Well my first problem is to over come the chip out. I am building the tops first and this is what it will look like if all my lines and splines square and true. The real problem here is I am getting a lot of chip out (not snipe) when I run the boards through the planer. These are very sharp blades! I think the problem is that the wood is Makore and very, very quilted. I have both tops glued up to about 24” X 17” just a bit over 1/2” thick. The outside will be Maple and after looking at it I may do the maple all the way around. Oh, and it will be tiger maple, as well defined as I can find. I guess I need some feed back on the wood of choice? I don’t want it to make to loud of a statement and I’m a little concerned about the Quilted Makore. It almost looks like 3D even with no finish. Kind of like the dashboard in a caddy. picture of wood Here’s a photo of the makore. The only thing I can come up with is to bring the top to a shop that has a wide belt sander and have it rough sanded just to level it and get it to a more uniform thickness.
Any one have any ideas or feed back?
-- Sell it here> http://woodworkerslist.com
12 comments so far
ChicoWoodnut
home | projects | blog
894 posts in 694 days
posted 205 days ago
I have never had any luck running figured wood through the planer or jointer. The best I have come up with is planing it close and then using a sander or scraper to bring the surface down. I have done this on figured maple. The birdseyes will pop out if you try to plane them leaving little pecky holes where the birdseyes were.
sandhill
608 posts in 803 days
posted 205 days ago
That’s exactly whats happening. I guess I will see what a cabinet shop wants to run it
25279 posts in 1279 days
posted 205 days ago
I’ve jad some great luck with the spiral head on my planer and jointer. I’ve never had any chipout. I planes some burly, tiger maple from roughsawn to smothness on both sides by only taking 1/16” per side.
sandhill
posted 205 days ago
I thought about making a conversion to my 20” Grizzly but its not cheep. Do they cut at more of an angle instead of straight on? Kind of slicing?
Jeremy
50 posts in 209 days
posted 204 days ago
Judging by your tag, “I need more tools” why not buy a drum sander? :-) This way you could avoid chip out all together…Just a thought!
-- Jeremy, Rochester, NY
sandhill
posted 204 days ago
Wish I could afford one. Retired also means broke in my case… It seem like something is always coming up that takes the few extra dollars I am able to raise. Nice Thought though.
Jeremy
posted 204 days ago
Don’t feel bad, I’m working and still feel like that! HAHA!
Douglas Bordner
3415 posts in 942 days
posted 204 days ago
I have moistened the wood with Mineral Spirits about five minutes before jointing or planing with some success. I generally plan on being a very healthy 1/8˝ over project thickness. And I am happy to have taken the plunge on a 10-20 open-end drum sander for final dimensioning.
sandhill
posted 204 days ago
I sure would like to get one of them for my shop. The one I want is about $1800.00. I all most got one for $650.00 like new but was to late. Maybe someone will list on on the woodworkerslist web site and I will be first to see it and call.
sandhill
posted 193 days ago
I have decided to buy a flat belt sander when I see one I can afford.
PurpLev
2675 posts in 527 days
posted 193 days ago
mmmm, just a thought- what about using a handplane for final dimensioning and smoothing out the surface?
sandhill
posted 193 days ago
All I have are smaller planes nothing that could do a large surface. Great idea though. I have the boards glued up and put away till the time comes I can do what I need. I went to a few shops and one wanted $50.00 per top and the other said flat out NO.
