Review: Porter Cable Pin Nailer
Review by Peter O posted 209 days ago 538 views 0 times favorited 7 comments Add to Favorites
View Peter O's profile
Peter O
622 posts in 316 days
Review: Porter Cable Pin Nailer No-picture-s No-picture-s Click the pictures to enlarge them
Features (from Porter Cable Website):
  • Uses 23 Ga. micro pin nails similar to Senco® models
  • Drives nails from 1/2” to 1” long
  • Tool automatically adjusts for different fastener lengths. Easier loading and less problems with pins out of spec
  • Bottom load magazine holds 170 pin micro nails
  • Dual trigger feature
  • Nail reload indicator
  • Rubber comfort grip on tool handle
  • Rear exhaust port channels air and tool oil/condensation away from user
  • Standard Equipment: Nailer, box of 2,000 ¾” pin nails, ¼” air fitting with dust cover, oil, wrench, carrying case, and operating manual
First impressions:
For those who have used Porter Cable brad guns, you will find this nailer somewhat familiar. I really like Porter-Cable’s magazine latch at the back of their guns. It really makes loading and unloading easy. Unlike other PC guns, this one is turned upside down for loading.
Cons:
  • I don’t like the dual trigger, and I don’t think it’s a very effective safety. There is no mechanism that requires the gun to be pressed against the workpiece in order to fire. A safety trigger is pulled with the middle finger, and then the primary trigger is pulled with the index finger. It’s difficult to hold on to the nailer with the last two fingers, so I found that I just held down the safety trigger, which keeps the nailer “armed” all the time.
  • I was also really bothered by the following quote from the owner’s manual: “The tool driving mechanism may cycle when tool is connected to the air supply.” This means that the air must be connected when loading the fasteners, which seems dangerous to me. It also seems to contradict another instruction: “Disconnect tool from air supply hose before … moving tool to another location, or handing the tool to another person.” Which would mean that when the tool is reconnected, it could fire, unless it were unloaded, reconnected, and then reloaded.
Pros:
  • It does what it’s supposed to do. I drove several ¾” pins into the face and side grain in White Oak and it sunk each pin to just past flush.
  • The nailer is quiet and uses very little air – I drove over 100 pins and my pancake air compressor only kicked on twice.
  • I actually like that the tip does not have to be pressed against the workpiece – this allows you to leave the pins proud, if you need to.
  • The nailer automatically adjusts to pin length, which makes loading a no-brainer.
  • I like the rear-exhaust. No matter which way I turn the adjustable exaust sheild on my other guns, I always seem to get a face-full of air!
Secondary Impressions:
I like this little nailer, and it will get a lot of use for attaching small trim and for holding difficult glue-ups. I will have to train myself to let go of the safety trigger when I’m not actually prepared to fire a fastener. I know there are better nailers on the market, and some that drive longer pins. For my requirements, this gun will do what I need it to do. The price was reasonable, and the performance meets my expectations. I was disapointed to find that even though the Home Depots in my area sell this nailer, they do not carry the pins for it .
-- What exactly is "The Move" and who are you calling a "Quirky Jerk"? -- http://www.north40custom.com
7 comments so far
View dalec's profile
dalec
452 posts in 330 days
posted 209 days ago
Nice review. I agree from your review that anyone owning the PC pin nailer will have to consciously work on tool handling process to avoid accidently triggering the nailer.
Dalec
View cajunpen's profile
cajunpen
5352 posts in 507 days
posted 208 days ago
Peter you nailed that review. I have the PC pin nailer and have grown to depend on it quite a bit – being careful with the safety IS good advice. Thanks for the review.
View Richforever's profile
Richforever
85 posts in 161 days
posted 86 days ago
Thanks for the great review. I’ve been wondering which nailer to put on my list. I’ve seen the little Grex nailer and it looks pretty good and has received good reviews, but not having used a nailer, can use all the info I can get.
Thanks!
-- Rich, Seattle, WA
dennis mitchell
2912 posts in 756 days
posted 86 days ago
I like my PC. I had two sencos but they did not hold up to every day use and my Grex just won’t sink the pins. The PC did the job for me.
View Sawdust2's profile
Sawdust2
827 posts in 529 days
posted 86 days ago
I’ve got one. For what it does and the price it cost it is a great deal.
:ee
View mrtrim's profile
mrtrim
1508 posts in 322 days
posted 86 days ago
ive had one of these 23 ga. pinners about 4 yrs and i have no problem with it . ive always been a senco owner but not anymore im done with them . this gun has never fired when plugging it in and i dont always have it plugged in when i load it . i wish my 18 ga. pinners also had the trigger saftys as well
great review peter
-- if you aint the lead dog the scenery never changes
View Scott Bryan's profile (online now)
8474 posts in 263 days
posted 86 days ago
Thanks for the review. I have been looking at one of these and was unsure about the PC or the Grex. This probably moves me in the direction of the PC nailer.
Bookmark And Share This Page
