Got me a Pot #1: eBay score
Blog entry by sandhill posted 05-09-2013 12:14 AM 1317 reads 0 times favorited 5 comments Add to Favorites Watch
no previous part Part 1 of Got me a Pot series no next part
I have been looking for a glue pot for some time now and finally found one so this post is a two questions: I think the pot was painted, so how do I burn off the paint and Part two is: Can I use it with it being painted? I got it for a reasonable price so if I cant use it for Glue it would make a nice display. It holds 2 cups and is a double boiler.
5 comments so far
View rustynails's profile
731 posts in 2465 days
#1 posted 05-09-2013 12:44 AM
Not sure if you can use it with the paint? But if not you could use paint stripper or if you have access to a sand blaster that would work as well.
View mcgyver's profile
56 posts in 1807 days
#2 posted 05-09-2013 02:24 AM
don’t know if paint would flake off in glue. if its made of cast iron just heat it evenly an burn paint off have done it with cast iron cookware. just build a fire and put it in. LET IT COOL SLOWLY! it will crack if not. you can put it in oven on 500f but it will stink up the house if you are married your wife may want to kill you. warning given! after it is burnt and cooled wash it with scrub pad and soapy water to get rid of the soot.
-- Mcgyver
View Mathew Nedeljko's profile
Mathew Nedeljko
715 posts in 3765 days
#3 posted 05-09-2013 05:03 AM
Bob, you only need to heat the glue to 145 deg F so no need to try to burn off the paint. I would go ahead and just use it the way it is and see what happens. The only place where I would pay close attention is to the surface that comes in contact with the glue. If you suspect that your glue is being contaminated you might want to strip the paint off the inside of the inner pot, but otherwise, the paint should be able to withstand the heat no problem.
-- Aim high. Ride easy. Trust God. Neale Donald Walsch
View JoeinGa's profile
7733 posts in 1943 days
#4 posted 05-09-2013 11:20 AM
I didn’t think you could buy POT on Ebay!
Oh wait. You mean THAT kind of POT!
OKay, never mind then LOL
View sandhill's profile
2128 posts in 3860 days
#5 posted 05-09-2013 02:35 PM
I gues we can give it a try and see if its OK. Thanks guys
