in height. Pretty handy. The drillpress is mounted on wheels like most everything else in my shop
This next one is clamp storage next to my sliding beams bench. Those new type Irwing clamps are really great!
Here is my electric handtool storage. The drawers house glue gun and supplies, soldering iron, handrill accessories, etc.
This is clamp storage on the opposite wall at the other end of the beam bench.
My 30 year old cabinet makers bench made by the Swedish manufacturer Sjøberg. You can also see my Delta band/disk sander with a sanding jig for precise sanding of segments to be glued up for turning.
This is what you see coming in the entrance door. Left is platter storage. First right is my shop-made router bench and just beyond that my 5 function combination woodworking machine. It has a tablesaw, shaper, jointer, planer and mortising attachment. A cheap version of similar machines, but good enough for me.
My newest tool acquistion. A Woodfast 12” disk sander. I’ll be using it for my segment turning. It’s a great tool and I will no doubt find a lot of other uses for it as well.
Opposite view looking towards the entry door. Stacked against the wall at the end is the garden bench components constructed so far and which I hope to finish soon. Remember my Garden Bench blog #1 before summer? Well, I’m not very fast or productive. Lazy Larry will be ashamed of me!
This is the sliding miter saw my wife gave me for Christmas last year. I love it! It’s mounted on a sliding torsion box so I can slide it out of the way when I’m not using it. As you can see I have a very narrow shop. Please note the round thingies on the dust hood. One on top and on each side. These are vacuum hose holes with removable plugs. This way I can put a hose in whichever way the saw is pointing.
This shows the SMS pushed in (it does go in all the way). My 2000W 2 motor 50 Gal. drum vacuum is tucked under the counter in it’s own place.
Here is my sharpening center and grinder equipped with a Veritas grinder jig which is very useful. I also have a Veritas honing jig, but since I’ve learned to hone by hand I don’t use it much. The scrollsaw is stored at the left. It’s mounted on a table with a cleat that’s for mounting to my drillpress table. I first tilt the scrollsaw table to the desired angle and then I tilt the drillpress table until the saw table is level. Makes it a lot easier to control angled cuts. The first original idea I’ve had since 1947.
The next two photos are near identical pictures of my sliding beams bench (yes there are two of them). I love this bench. There isn’t anything I can’t clamp for gluing-up. hand planing or anything else. It beats the heck out of my cabinet makers bench. I also have a 50 ltr. compressor under the bench.
This is my Record 1/2 hp 3 speed lathe. It has a swing of 12” over the rails and 16” using the extended tool holder attachment and with the headstock swung 90 degrees to the the right. Not a particularly hefty or even
good lathe, but extremely reliable. I’ve had it for 13 years now and never had a single problem with it, or replaced any belts or parts.
Another lathe view which shows my turning chisels and accessory storage. I’ve made a dust catcher from an office lamp shad which attaches to the vacuum hose. You can just see it at the right under the rails.
One thing I didn’t mention above is that the counter tops, electric tool storage top, combi machine and router cabinet all are the same height. This comes in real handy to support long pieces.
I hope you enjoyed the look see. I figured that it’s so seldom cleaned up that I wanted to take advantage of it while I could. Also when folks come visiting and they ask to see the shop, I can just show them the photos if it isn’t presentable at the time.
Thanks for looking in
-- Mike, American in Norway
25 comments so far
woodisit
home | projects | blog
61 posts in 135 days
posted 63 days ago
Well thought out, very nice shop!!!!!
-- Woodisit
PurpLev
2745 posts in 542 days
posted 63 days ago
very nice and organized well!
gator9t9
295 posts in 598 days
posted 63 days ago
Nice very nice shop …...thanks for posting
mike
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
dustyal
444 posts in 369 days
posted 63 days ago
okay, I’m more than a bit jealous… so I must find fault… the stairway does not have a hand rail!
So there. Not perfect, but you are getting mighty close. Well done.
Sliding beam benches. Very interesting. Question: Do they float on the wall support beams? They can be lifted up in addition to slide along? Hope I am understanding that right. Wish I would have thought of that when I was making up my little shop space. But it is not too late to rethink it… and upgrade…
aren’t all shops a work in progress?
-- Al H. - small shop, small projects...
Moai
721 posts in 287 days
posted 63 days ago
Lots of pics and lots of nice stuff….......that’s a nice place!
-- Francisco Luna, San Francisco Bay Area.
NBeener
373 posts in 67 days
posted 63 days ago
Wow. What a beautiful, organized, and totally functional shop! Well done, Good Sir. Well done!
Quick questions:
- what’s upstairs (inquiring minds….)??
- what’s the total square feet on the ground floor?
I was telling my brother, last night, that I was trying to get every table/bench top to be the same height—ideally, the height of my TS. I just think that’s a nice feature, if you can manage it. You managed it :-)
“I know it’s a long blog, but please don’t feel you have to look if you’re not interested.”
Yeah. Pry me away from your pics :-)
-- -- Neil
charlie48
42 posts in 63 days
posted 63 days ago
Very nice shop!..................thanks for the pics
-- Only time will tell if it was time well spent
stefang
1646 posts in 228 days
posted 63 days ago
Thanks everyone for the nice comments.
