Big wood find #6: Vises & and 1/3 top and pop the grain
Blog entry by rtb posted 1189 days ago 900 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 5: The base comes together Part 6 of Big wood find series Part 7: Design Changes ? »
I recently read a short article in one of the current woodworking magazines about a simple three step, foolproof (thats the part that caught my attention) method finish. The first step was to wipe on and then off a light coat of BLO. “to bring out the natural color” or words to that effect.
Although I was going to whip out the small face vise the very next day cool temps and some sanding etc of the frame was in order first. Among others I wiped the tail vise with BLO just to see what in would look like. and was absolutely amazed.
I had never really seen Cherry with the grain defined like this, probably because so much cherry is stained. And the white Oak looks quite good as well. The face vice was next
I decided that I had no choice but to start the glue up of those pieces that I had cut for the top. I was not really comfortable with the idea of trying to dry glue in sub-freezing temps, but I also didn’t want to have to wait until spring. taking it into the house would have been self defeating as I would not be able to lift and carry it back to the shop.
As you can see the glue on the out side had certainly frozen by the next morning.To be a little more comfortable I kept it clamped until the 3 rd day. As nothing seemed to spring apart I crossed my fingers and manipulated it to the planer to start the flattening. with rollers on both sides of the planer i could send it through with a lot of helping it, shave off a small amount. I then shut of the planner, raised the cutting head and rolled it back through and started the process all over again. This soon became a drawn out process. At the end it looked about like this and I was done for the day.
-- RTB. stray animals are just looking for love
5 comments so far
View Ecocandle's profile
Ecocandle
1014 posts in 1232 days
#1 posted 1189 days ago
It looks great. What is BLO? It sounds like you were happy with the results, I would like to try it. I just don’t know what BLO stands for.
I do know…ELO…Electric Light Orchestra
I also know BTO…Bachman Turner Overdrive
So if you could explain wht BLO is, it woudl be greatly appreciated.
-- Brian Meeks, http://extremelyaverage.com
View AtomJack's profile
AtomJack
1279 posts in 1275 days
#2 posted 1189 days ago
Don’t forget GTO! I’ve had two of them in my misspent youth.
BLO=Boiled Linseed Oil
RLO-Raw Linseed Oil.
And it does pop the grain. Though it tends to darken the wood more than you might like. Now, if I could get my wife to use it as perfume…it’s a nice smell when you walk into a woodshop. You know you’re a LumberJock…when you walk into the wood section of a store and your nostrils nearly collapse from the deep whiff you take to get the smell.
Ecocandle
#3 posted 1189 days ago
Thanks AtomJack.
View bigike's profile
bigike
4023 posts in 1454 days
#4 posted 1189 days ago
good work
View rtb's profile
rtb
1097 posts in 1879 days
#5 posted 1188 days ago
I agree with atom jack that it can darken deeply. I have usually used in a mix but remember My grandfathers back porch on which he had treated wipe BLO. of course he let it soak in rather that the wipe on wipe on method that I did. and when dried it was so brown it was like dark tea.
