| Review by Jimi_C | posted 20 days ago | 732 views | 0 times favorited | 14 comments | ![]() |
- Kreg R3 Jr. Pocket Hole Jig System
- Brand: Kreg | Category: Other
I’ve been looking at getting a Kreg pocket hole jig for a while now, with it basically being a toss up between the R3 Jr. and the extremely simple mini jig kit. I wasn’t really looking at the K4 or higher systems, since they go up in price pretty quickly, and as always I’m working on a budget. In addition, I always planned to get the face clamps, so the extra clamping capabilities of the more expensive systems seemed unnecessary for my level of work. I bought the small face clamp for now, since I’m primarily using this for face frames, as well as the right angle clamp, to attach the face frames to the cabinet box. But enough about clamps!
That being said, the K3 Jr. meets my needs exactly. It comes with a nice case, which includes the guide for placing the stop collar on the drill bit (shown in picture #2) based on material thickness. The jig itself has adjustable sliders on each side, with positive stops for each material thickness (from 1/2” to 1-1/2”). It also has a detachable clamp pad for non-Kreg clamps, or if you are putting some pocket holes someplace you can’t clamp, there are screw holes for holding the jig in place. The jig has marks on the front face, denoting the pocket hole centers for lining the jig up. This kit also comes with a (very) small assortment of screws and plugs, but it’s not enough to do anything with but practice.
Out of the box, without reading the instructions, I was able to joint two pieces of scrap maple I had laying around. The joint was nice and tight, and with glue I have no doubt it’d keep just about anything together. Out of all of Kreg’s jigs, I think this one has the most bang for the buck, I’d recommend this to anyone looking to make some pocket holes.
14 comments so far
home | projects | blog
16683 posts in 470 days
posted 20 days ago
Good review
Rick Dennington
318 posts in 87 days
posted 20 days ago
Hey JimiC: They sure are nice to have. For a long time I’ve been using the Mini jig, and it’s great for one hole at a time. But I bit the bullet last week and ordered the K4 set-up, along with some other stuff from Rockler.
I’ve read some good reviews on here from other LJ’s. I may not use it all the time for some applications, but I’ll have it if I need it. Like they say—it’s better to have it and not need it, as it is to need it and not have it.
Have fun with your new toy !!
-- Remember--- one good turn-- gets most of the blanket!!!!
UnionLabel
148 posts in 93 days
posted 19 days ago
Good review. I have one and have used it recently in making some table legs for a mahogany play table I’m building for my grand-daughter. I absolutely love the ease and strength of creating joints, plus it frees up a ton of clamps too.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
dfarr
11 posts in 325 days
posted 19 days ago
Nice review and I agree. The R3 gets you started and able to dabble with the pocket hole method of joinery without having to invest a bunch of $. I find it quick and adaptable for my projects and so far I don’t see the need for the larger more expensive model. Make sure you order a back-up drill bit as once the pilot tip breaks off the rest of the bit is pretty much useless. My battery drill toppled over and the tip was gone in an instant. Luckily I had a spare.
Kent Shepherd
805 posts in 179 days
posted 19 days ago
Thanks for the review—Good job
rozzi
44 posts in 215 days
posted 19 days ago
Nice review. I have not bought one yet so I appreciate your thoughts. It will probably save some money.
-- Duane, Iowa
SteveMI
209 posts in 187 days
posted 19 days ago
Another thanks for the review. I have stood at the display a number of times trying to figure out which one would meet my minimal needs. The sales people always end any question about the lower models with a big BUT and proceed to brag about the K4 and above.
Steve.
bunkie
52 posts in 40 days
posted 19 days ago
Back in February, I bought the pocket Kreg Jig on impulse at the Woodworking Show. It definitely changed the way I do things. At about $20, it’s an excellent value. I ordered a big box of screws from Amazon (free shipping!) and off I went. In June I sprung for the $99 kit because it’s a real time saver when doing large panels. It’s much faster to place the panel in the jig clamped to the bench tha it is to index the pocket jig and clamp it down.
Last week I used the two clamps I had bought, the one with one jaw shaped like a dowel for right-angle use and one for face-frame use. The right angle clamp works like a champ and, in my opinion, is a necessity as the act of driving the screw tends to misalign the two workpieces.
Of course, I’m now into Kreg for a little more than I would have spent for the Master Kit, but I do have two drill bits and I can carry the pocket jig in my toolbox for portable use.
It’s my opinion that the various forms of Kreg jig are well worth the money. This weekend, I was making a pair of L-shaped shelved by edge-joining two plywood rectangles. The Kreg jig made short work of it. I am very satisfied.
-- Life is too short to suffer bad food and lousy speakers
NBeener
372 posts in 67 days
posted 19 days ago
Good review.
I’ve got the mini, and like it a lot. After my minimal experience with my Kreg router table, I’d be willing to consider anything else they make.
Seems like a good company, generally.
-- -- Neil
Dusty56
3458 posts in 581 days
posted 19 days ago
I bought the “big” set up several years ago and so far I have only used the mini 1 hole unit , clamp , drill bit and screws to make several projects….I could have saved a lot of money had I only purchased the previously mentioned items : ) If I ever need the other pieces , I have them ….somewhere. LOL
Greg
217 posts in 201 days
posted 19 days ago
Good review.
I purchased my second Kreg kit and use it alot. Find it to be quite useful and foolproof.
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
dbhost
600 posts in 125 days
posted 18 days ago
I have the Kreg jig on my upgrade list. I have a General Tool pocket hole jig, and it is anything but accurate. I mean it works, and thankfully all the pocket holes i Have made have been in concealed areas…
You chose very well. Use it to it’s ability and you will have some nice work done with it…
-- Trying to follow the example of the master.
Jimi_C
189 posts in 128 days
posted 18 days ago
Thanks for all the comments! Just thought I’d mention that I created my first face frame today using the jig, and it went together flawlessly! Measuring the diagonals, I’m about 1/16” out of square, which I’ll call close enough for the built-in I’m working on :D
mgb
23 posts in 106 days
posted 16 days ago
Nice review. I bought the K-3 last year and I love it. Built a cabinet for our laundry room, 84×34x24, used pocket holes to join all the pieces. Nice rigid joints.
Again good review