AL There are three reasons for not having a handrail. Firstly, it discourages the wife from nosing around up there. Secondly there’s a lot of stuff stored up there that I couldn’t get down if there were a handrail, and thirdly, there is a very large trap door at the top of the stairs which closes off the loft to prevent too much dust migration and which does not allow a proper handrail to be installed. You are however, absolutely correct from a safety standpoint, and I do appreciate your concern. My wife is nagging me about it all the time. I just say “yes dear”. Hope I don’t live to regret my poor attitude.
You are correct, the sliding beams just sit on the sliders mounted to the wall and can be lifted upwards as well. Did you notice the lower sliders? That’s for mounting the beams at a lower position for grandchildren or working on something tall like a chest of drawers. A little warning here: The beams tend to easily rack when being moved, so a guidance system to prevent this would be an advantage (but not a necessity).
Yes, you are right. Shops change constantly as the type of work and storage changes and when experience and frustration motivate better ideas. There is no such thing as the ultimate shop. For example; I used to hate that my shop was so small, but now at my age I’m glad I don’t have to walk so much.
dbhost
608 posts in 125 days
posted 63 days ago
Very nice… It would be nice to folks that browse the Workshops to update your workshop page with this info as well…
-- Trying to follow the example of the master.
stefang
posted 63 days ago
NBeener Upstairs is a lot of “stuff” including paint storage, xmas decorations bit and pieces of odds and ends. However there are a couple of interesting things too. I have a professional drafting table (all we need now is a professional draftsman) and a shopmade light table. My plans for the future are to make the loft into a finishing center. A couple of years ago I insulated and paneled the ceiling and 30” high walls with knotty pine. The floor was already insulated as is the entire shop. I have a lot of plans, but at my age I’m not sure if I will be able to realize them all.
The shop is 220 sq. ft. total.
degoose
1993 posts in 248 days
posted 63 days ago
I just love looking at other folks shops and yours is a doosy.. not small just compact and you have it organised quite well.
Enjoy.
Kent Shepherd
813 posts in 180 days
posted 63 days ago
Mike, Great looking shop. We look forward to seeing a lot more fantastic projects.
stefang
posted 63 days ago
Thanks Larry. I like to look at other folks shops too. Are we nuts?
stefang
posted 63 days ago
Thanks Kent. It’s certainly not beautiful, but is fairly functional.
Blake
2754 posts in 768 days
posted 62 days ago
Cool shop! Thanks for the tour.
16714 posts in 471 days
posted 62 days ago
He Mike
This is a fabulous shop well thought out and layed out it shows a bright mind and a creative aproach.exactly what I would expect of your shop so nice.
Mike
140 posts in 276 days
posted 62 days ago
This is a great shop! Great layout.
-- Mike, VT
oldwoodman
98 posts in 291 days
posted 62 days ago
Mike,
I love to see how other woodworkers have organized their workspace. I have gotten some great ideas on how to use the workspace efficiently. You have done a great job in organizing your shop.
Thank you for taking the time to post your pictures and write your commentary.
stefang
posted 62 days ago
Thanks again everybody for the kudos. The shop has sort of evolved the way it has out of necessity rather than clever planning because I have so many (mostly second rate) tools to accommodate.
Whenever I begin to envy others their tools or shops, I think about craftsmen present and past who have made things I would never be capable of with the the bare minimum of hand tools and in a small space that couldn’t even be called a shop. Then I realize how lucky I really am and it reminds me that it is the skill and not the tools or shop that make a craftsman.
2379 posts in 235 days
posted 62 days ago
mike ,
when i first saw your sketch-up ,
i new there was a mind at work ,
your pic’s prove me right .
your shop is as sharp as your turning tools !
well done !
stefang
posted 62 days ago
Thanks David. I just wish I could spend more time in it to actually make something!
TopamaxSurvivor
3014 posts in 569 days
posted 62 days ago
Looks like you have it all and very well organized mike ;-)) No wonder you turn out such nice work !!
stefang
posted 61 days ago
Thanks Bob. I am going to try to do some nice work. I’m really excited about this segment turning thing after doing those test pieces and really enjoying the process. I hope you will try it too because it is fun. Yesterday I started making a sanding jig for my new 12” disk sander. As soon as that’s finished I will be making one more pine open segment vessel for a blog to show my different approach to this type of construction. It will be like the blind leading the blind, as I haven’t use the normal method yet. and I have only done one open segment so far. How’s that for overconfidence? Well, it takes all kinds I guess.
I wondered how you were coming along with your turning and if you liked your new lathe?
Kristoffer
88 posts in 109 days
posted 61 days ago
I am also more than a bit jealous! An absolutely amazing use of space! I hope that you get to spend a little more time in your shop, and soon.
I’ve gotta say, you’ve changed the way I look at life….. I’ve always known three certainties – The sky is blue, water is wet and you can never have too many clamps. Well, two out of three isn’t bad.
-- Cheers and God Bless
TopamaxSurvivor
posted 59 days ago
Mike, Too many irons in the fire, don’t have a place to set it up yet :-(( Running and shooitng rifle match last weekend. Had volunteer training last week too. I sure seem to be busy for not having much to do ;-)) Problem is my shop is too full oif personal stuff plus business stuff plus wife stuff…..... Went to dam break/flood control meeting last night. We don’t live in jeapordy, but the wife works there. I’m getting my match results out for the season and working on next year’s schedules today. Got to get set up to shot a 100 shot offhand rimfire match Sat…......... To many interests!!
