| Review by Routerisstillmyname | posted 33 days ago | 1462 views | 3 times favorited | 30 comments | ![]() |
- Freud LM74M010
- Brand: Freud | Category: Saw Blades
When Freud claims that this blade will give you flawless rips and glue joints, they are not boasting.
I purchased this blade few months back but never got around using it until this week when I got tired cleaning the mess my jointer was making.
Long story short, this put my jointer to shame. The cut is so smooth; you may have to scuff it up a bit before gluing.
Well, I’m not the least bit surprised, Freud makes some of the longest lasting and sharpest router bits and saw blades around. it’s 30T, 12 Hook and with 1/8” Full Kerf.
Enough said.
-- Router è ancora il mio nome.
30 comments so far
socalwood
home | projects | blog
968 posts in 496 days
posted 33 days ago
You might want to research the term “glue line rip ” , see who coined it , and what it means. I am happy that the Freud ripping blade pleases you -
-- rob
25793 posts in 1292 days
posted 33 days ago
Sounds like a good blade.
16558 posts in 469 days
posted 33 days ago
very good hard to believe it works that well.
Routerisstillmyname
109 posts in 401 days
posted 33 days ago
I was a skeptic also until I used this blade.
Unfortunately pictures can’t capture the smoothness. You just have to see and feel the cut to believe it.
Let me put it another way, If I had used this saw blade two months ago, Most likely, I would not have purchased a jointer and would have opted for a planer instead.
Jointers have their place but if someone were to buy a jointer just for glue up boards, I would recommend they give this blade a try first.
dbhost
599 posts in 124 days
posted 32 days ago
Considering how well their 40T Diablo blades work, I am not at all surprised that their higher end blades work so well…
-- Trying to follow the example of the master.
woodworm
8135 posts in 482 days
posted 32 days ago
Thanks for sharing.
I’m searching on-line store in UK that has this blade, but so far cannot find one.
-- masrol, kuala lumpur, MY.
bern92
41 posts in 247 days
posted 32 days ago
I’ve got the same blade and i love it. Work like they said.
-- RIP Sam Maloof.........
SEE
61 posts in 59 days
posted 32 days ago
I have a couple of their thin kerf blades. Both give me the same glue line rip as well as super smooth cross cuts. I’m a believer, now!
Next, I want to try some of their quadra cut router bits.
-- Build for the joy of it!
closetguy
302 posts in 784 days
posted 32 days ago
I only use Freud blades and the glue line rip is one of the finest ripping blades I have ever used.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
2372 posts in 233 days
posted 32 days ago
it sounds like a great blade .
however , nothing beats flattening and straightening rough lumber like a jointer ,
and nothing makes thickness like a planer !
Peter O
1016 posts in 766 days
posted 32 days ago
I just about wore out my current blade, I think maybe it can be sharpened one more time. The new one came today. I’ve spent a lot more on a rip blade, but never had one that I liked better.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
longboarder
14 posts in 157 days
posted 32 days ago
where are these blades available to purchase and how much are they? Thanks
bigike
173 posts in 180 days
posted 32 days ago
what store did u get it from? also is it a flat bottom cut cuz im looking for a blade just like that and i was gonna go with the forest but found the freud to be cheaper.
-- Ike, Big Daddies Woodshop,www.icombadaniels@yahoo.com
Greg
215 posts in 200 days
posted 32 days ago
This is An excellent blade! Just had mine resharpened and it sure lasted a long time in between its last sharpening.
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
Routerisstillmyname
posted 31 days ago
Never been disappointed with Freud but always amazed.
Todd A. Clippinger
5632 posts in 991 days
posted 31 days ago
I use this blade all of the time and have equally pleasing results.
I have it on my tablesaw right now and it is the one that sees the most use.
That also means that I have two of them because when one is being sharpened I put the other one on.
Routerisstillmyname
posted 31 days ago
Looks like there’s a new thin kerf glue line rip version with perma shield LM75R.
http://www.freudtools.com/p-421-thin-kerf-glue-line-ripbrnbsp.aspx
Thick kerf
http://www.freudtools.com/p-34-glue-line-rippingbr-nbsp.aspx
Jim
51 posts in 969 days
posted 30 days ago
I add my recommendation for this blade as well. I’ve used mine for 2 yrs. with excellent results!
-- Jim, www.greenteawoodworking.com
Cato
138 posts in 204 days
posted 30 days ago
What is the difference between the red and the silver blades? The look very similar but there must be a difference because the red blade cost a little more.
Todd A. Clippinger
posted 30 days ago
Cato – The red is the nonstick coating they refer to as “perma-shield.”
I prefer to run the thick kerf blades.
mnorusis
46 posts in 35 days
posted 29 days ago
I bought this blade yesterday, mainly based on this review and the favorable responses. It is most definitely amazing. I was using a dewal blade that, while better than the blade that came with my table saw, is no match for this blade.
Definitely recommended.
Todd A. Clippinger
posted 29 days ago
Remember that the blade gives the best results when the tablesaw is running true. So be sure to make sure that all is square.
Beginningwoodworker
4101 posts in 565 days
posted 29 days ago
Great review, thats all I use is Freud blades.
-- CJIII Future cabinetmaker
Routerisstillmyname
posted 29 days ago
mnorusis, congrats on your new blade. happy jointing ;-)
panther
36 posts in 135 days
posted 29 days ago
the blade can be found at woodcraft stores or woodcraft.com
woodspyder
59 posts in 521 days
posted 28 days ago
I have only used the inexpensive blades, until recently, because I’m cheap or frugal take your pick.
I bookmatched a Birdseye maple plank for a table I am working on and was having trouble getting the edges ready to be glued. I saw an article somewhere recently about this blade and thought, “why not”?
It does leave a beautiful edge ready for gluing.
-- Measure three times, cut twice.
APLJaK
47 posts in 259 days
posted 27 days ago
They all work well when they are sharp. Just keep this in mind as the cut starts to degrade (and it will).
-- APLJaK Woodworking, Okanagan Valley, BC
Russ Anderson
28 posts in 220 days
posted 26 days ago
Socalwood, now I’m curious, who coined the term “glue line rip” and what does it mean? The only thing that I can find is that maybe the original was orange.
-- Russ
Splinters
168 posts in 1075 days
posted 17 days ago
per Todd’s and my conversation and all in this threads comments…I have ordered,received, installed, and used this saw blade… All I have to say is “What took me so long?”
-- Splinters - Living and Loving life in the Rockies - http://www.splinterswoodworks.com/ - http://www.etsy.com/shop.php?user_id=5220040
vikingcraftsman
2 posts in 9 days
posted 9 days ago
I purchased my first DIABLO blade more than 5 years ago. A 10” 40T for my Mitre/Chop Saw. I’ve since added blades to all my power equipment. The 5 year old blade still cuts like the day I bought it. At $35-$60 a blade, they are a little expensive but worth every penny. Whatever your application, get on board and experience the difference. You’ll never buy another blade again!
