Quarter Sawn White Oak
Blog entry by sandhill posted 04-21-2010 03:36 AM 3490 reads 0 times favorited 8 comments Add to Favorites Watch
Well I am starting a new project and would like some input. After seeing to price of QSWO I was shocked to find the cost of the bed and rails made from Quarter Sawn White Oak came to right around a thousand dollars 8.50 A board foot. I can see using it on the legs and back rails that show but is that what everyone uses? Is 8.50 over priced? I thought it would be closer to 3.90 to 4.25 per BFT.
8 comments so far
View Dark_Lightning's profile
Dark_Lightning
3165 posts in 3134 days
#1 posted 04-21-2010 03:44 AM
Well, that depends on thickness. Sometimes the thicker stuff is more. More experienced LJs can tell you more, but when I priced QSWO for a chest, I was looking at about $500 US. This wasn’t 8.50 per bdft, it was about $5 per bdft (milled to 3/4”), at Rockler, and the boards I have been seeing/buying have usually been wany and warped.
-- Random Orbital Nailer
View mpmitche's profile
mpmitche
428 posts in 3001 days
#2 posted 04-21-2010 04:58 AM
It cost me about $6.50/bdft when I bought 5/4 QSWO in western NY last winter.
-- Mike, Western New York
View longgone's profile
longgone
5688 posts in 3333 days
#3 posted 04-21-2010 05:55 AM
You should search out someone with a sawmill and kiln. I recently bought over 400 bd ft of quartersawn oak for $3 bd ft. from a person I found on craigslist who was about 30 minutes from my house.
117115 posts in 3602 days
#4 posted 04-21-2010 06:04 AM
In my area plain sawn red oak goes for $4.25 and quarter sawn white oak twice that.
View sandhill's profile
sandhill
2128 posts in 3949 days
#5 posted 04-21-2010 06:44 AM
Thats what I am seeing Jim, 8.50 for 8/4 which I assume is good by the sound of it. The bed calls for 109 bft with hardware and tax it rings up to just under $1100.00 and that is for white QS oak. This is an expensive undertaking I can buy one for that much and its good quality. Maple may be a better choice?
View Tim Pursell's profile
Tim Pursell
499 posts in 3807 days
#6 posted 04-21-2010 11:13 AM
QSWO is pricey, especially if it is not common locally.
You’ve got lots of options, I love QSWO, but I have seen A&C furniture in all types of wood and it all looks good.
If you have re-saw ability you could laminate QSWO over a cheaper local lumber where ever possible, especially the side rails. When I built my first QSWO bed I just glued two 4/4 boards together to achieve the thickness I needed.
I did not like the seam showing on top so the next one I did I re sawed one 4/4 piece of QSWO and covered two 6/4 maple side rails (top & face). I got the Maple cheap because it was stained pretty badly. The same could be done for the posts, ensuring you get four really pretty flecked faces on each post. Saves a bunch of cash that way.
-- http://www.etsy.com/shop/tpursell?ref=si_shop
sandhill
#7 posted 04-25-2010 07:41 AM
Tim, I have to ask do you get many orders for beds? And is that what you do on the ones you sell from your site? Also do you miter the re-swan pieces that you put on the side & top, rails, and faces? Or do you use a locking miter bit? I like the idea of using a less expensive wood with the laminated face (plane white oak?) or I guess maple could work but I don’t think I would mix the QSWO with maple I may look at just a less costly white oak and laminate that. Great Idea thanks.
Tim Pursell
#8 posted 04-25-2010 01:03 PM
The answer to your first question is, sadly, not many in the past 3 years. I had great working relationships with 3 different interior designers that kept my furniture building endeavors in the black. Two closed up shop and one sold the business an took a job with a company that does large retail spaces. Poof—there went 90% of my biz.
I’ve only used this laminating method on side rails and legs, the rest of the pieces are solid wood. When I use the laminate method to cover a base wood I try to book match the most prominent pieces but even this is hardly necessary. Trying to miter the joints would be too time consuming for me, I guess it depends on how thick your face laminates are and how much time you are willing to invest. If your face pieces are 1/8” or thinner and are really tight in the corners, a simple easing of that corner is usually enough to mask the seam. Occasionally you may need to tweak a bit in the finishing stage to be certain the seam is near invisible. I have used the lock miter bit on the legs, but only on solid wood or the base wood before I apply a face of QSWO.
One other way to keep costs down when using QSWO on Mission style furniture is use square spindles no more than approx. 3/4” thick. No need to cut up a bunch of expensive QS when you can use cheaper flat sawn 4/4 white oak, once you rotate them, 90 deg. they are QS!
Once I found the Wood Slicer blade from Highland hardware: http://www.highlandwoodworking.com/woodslicer-resaw-bandsaw-blades.aspx and my thickness sander I have saved a ton of $’s resawing expensive woods for many applications.
