Tenryu Dado won't allow shims!
Review by Russ Anderson posted 34 days ago 1063 views 0 times favorited 17 comments Add to Favorites Watch
Tenryu Dado won't allow shims! No-picture-s No-picture-s Click the pictures to enlarge them
This is a brief review of the Tenryu GMD.
First Impression: The blades look of extremely high quality with thick bodies.
Box: I personally don’t like the wood box because you have to lift out all of the chippers in order to get to the outer blades.
Cut Quality: I haven’t had the opportunity to make a lot of cuts with this set yet but so far I’m impressed! The bottom of the dado is the flattest, smoothest that I have seen. I’ve owned two previous dado sets, one from Systi-Matic, and one from Amana.
Setup: Setup is a little different on this set than I’m used to. First, there isn’t a set of missing teeth, or gap in which you put the teeth from the chippers. This isn’t a big deal though because here’s the other thing that’s different. The body of the blades and chippers are the same thickness as the teeth. That being said, it would probably be okay to have the chipper and blade teeth right next to each other but I can’t force myself to do it. There are a couple of positives here, thick bodies = less runout, and quick setup to specific dimensions (1/4”, 5/16”, 3/8”, 7/16”, 1/2”, 9/16”, 5/8”, 11/16”, 3/4”, 13/16”). The negative, which is a big deal for me, is that there is no room for shims! You either set it up with shims and then end up removing thin slivers inside your dado, or you make multiple passes. Neither of which works for me.
Conclusion: This is a high quality set that delivers amazing quality in the cut. I will be keeping my Amana set around for those situations where I need to get to odd dimensions, which seems to be all of the time. I’m really glad that I have another set, and that I didn’t pay for this one. If this was my only set and I had paid $250 + for it I would be rather upset that it doesn’t allow shims, especially since their’s no mention of it on the Tenryu website.
-- Russ
View Russ Anderson's profile
Russ Anderson
28 posts in 222 days
17 comments so far
View dustyal's profile
dustyal
444 posts in 368 days
posted 34 days ago
I’m looking around for a dado set and I appreciate your comments. I have this set on my list but I don’t know if the lack of shims would be a problem for me. My “table saw” is only 9 amps so I get a little concerned about weight of a dado. The arbor is long enough—I think. So I want to get a good dado set that I can use on this saw if I can… eventually I will get a new saw that would enjoy a better dado set… that make sense?
-- Al H. - small shop, small projects...
View Don Newton's profile
Don Newton
530 posts in 512 days
posted 34 days ago
Not being able to use shims would be a deal breaker for me. I have yet to use a dado set that I didn’t have to shim.
-- Don, Pittsburgh
20603 posts in 715 days
posted 34 days ago
Thanks for the review. At this price the dado set is obviously a quality product but I rarely make dado cuts without hading to add shims. And I agree that having to clean up the dado after making a cut would be an annoyance to me as well.
Russ Anderson
posted 34 days ago
I haven’t contacted Tenryu about what is typically done for shim conditions but there definitely isn’t room in between the chippers or the blades. I’ll send them an email and post my findings.
-- Russ
View reggiek's profile
reggiek
705 posts in 163 days
posted 34 days ago
Great review…great information…..I will definitely like to see what Tenryu says about the shims….I have dabbled with the thought of trying some of their blades as they are a little less then the forrest blades and are supposed to be of similar quality.
Russ Anderson
posted 34 days ago
Hopefully they will be able to provide a solution. The dado is amazingly clean. You can’t even tell where the stack transitioned between chippers. It cuts a grove that looks like it was milled by a single blade of that width. I’ve already emailed them and will hopefully hear back in the next day or two.
-- Russ
View Charles Maxwell's profile
Charles Maxwell
160 posts in 701 days
posted 33 days ago
I have a 10” Tenryu combo blade on my table saw. Hands down – It is the best blade that I’ve ever used. Sharpening is just not an issue. I’ve been using for 2-1/2 years now!!! Needs no sharpening!!!
