The electric is done and the inspection passed now on to the sheet rock.
Blog entry by sandhill posted 413 days ago 1752 reads 0 times favorited 6 comments Add to Favorites Watch
Almost done with the electric. I forgot to replace the outlet for the garage door..duh. But the walls are about half done with sheet rock. Because the ceilings are slightly over ten feet I left the top 18” for after the ceiling is up so the seams don’t crack after they are taped, not that its a big deal. I may put a 1”X6” or 8” around the perimeter at the ceiling for some place to hang templates to keep them safe and out of the way.
6 comments so far
View SugarbeatCo's profile
SugarbeatCo
60 posts in 433 days
#1 posted 413 days ago
Looks like you’ve been busy. Something to be proud of for sure. Good work, and its always good see the progress videos. I would like to do the same when Im in my big shop.
-- Always one more tool away from being an excellent woodworker...
View sandhill's profile
sandhill
1978 posts in 2089 days
#2 posted 410 days ago
Thanks, not many people watch them I will try to get better at it.
View Ken22F's profile
Ken22F
22 posts in 1429 days
#3 posted 410 days ago
Bob the Shop is looking good.
For your garage door and vent wiring pull a line from your breaker box
If it is getting full use a SINGLE POLE DUEL CIRCUIT BREAKER
sandhill
#4 posted 410 days ago
I still have 5 open spaces but I still mat use the piggy back breaker to keep them options open. What can I do to make it easier to pull new lines later on after the ceiling and walls are up.
Ken22F
#5 posted 410 days ago
Bob,
For the walls either have an extra hole drilled in the top plate (joist)
Or if you have some room in the existing holes that’s ok use them. Run a pull string (nylon like the stuff used for laying block strong).
Note: fill unused holes with a little expansion foam.
Adding pull strings are great
sandhill
#6 posted 379 days ago
Good idea ken, Will do.
