Good and fast
Review by DannyBoy posted 47 days ago 348 views 0 times favorited 4 comments Add to Favorites Watch
Good and fast No-picture-s No-picture-s Click the pictures to enlarge them
I picked up the 5-piece set of these from Lowes yesterday to drill holes to run wires through floor joists. I’ll be comparing these to the last ones I had which came in a catch-all bit kit I got for Christmas years ago (they sucked).
The bits bored fast. I mean really fast. I’m not sure what difference in the design that makes them bore so quickly, but it definitely made the difference. I used the 5/8” to bore through the joists at a slight angle (since I didn’t have a 90* drill). Holes went through relatively clean with a little tear out on the back end. I’m sure if I clamped a sacrificial scrap on the other side, it would have been clean through.
There was a little bump about halfway through one joist as my hand slipped a little on the drill. But that was my fault and not the bit. The bit kept going through despite the bump.
I’ll probably never give up my forstners, but for $8 I’d say these are a good deal to add to the shop.
~DB
-- He said wood...http://hickbyassociation.blogspot.com/
View DannyBoy's profile
DannyBoy
442 posts in 758 days
4 comments so far
View NBeener's profile
NBeener
372 posts in 67 days
posted 47 days ago
Had those in my sights, so … thanks very much for the info!
-- -- Neil
View HokieMojo's profile
HokieMojo
1140 posts in 621 days
posted 47 days ago
i like these bits too.
View dbhost's profile
dbhost
600 posts in 125 days
posted 47 days ago
Got the SpeedBor Max bits. The cut in crazy fast… Had a set of the original SpeedBor bits that I wore out. I like the regular SpeedBor bits better… Easier to control…
-- Trying to follow the example of the master.
View reggiek's profile
reggiek
705 posts in 163 days
posted 47 days ago
Nice to hear….sometimes using a forstner is just not possible….or to use a very good set to cut holes in pitch laden pine is not what you want to do…I’ll have to look out for that set…Thanks for the info.