-- Max the "night janitor" at www.hardwoodclocks.com
Russ Anderson
posted 33 days ago
Here was the response that I had from Tenryu in regards to shims.
“The main outer blades have zero clearance, but there is some clearance between the chippers. These are only places where shims can be used. Unfortunately, this may not be a solution for combinations of zero or single chipper used with the main blades.There are a couple of manufacturers offering special dados for undersized plywood, but our is not designed for that.”
I asked them what the clearance was between chippers but haven’t heard back yet.
-- Russ
16695 posts in 470 days
posted 33 days ago
Interesting review
View socalwood's profile
socalwood
968 posts in 497 days
posted 33 days ago
I don’t allow Tenryu in my shop. Thank you for the review though !
View Bothus's profile
Bothus
225 posts in 70 days
posted 33 days ago
Thanks for the review. I don’t do a lot of dadoing but it was interesting reading since I have been thinking about buying a Tenryu blade.
Socal wood: Don’t leave me hanging! You can’t make a comment like that without telling me the story behind.
Send me a private message if need be.
Thanks,
Bothus
-- Professional kitchen designer, amature woodworker.
socalwood
posted 33 days ago
Hi Bothus , I approached them at one of the AWFS shows about using their blades and they just blew me off- I was pretty insulted. I am one of those bone headed guys that look at my tooling seriously and they clearly do not take the tool business seriously .So I ended up with someone else for my business needs -
View hjt's profile
hjt
31 posts in 32 days
posted 31 days ago
Socalwood – sorry to hear that Tenryu treated you as such. When I and Pete worked for them I can guarantee you would have been happy with the service.
Unless they have changed their business plan, they sell through specialty stores via independent reps, however – you can contact them directly. Again, this is back when I worked for them in 2001.
Even though I really wasn’t into wood working back them, I can tell you from what I learned…. Tenryu makes a superior blade. Now that I am getting into woodworking (read my bio) I’ve already located my Tenryu dealer.
-- Harold
View rustfever's profile
rustfever
125 posts in 204 days
posted 30 days ago
I have an old Dado set that was included with the ca. 1950’s Dewalt Radial Arm saw, gifted to me in 1972. it is adjustable with most anything. I frequently use business card stock or even typing paper. It work just fine. I’ve only had it sharpened a half dozen times over the last nearly 40 years. Of course, only really used it just a few time, too. I used it just a few months ago. Still works good. Crisp edges, flat bottom. Maximum width of cut, using card-stock shims is .9375” [15/16”]
The old stuff never wears out.
-- Rustfever, Central California
View Peter O's profile
Peter O
1017 posts in 768 days
posted 30 days ago
I’m with socialwood – no Tenryu in my shop.
I went to a local supplier to buy a Freud Glue-Line Rip, and the salesman talked me into a Tenryu rip blade. If I liked the Freud, I was going to love the Tenryu: it was so much better I’d never look back. It cost twice as much as the Freud and cut like an Oldham combo blade. My local supplier said, “sorry, we don’t take back used saw blades.” and Tenryu said, “that’s not our problem” when I called. I went and bought a Freud and threw the Tenryu in the trash, and I don’t use Tenryu or that supplier anymore.
With regard to this dado set, the whole idea of a dado is getting a groove or dado the thickness you need, and that almost always means slightly over or under the intended measurement. The woodworker said to the machinist: “Sure, you may be accurate to .001”, but I have to be dead-on.”
-- http://www.north40custom.com -- http://north40studios.etsy.com --
Bothus
posted 28 days ago
Thanks for the explanation Socalwood.
Peter O, you are the first person I have heard say they didn’t like the way the Tenyru cut.
Thanks for the input guys.
Bothus
Russ Anderson
posted 27 days ago
After further research I felt it necessary to post a new review for this set. Click here!
-- Russ
