| Review by DannyBoy | posted 40 days ago | 888 views | 0 times favorited | 6 comments | ![]() |
- Woodcraft Retracting Casters
- Brand: Woodcraft | Category: Tablesaw Accessories
From the start, I needed to make sure that my saw would be movable. With a small shop, floor space is at a premium and it only makes things difficult to admit that my floor is not at all level and even.
This system took care of both of those needs. The casters are well built and work well on the uneven floor. Plus, once you are done moving the unit, you flip it down onto it’s own feet right into your floors sweet-spot.
Two bits of advice:
First, you probably won’t match have matching holes in your shop for the casters. Just realize that and drill new holes. I used a step drill bit and drilled the holes into the saw’s legs. Worked well and quickly.
Second, take a realistic view of your saws legs. If you have an older Craftsman like I do or a base with no cross bracing within 6” of the floor, then you need to put some supports in. This is an easy and quick fix that will make the base more solid and make you more confident that it won’t suddenly fall out from underneath the saw. Don’t wait. Do it.
All in all, it is a good value. Woodcraft sells them for about $45-$50 so it is less expensive than many alternative bases. Plus, I doubt you could build a much better base for that (what with caster costing $15 a piece in some cases).
~DB
*I rewrote this during the day. The original was written after midnight…
-- He said wood...http://hickbyassociation.blogspot.com/
6 comments so far
home | projects | blog
16681 posts in 470 days
posted 39 days ago
Good review thanks for the info
clieb91
683 posts in 828 days
posted 39 days ago
These types of casters are the ones that are attached to the bandsaw I just bought used. They work great. Glad to know now where they came from.
CtL
-- Chris L. "Don't Dream it, Be it."
poppychuck
14 posts in 363 days
posted 38 days ago
I have installed these on two steel leg sets-and they are excellent. Just make sure you release them with the toe of your shoe,
-- Chas F
dustyal
443 posts in 368 days
posted 38 days ago
Thanks… didn’t even know they existed. I’ve been reviewing and scratching my head as to how to make portable any power tools I want to add.
-- Al H. - small shop, small projects...
UnionLabel
148 posts in 93 days
posted 37 days ago
I bought 2 sets of these last year. One set is on the shelf, the other is on my RAS. I love ‘em. They are great for my garage shop. But like poppychuck stated keep your hands away. These things can bite if you don’t use your shoe toe.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
VanessaG
6 posts in 184 days
posted 27 days ago
Yes I have these too, they came on a second hand Craftsman Table saw I bought. I am having a little trouble adjusting them though, seems the spacing between the wheel and the floor is too tight so on some high places in my uneven floor, the actual leg drags.
