Table Saw Cabinet with router incert and lots of draws.
12K views 7 replies 5 participants last post by  JaydenNan
#1 ·
Torsion Box Top
Here is my idea of a ultimate work station for and around my cabinet saw. Here is a progression of photos as I build each stage.
First is the cabinets with where the router will be there are 6 adjustable feet that allow me to adjust from "0" to about "2" inches so every surface will be perfectly level with the Table saw..
Wood Table Window Table saws Tool
Next is the top torsion box that will support the fence out to 54"
Wheel Tire Table Automotive tire Vehicle
Here you can see the top on the torsion box this will give me a surface 54" X 72" once the out-feed table is incorporated at the back of the saw.
Plant Wood Table Tool Tire
Tomorrow the 6 sets of draw guides should be here that I ordered from Rockler. The draws will be more of a shallow tray not more then 4" to 5" in hight even though the opening is 7" high.
Heres a few different angles
Table Wood Interior design Flooring Floor
Wood Workbench Tool Toolroom Gas
#2 ·
Torsion Box Top
Well done looking good!
#3 ·
Torsion Box Top
Your pictures are very helpful. I plan to do the same this summer. I only hope I do as good a job as you. Nice work!
#4 ·
Torsion Box Top
Thanks, the router insert is an after thought. Today I will try to build the box for it. I think I will put a draw or two in there as well for bits and such.
#5 ·
Torsion Box Top
Looks great! Cheers
#6 ·
Torsion Box Top
Well I have decided not to put the pouter into the table for two reasons I need to have the router raised up above the table so I can do router operations on curved projects that can not be done on a flat table. The other reason is I would prefer a mobile router table I can store against the wall.
#7 ·
Whats an out-feed table without a Panel Sled?
Table Wood Floor Flooring Engineering
Property Wood Interior design Floor Flooring
As I mentioned in the last comment of part 1 I am not going to place the router into the cabinet with the table saw so I moved on to the out-feed table. Its a real simple set up 3/4" Birch ply with a 3" oak border and oak stiffeners ever 12" the legs are 3/4" plywood as well. I removed the angle iron on the out feed side of the saw that's part of the Biesemeyer 54" fence and used the bolts to secure the out-feed table to the saw and 2" screws ever 12" to secure the out-feed table to the cabinet. I used William Ni' 5 cut method the firs try the sled was out 48 thousands but I was shocked how easy it was to nail it on the second try I let it go at half a thousandth. I highly recommend using his method it is so easy next I am going to make a dedicated zero clearance dado sled for common sizes 3/8" 1/2" 3/4" inserts as soon as I figure out how to attach a throat plate in the panel sled safely. Thanks for looking
#8 ·
This machine is helping to complete the wood project and you are looking like experience able person. Need some wood things for dissertation help uk review office and I am thinking this project is giving you.
