Shop Made Honing Machine
Review by Andrew posted 1324 days ago 2512 views 3 times favorited 7 comments Add to Favorites Watch
Shop Made Honing Machine Shop Made Honing Machine Shop Made Honing Machine Click the pictures to enlarge them
I was communicating in a project from dbhost about this honing machine so I thought I would share it here. I got this motor (1/2 hp 1750rpm) from Metal Mike, a nieghbor, same guy who traded a working drll press for a broken band saw. I took 2 peices of MDF and glued them together, roughed a circle, about 10” diameter, then mounted it on my lathe. I turned it into a perfect circle, lathes are good at that. I then purchased a work arbor from woodcraft, I think $14. Mounted the MDF circle to the arbor and then charged it with white buffing compound. The wheel turns up and away from me, which is opposite from a grinder, but this is good for honing. I don’t have a tool rest so I have to freehand the tools, seems to work pretty good anyway. I am showing a menards Tool Shop chisel in the picture. I simply turn it on and hold the edge up to it so that the back of the edge is also against the wheel. When the “black mud” starts to roll over the top of the edge, it is sharp, very sharp and has a mirror finish. I use this to hone my Chefs Knives ( I can drop a tomato on it and have 2 peices) turning tools, chisels, planes irons, you name it.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
View Andrew's profile
Andrew
709 posts in 1394 days
7 comments so far
88965 posts in 1773 days
#1 posted 1324 days ago
Inexpensive but effective well done Andrew
27253 posts in 2018 days
#2 posted 1324 days ago
Andrew that is pretty neat. Thanks for the tip.
View dustygirl's profile
dustygirl
861 posts in 1924 days
#3 posted 1324 days ago
Nice job.Looks to work quite effectively.
View lew's profile
lew
9035 posts in 1951 days
#4 posted 1324 days ago
Cool!
If you make another one, you can go to the “Goodwill Store”, buy a leather belt for $1, contact cement the belt- fuzzy side out- to the perimeter of the circle. The leather is a little “softer” than the MDF and it loads up with compound a little better.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Jim Bertelson's profile
Jim Bertelson
3345 posts in 1360 days
#5 posted 1324 days ago
Thats’s another one for the “making tools is better than buying tools” crowd. Looks really neat.
-- Jim, Anchorage Alaska
View Berg's profile
Berg
116 posts in 1386 days
#6 posted 1323 days ago
I like it. This is on my list. And lew, thanks for the leather belt idea. Have you done that? I’m a little concerned about the belt flying off.
-- Pete - "To every thing there is a season Turn! Turn! turn!" [Ecclesiastes and Pete Seeger]
View StumpyNubs's profile
StumpyNubs
5106 posts in 996 days
#7 posted 534 days ago
Thought you may like to see my video of the Upgrades I made to the Work Sharp including one that allows you to use Tormek jigs AND how to use cheap buffing compound instead of sandpaper instead of diamond wheels and compounds:
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com
