Excellent budget blade!
Review by Mike Gager posted 47 days ago 683 views 2 times favorited 23 comments Add to Favorites Watch
Excellent budget blade! No-picture-s No-picture-s Click the pictures to enlarge them
I just recently bought this blade after reading some of the reviews on the home depot website. I am very satisfied with it and think its an excellent choice for someone on a budget wanting a nice cutting blade. I havent used any of the high end blades such as the forrest woodworker2 but i would be mighty surprised if they cut that much better then this blade does. I tried it on red oak, pine, douglas fir, MDF, and particle board melamine and it left a super smooth cut in all of them with no tear out on both rip and crosscuts.
For $39.95 i think its a pretty good deal
i plan on getting one of ridgids 90 tooth blades for my miter saw when i get some extra cash
the following is from HDs website
RIDGID 10 In. x 50 Tooth Combination Saw Blade
Model # R1050C
T3 Titanium coating technology maximizes tool performance protecting the from heat and corrosion, while extending saw blade cutting life.
LASER CUT REDUCED VIBRATION TECHNOLOGY delivers quiet performance while reducing vibration
LARGE MICROGRAIN TITANIUM CARBIDE provides maximum cutting life and resharpenings.
ENGINEERED TENSIONING keeps the blade running true and flat.
OVERSIZED GULLET DESIGN maximizes chip removal while cutting for a more precise cut.
View Mike Gager's profile
Mike Gager
215 posts in 159 days
23 comments so far
View kkickback's profile
kkickback
234 posts in 108 days
posted 47 days ago
I use this blade mostly and on my table saw for cutting red oak …best bang for the buck I think…
-- christoper Blanchard, Michigan
View rtb's profile
rtb
678 posts in 605 days
posted 47 days ago
I’ve been using this blade for over a year for everything and can not find a single fault with it. I could’n quite make the stretch to the high end blades and don’t know now that I will ever even try.
View NBeener's profile
NBeener
369 posts in 66 days
posted 47 days ago
This is what I’m running on my (new) Bosch 4100, and what I WAS running on my (kicked to the curb) little Ryobi.
I love it … BUT … do get a bit more tear-out than I’d like on Baltic Birch ply (of COURSE, that’s what I’m working with for two projects!).
Do I NEED to use a sacrificial board underneath the to-be-cut piece … or … step up to a specialty blade for the finish ply work … or … is it likely I’m doing something wrong?
-- -- Neil
View depictureboy's profile
depictureboy
305 posts in 534 days
posted 47 days ago
NBeener…Tape your cuts that will help some…
I have this blade and love it…but I am still thinking about getting a dedicated rip for those special occasions.
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
NBeener
posted 47 days ago
Plain old masking tape? No downside….. Thanks.
-- -- Neil
View jerryz's profile
jerryz
109 posts in 170 days
posted 47 days ago
NBeener, do you have a zero clearance insert on your saw? that will make a huge impact when cutting plywood material as the insert acts as a backup to the material to the side of the cut.
The tape trick I have used when cutting melamine countertops and it works, you still can have some chip-out however.
depictureboy
posted 47 days ago
not regular masking tape…use the blue stuff…regular might mess up your veneer…
NBeener
posted 47 days ago
Jerry: Got a ZCI.
Just did the cut on it, last week, but haven’t tackled any more of the Birch with it, since. Looking forward to some improvement. Thanks.
depictureboy: Got it, and thanks, on the blue painter’s tape. Got a whole roll laying around. Thanks.
-- -- Neil
View John Gray's profile
John Gray
1748 posts in 777 days
posted 47 days ago
I have one of these blades and love!
View Routerisstillmyname's profile
Routerisstillmyname
109 posts in 401 days
posted 47 days ago
No need for backing board or tape. Use the old school trick. lower your saw blade so that only about 1/16 or so is sticking out of table. then run your sheet backward. then raise the saw blade to cut level and do regular forward cut. No tear out this way.
some super high end table saws have a second small saw blade that runs opposite of the main blade just for that purpose.
