MASTERFORCE 18" Scroll Saw with Rotary Attachment
Review by Raymond posted 51 days ago 702 views 0 times favorited 4 comments Add to Favorites Watch
MASTERFORCE 18" Scroll Saw with Rotary Attachment MASTERFORCE 18" Scroll Saw with Rotary Attachment MASTERFORCE 18" Scroll Saw with Rotary Attachment Click the pictures to enlarge them
The other day I went to use my trusty Wilton Scroll Saw, went to turn it on and nothing…After checking the usual. Yes it was plugged iin. My nose told me something was wrong. There was that smell we all know, the smell of a burnt controller board. And yes it was toast. So off to Menards to get a replacement one. When what do I see but this Masterforce 18” Scroll Saw. So after poking and prodding it I load up my cart and off to home I go. The saw seams built very rugged it’s an 18” saw, 2” depth of cut variable speed with a left and right tilting table. Tilting is done by rotating a knob that engages a gear, there is a lock handle once the desired angle is set. The motor is a 2 amp 120 v ac motor, with an accessory shaft that can be used either hand held or placed in the accessory table giving the tool the ability to do routing or sanding. The accessory tool is a flexiable shaft tool with a 1/4chuck. Speed range on the accessory tool is 1100 to 4500 rpm, and blade speed is 400 to 1600 spm. Blade stroke is 3/4 inch. The saw is complete with buiilt in blower not a cheep hose but a flexible ball socket tubing, with an LED light built into to blower tube so the light is placed right on the cut. My first impression of the saw is impressive, time will tell as I put it though it’s paces. Price was 159.99 on sale regulary 199.99. It has an outstanding 5 year warentee if it breaks take it back to Menards with your reciept and walk out with a new one.
Looks like a winner to me
I’ll keep you posted
-- Ray
View Raymond's profile
Raymond
80 posts in 623 days
4 comments so far
View Trikzter's profile
Trikzter
31 posts in 152 days
posted 50 days ago
Thanks for the review, Ray. I’m studying on a scroll saw on the cheap. I will check em out next time I go to Menard’s.
-- Rick... A tree knows more about wood then I do.
View PetVet's profile
PetVet
233 posts in 383 days
posted 50 days ago
Thanks for the review Ray. Do you know of any other source for these other than Menard’s?
-- Rich in Richmond
Raymond
posted 50 days ago
Hi there Rich, not that I am aware of. I will look into it. I know the manual has a 1-800 number for service so I will get that for you. They might be able to let you know where else you can purchase the saw.
-- Ray
View UnclePhil's profile
UnclePhil
1 post in 40 days
posted 40 days ago
Hello Guys, you may be able to order the saw from Menards and have it shipped, if you don’t have one close enough to you.
