Grngate Gates Work Great
Review by pintodeluxe posted 04-10-2017 07:21 PM 2340 views 0 times favorited 7 comments Add to Favorites Watch
Grngate Gates Work Great Grngate Gates Work Great Grngate Gates Work Great Click the pictures to enlarge them
Check out my video review on Youtube…
https://www.youtube.com/watch?v=3ic9A73Fb_Y
Installing this Grngate starter system was amazingly simple. If you can plug in a phone, you can install this system. Of course you have to wire the system controller, but that’s nothing more than stripping a few wires, and screwing the wires to a terminal block. Actually I sacrificed a 240v extension cord so I could keep my dust collectors cord intact, and that was a good solution for me.
The gates are quite sturdy, and feel like they are built to last. Everything is wired with communication cables, so you don’t need a separate 120v outlet at each gate or sensor location. You can daisy chain the gates together as needed, or run home runs to the controller, whichever works best for your shop layout. The starter kit comes with a controller, three gates, three sensors, and all the cables. If you compare it to other systems, it’s a fantastic value. If it seems expensive, compare it to respiratory therapy. Dust collection is important for our health people, and this system makes sure I will actually use my dust collection for each and every cut.
This year my priority was safety, and for me that means a Sawstop and good dust collection.
As far as reliability, the gates have activated 100% of the time. Since everything is hard wired, I don’t expect any issues.
Comments and questions are welcome.
(sorry about the dinosaur picture, but the blast gates remind me of a Dilophosaurus with neck frills in attack mode!)
View pintodeluxe's profile
pintodeluxe
5737 posts in 2899 days
7 comments so far
View Jerry's profile
Jerry
2713 posts in 1734 days
#1 posted 04-10-2017 08:05 PM
Willie this is a GREAT review, very useful and informative, thanks so much for taking the time to post this!
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
pintodeluxe
#2 posted 04-10-2017 08:19 PM
Yeah, it’s a good system for people that want effective dust collection without having to manually switch gates and start the collector with each cutting operation.
Thanks
View CyberDyneSystems's profile
CyberDyneSystems
288 posts in 2275 days
#3 posted 04-10-2017 08:59 PM
Thank you for the review. This looks like something we might afford, and we definitely NEED!
-- Without the wood, it's just working
View CL810's profile
CL810
3820 posts in 3074 days
#4 posted 04-10-2017 08:59 PM
Thanks for a great review Willie!
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
View AZWoody's profile (online now)
AZWoody
1366 posts in 1310 days
#5 posted 04-10-2017 09:14 PM
Interesting. With the shape of those gates, have you had a problem using it with ducting against the wall? It looks like everything has to be angled away or set out quite a bit.
pintodeluxe
#6 posted 04-10-2017 09:37 PM
- AZWoody
That’s what I thought initially. The gates have threaded inserts that allow you to wall mount them. That would be a slick way to do it, because you could attach to your metal duct or S&D duct on both sides of the gate. The pipe itself would tuck nice and tight to the wall (I’m imagining doing this on a vertical drop), and the gate would just stick out a bit more.
Even the way I did my simple install, the gates don’t interfere with my normal woodworking routine.
Thanks for chiming in.
View Gripbd's profile
Gripbd
18 posts in 879 days
#7 posted 04-11-2017 03:39 AM
I’ve got this system too. What sold me on the automatic operation was that I could install the blast gates in locations regardless of whether or not they would be easily accessible for manual operation. I have dust collection to my TS above and below the table, so I have one gate on the floor beside the saw, and one gate on the ceiling. I also installed the gate to my miter saw below the saw, where it is out of the way, but inaccessible.
I would like to add that Petr, who I dealt with when I placed the order, couldn’t have been more helpful to deal with, and I highly recommend them.