-- Router è ancora il mio nome.
View MOJOE's profile
MOJOE
83 posts in 161 days
posted 47 days ago
I replaced my factory blade with a RIDGID from Home Depot as well. I have been very satisified with it. Have most recently run a fair amount of hard maple across it, and no troubles.
-- Measuring twice and cutting once only works if you read the tape right!
16577 posts in 469 days
posted 47 days ago
good review
View Ryan Brown's profile
Ryan Brown
35 posts in 82 days
posted 47 days ago
Wood Magazine just gave this blade top marks for this price point.
-- If you can't fix it with a hammer, you have an electrical problem. Roanoke, VA
View DaveH's profile
DaveH
372 posts in 670 days
posted 47 days ago
For plywood I use the Freud blades that have an excellent rating for plywood. As near to no tear out that I have seen from any blade.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
NBeener
posted 47 days ago
DaveH: the one I had on my to-buy list is called
“Freud LU80R Ultimate Plywood and Melamine Blade”
Sound familiar?
I’ll try the pre-saw @ 1/16” trick first, but hold the Freud as a Plan B.
-- -- Neil
View Dusty56's profile
Dusty56
3456 posts in 580 days
posted 46 days ago
” then run your sheet backward” …sounds like an accident waiting to happen ! : (
Must be assuming that you have no blade guard , splitter or riving knife installed on your saw. Stick with a ZCI made with the blade that you’re using to cut with and tape if still necessary. Also , you might want to adjust your feed rate.
View michstairguy's profile
michstairguy
9 posts in 135 days
posted 45 days ago
There is really no reason to run your stock backwards to make a scoring cut just run as you normally would except with the blade elevated 1/16 inch . This may be a good blade but once you try a forrest ww2 you will never look back
-- There is no growing in knowing where your going
View scopemonkey's profile
scopemonkey
128 posts in 1056 days
posted 41 days ago
This is all I use. For almost the price of sharpening a WWII, I get a new blade. This has consistently been ranked highly by woodworking magazines—most recently Wood. For the price, you can’t beat it. Used in conjunction with a zero clearance insert, I get great results from sheet goods to hard as nails exotics.
-- GSY from N. Idaho
View RexMcKinnon's profile
RexMcKinnon
652 posts in 87 days
posted 39 days ago
Great Review. I too have this blade and the ridgid 90 tooth 10 inch blade in my mitre saw. Love them both. In the latest edition of WOOD Mag they compare many budget blades and the Ridgid 50tooh came out on top. I wish we could get them for that price up here in Canada though. $63.99 hopedepot.ca
-- If all you have is a hammer, everything looks like a nail!
View VanessaG's profile
VanessaG
6 posts in 183 days
posted 26 days ago
Hey thanks for the great review!
View knotscott's profile
knotscott
521 posts in 267 days
posted 15 days ago
This blade is made by Freud and is very similar to their Diablo D1050 and Industrial LU83R010 (the LU83 has thicker carbide). The LU84 is Freud’s full kerf version of the LU83. Any of these should have similar performance, but the full kerf is 33% wider so the TK’s are easier on the motor.
NBeener – The LU80 is an 80T Hi-ATB blade that’s outstanding for ply and crosscuts…the LU79 is their thin kerf version. Other blades with a similar grind are the Forrest Duraline & WWI, Infinity 010-080 & 010-060, and Amana MB10-800. CMT, Ridge Carbide, and Tenryu likely have some 60T and 80T Hi-ATB blades.
View AKWoody's profile
AKWoody
12 posts in 55 days
posted 10 days ago
Just purchased this blade based upon this review, I was not disappointed.
Thanks!
View hasbeen99's profile
hasbeen99
130 posts in 431 days
posted 10 days ago
Good to know, guys. Based on what’s posted here, this will probably be my next blade purchase. Thanks everyone!
-- "The only thing that counts is faith, expressing itself in love." --Galatians 5:6
