| Review by michaeldmunro | posted 45 days ago | 744 views | 0 times favorited | 9 comments | ![]() |
- Craftsman 21802 (10 in. Table Saw with Stand)
- Brand: Craftsman | Category: Tablesaws
This being my first product review, I might miss some obvious things, but I’ll give it my best shot.
At around $100, the Craftsman 21802 10 in. Table Saw is a good beginner’s saw. This is also my first table saw. I had no expectations other than when I was done I would be able to cut wood with it! The assembly was easy and I had it together in about 30 minutes or so. All the parts for the stands fit nice and everything lined up where it was supposed to.
After assembly I set about to square the blade up to the work surface. Here is where this saw lost a star from me. The hex bolts holding the motor in place were cranked down very tight to begin with. I suppose this could be a safety issue, but it made it hard to square the blade. I had a hard time getting my hands in there to get to the locking nut under the motor. There’s just not a lot of room under there. I was finally able to get the bolts loose and square up the blade.
After tightening the bolts back up I took it outside for a test run. The motor has enough horsepower to cut lighter stock. If you’re cutting hardwood, take your time feeding it through. Now, this could be due to the stock blade, so I won’t say that the saw is completely underpowered. Just take your time.
The miter gauge and the rip fence are passable, but you will want to measure two or three times when you set up for a cut. They are made very cheap and I don’t know how accurate they are.
Hope this helps anyone looking to buy this saw. I’ve been able to get a floor out of it. Now on to my workbench!
-- www.michaeldmunro.com
9 comments so far
HokieMojo
home | projects | blog
1142 posts in 626 days
posted 45 days ago
does your saw have smooth miter slots or does it have a few little “teeth” to help hold the miter gauge down to the table? Mine had teeth and that became the reason I needed to replace it. I couldn’t use any homem ade jigs. I hope they changed that.
JJohnston
118 posts in 189 days
posted 45 days ago
My dad has one of these, and while it’s no cabinet saw, it does OK for utility-grade projects, such as crosscutting and ripping cedar fence pickets, and cutting 2-by lumber for quick work benches. One of the better features is that the whole thing weighs about 30 lb complete, so you can pick it up and set it right where you need it.
-- Measure twice, then try to figure out which one was right.
UnionLabel
149 posts in 98 days
posted 45 days ago
You’re on your way now. Next comes the router table, then the drill press, then the …. oh you know the rest.
Christmas is coming, better start making your list. Nice job on the review. Thanks for taking the time.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
17022 posts in 475 days
posted 45 days ago
good review enjoy your new saw.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
Tim_456
46 posts in 493 days
posted 45 days ago
i had a saw similar to this and it was my first TS as well. For $100 it was the right tool for me at the time. Plus it’s size makes it portable and less intimidating than a big cabinet saw. Other than outgrowing it the only problem I had with it was the fence. The fence was always out of square and eventually broke and I had to rig up my own which took FOREVER to set up for each cut. Anyway, I still have mine buried on the bottom shelf in the garage and I’d like to use it for something but I need to fix that fence issue;)
My only advice is watch that fence and make sure you don’t get any wicked kickback.
stefang
1655 posts in 232 days
posted 44 days ago
Congratulations on your first table saw. I remember when I bought my 5 function combi machine. I used the tablesaw right away, but I was very new to woodworking, so I just tiptoed around it for quite a while before I actually got up the nerve to try the other 4 functions.
-- Mike, American in Norway
KTMM
13 posts in 91 days
posted 44 days ago
I had two of these and took them both back. I couldn’t get the blade to line up with the miter slot or fence. The first one I tried to adjust the blade using the alen screws and they stripped. I got some replacement screws and still couldn’t get the blade to line up. The second time around was about the same. I’m a very paranoid woodworker these days, and all of my tools frighten me to some degree, but a misaligned tablesaw will keep me out of the shop. I’m glad to hear you’ve had better experience.
michaeldmunro
12 posts in 202 days
posted 40 days ago
To answer HokieMojo’s question, the miter slots have little tabs (teeth?) to hold the miter gauge in the track. They don’t do a very good job and there’s a lot of slop in it. I’m going to run a few layers of duct tape trimmed to fit the miter gauge rail to “beef up” the rail. That should hold the gauge tighter to the tabs while letting it slide. I’ve fund that a light coat of WD40 in the slots helps too.
To add to Tim_456’s comment about the rip fence, I agree that it is less than accurate when it’s used. I’ve taken to using my speed square a lot to make sure the rip fence is square to the table and parallel to the blade.
Again, for the price it does a pretty good job. My next project will involve using a dado blade for the first time and also cutting some compound miter’s.
michaeldmunro
posted 39 days ago
Just wanted to add an additional comment on the rip fence… make sure the tension screw is tight enough or the fence will travel on you and you’ll end up with an out of square cut. Found that out tonight while cutting legs for my scrap wood workbench project. Doh!
