Fried planer:/
Blog entry by shelly_b posted 02-10-2013 06:46 PM 1510 reads 0 times favorited 22 comments Add to Favorites Watch
So
22 comments so far
View JJohnston's profile
JJohnston
1622 posts in 3168 days
#1 posted 02-10-2013 07:05 PM
They do have these things called “locks”.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Dallas's profile
Dallas
3599 posts in 2364 days
#2 posted 02-10-2013 07:07 PM
No problem shelly_b, you can temporarily replace the switch with a toggle if you need to and use it until you order a new switch from eReplacements.com
I had someone set a bag of frozen tomato sauce on my aluminum table saw wing. It was there fro about two weeks in a cardboard box and I didn’t have any time in the shop.
When I found it the juice had leaked out of the bag, through the box and ate about a 1/16” of my wing.
No one will own up to who did the deed, but there are only two of us and five kitties with access and the kitties don’t like tomatoes.
View shelly_b's profile
shelly_b
850 posts in 1994 days
#3 posted 02-10-2013 07:08 PM
My side just happens to have the man door and garage door, so no way to get in without going through my shop…
shelly_b
#4 posted 02-10-2013 07:09 PM
lol thanks dallas. I will have to look into getting a new switch. I was thinking it fried the motor the way it was smoking
Dallas
#5 posted 02-10-2013 07:20 PM
Test the motor, but I doubt there is anything wrong with it.
What model planer is it?
shelly_b
#6 posted 02-10-2013 07:24 PM
Im not sure the number, I’m at work right now. Delta 12in bench top planer
View Handtooler's profile
Handtooler
1493 posts in 2009 days
#7 posted 02-10-2013 07:25 PM
Shelly, And, Delta can probably instruct or advise, if necessary, on how to most easily replace that switch. Even be a source of supply. Of course have the model and S/N handy.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View JoeinGa's profile
JoeinGa
7733 posts in 1884 days
#8 posted 02-10-2013 07:43 PM
If the smoke was coming out around the switch, I’ll bet it was the blood smoking and NOT the planer motor. If anything it MIGHT have been the switch throwing the smoke, but I’d be betting the planer itself is fine.
You may hafta open ‘er up (using your Nurse/SURGEON SKILLZ) to replace the switch, but from what you’ve posted in the past I dont think this job is too big for you.
Hey, you were gonna do a Googley search to learn how to hook up 220! So how hard can it be to swap out one little swicth?
C’mon girl, use those mad skillz you got. You can do this!
13594 posts in 3218 days
#9 posted 02-10-2013 07:43 PM
might want to text him on twitter
or comment to FB on his page
might be the only thing he will understand
get him to buy the switch
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3100 days
#10 posted 02-10-2013 08:13 PM
Shelly,
I have use eReplacements.com for all my tools parts needs great service.
-- Andrew, Ohio https://www.etsy.com/shop/AndrewBetschman
View ajosephg's profile
ajosephg
1880 posts in 3438 days
#11 posted 02-10-2013 08:17 PM
He need punishment.
1. Place his hand in the planer and lower it until the hand is securely squeezed.
2. Plug planer in with switch off.
3. If nothing happens all is forgiven
4. If the planer turns on, he got what he deserved.
-- Joe
shelly_b
#12 posted 02-10-2013 08:23 PM
lol joe-i did look up how to wire a 220 and it doesn’t look bad at all. i have to go get some wire from his dad to make an extension cord b/c we will be running his welder off of it also. so we will have one outlet and 2 extension cords b/c each machine takes a different plug. we won’t be running them at the same time anyway.
shelly_b
#13 posted 02-10-2013 08:25 PM
haha he does need punishment joe…i guess if he doesn’t have hands then he can’t ruin any more of my things right? lol i mean, i would think common sense would tell you if i don’t want it on my bench, then i REALLY don’t want it on my power tools lol. but it was in the off position when it turned itself on, so i’m pretty sure it would come on!
shelly_b
#14 posted 02-10-2013 08:27 PM
david-he actually doesn’t do FB or twitter…i need to invent a talking beer can, maybe that would work! one that i can record msgs into…
Dallas
#15 posted 02-10-2013 08:48 PM
Cheaper method than two cords….. change the plug on one cord to match the other, then only one cord needed.
showing 1 through 15 of 22 comments
