Gotta love reusable glue spreaders.
Review by drfixit posted 27 days ago 885 views 0 times favorited 10 comments Add to Favorites Watch
Gotta love reusable glue spreaders. No-picture-s No-picture-s Click the pictures to enlarge them
This is going to be my first review here at LJs and hope some one finds it of use. I normally use the cheap little shop brushes for spreading glue in joints and on tenons and such. I went by the local WoodCraft the other day to pick some up and came across these polypropylene glue spreaders. There is 6 in a pack and at $3.50 I figured it would be worth a shot. Love em! I use a lot of Tight Bond glue, after using one the other night while glueing up a clock case, I simply let it dry over night. The next day the hardened glue just pealed right off, just like new! They are to small if you are glueing anything of size, but for most of what I do they work great. The spreader portion of them are approx 5/8” and are 6” long including the handle.
-- I can fix ANYTHING!.... Wheres the duct tape?
View drfixit's profile
drfixit
122 posts in 36 days
10 comments so far
View Jim Crockett's profile
Jim Crockett
319 posts in 625 days
posted 27 days ago
Hmmm – looks like a cross between a lollipop and a passifier. Very interesting. Don’t have a Woodcraft anywhere near me but next time I place an order there, I just might get some and try them out.
Jim
16598 posts in 469 days
posted 27 days ago
Interesting, thanks
View daltxguy's profile
daltxguy
558 posts in 806 days
posted 27 days ago
You could also just save a worn out foam brush and remove the foam. Underneath it, you will find something that looks just like this thing.
I’ve been using the brushes from a single package of shop brushes for the last 20 years. Clean em after every use and each one lasts a very long time.
-- Steve, New Zealand, www.steveracz.com
View CreekWoodworker's profile
CreekWoodworker
169 posts in 190 days
posted 27 days ago
Thanks for posting your review. I’ve seen those things but wasn’t sure how they would work.
Steve, interesting suggestion, I’m going to see what is under a worn out foam brush, never thought to look.
-- Mike the CreekWoodworker
View DaveR's profile
DaveR
1517 posts in 613 days
posted 27 days ago
For awhile I was getting these great free glue spreaders from American Express. I agree that the internal plastic thing in the foam brushes work well.
-- Until you spread your wings, you'll have no idea how far you can walk.
View Greg's profile
Greg
215 posts in 201 days
posted 27 days ago
I use the acid brushes from Harbor Freight for small glue ups. They are always on sale foe $1.99 for a bag of 36. I rinse them off with water after each use and re use them. For larger glue ups I use one of several sizes of UHMW scraps. Works grreat and nothing sticks. Best of all…the scrap pieces are free.
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
View RexMcKinnon's profile
RexMcKinnon
652 posts in 87 days
posted 27 days ago
Looks cool but I don’t know why they would put that ring around it just behind the head. Looks like that would restrict access and make it more cumbersome to use. I use the brushes and always forget to clean them before the glue dries. I always forget about it while fine tuning the clamps. Gonna try the foam brush trick. That sounds great.
-- If all you have is a hammer, everything looks like a nail!
View hunter71's profile
hunter71
93 posts in 79 days
posted 26 days ago
I don’t throw anything away that can be used. I make my glue spreaders from scrap wood, flat, brush, notched, make them all. Then they can be thrown out.
-- A childs smile is payment enough.
drfixit
posted 26 days ago
The ring holds it up off a table top when you lay it down. They have 2 flats to prevent the spreader from rolling also
View TraumaJacques's profile
TraumaJacques
382 posts in 393 days
posted 25 days ago
Hey! I still have 10 of those… 5 on my right hand and 5 on my left hand,you just need to wipe them on your pants once in awhile! I am gona try too keep the numbers the same for the next few decades. But thanks for posting.
-- All bleeding will eventually stop.
