| Review by Tony | posted 53 days ago | 794 views | 1 time favorited | 13 comments | ![]() |
- Chinese imports #4 smother
- Brand: Chinese imports | Category: Hand Planes
I have just completed this review on a Chinese imported hand plane. This hand plane looks remarkably like the WoodRiver Hand planes supplied by WoodCraft, so I thought that you might like to read the review I wrote about a similar hand plane over here in Finland.
The report is in pdf format which you can down load it if you wish to read the full report.
Summary: A well engineered hand plane, which has a positive feel to it as soon as you pick it up. The weight of the plane is a definite advantage in eliminating the chatter, normally associated with lower cost hand planes.
Straight from the box, only with a small amount of sharpening and honing on the blade to get good results, I think that with a small amount of fine tuning (the same with any hand plane) the results would absolutely A1
After using this smoothing plane for a whole day, I found that it was a real pleasure to use – the results were first rate, as good as I can achieve on my more expensive hand planes. The only disadvantage I found was the size of the Tote/Handle, but this was not a major drawback.
Conclusion: I would strongly recommend this particular hand plane as real competitor to other number 4 hand planes on the market costing 2 or even 3 times as much. Add a second blade for high angle work and this tool would cover most of your small project needs.
I am looking forward to getting my hands on the remaining hand planes in this series to test and use.
Value for money 10/10
Performance 10/10
Ergonomics 9/10
Overall 10/10
13 comments so far
home | projects | blog
3046 posts in 919 days
posted 53 days ago
I have had the same experience with these planes.
They work even better with a Lee Valley or Hock blade in them. Thes bllades are thcker and allow a beefier edge to reduce chatter.
Would I trade them for Lee Valleys? – of course!
In the meantime I have some darn good iron to work with with a modest investment.
Good luck with yours
AaronK
409 posts in 361 days
posted 53 days ago
hmm. where do they retail in the US?
Tony
813 posts in 927 days
posted 53 days ago
Hi Bob
They are a great tool, but I have to disagree with you about the Hock blades. The hock are 3/32” thick, whilst the blade in this unit is a full 1/8”thick, about 0.7mm thicker than the Hock equivalent. Also I prefer the chip breaker on this unit to the Hock version.
I am really looking forward to seeing the remainder of the planes in this series later this month, Block, #1, #3, #5 & #6 – I think they will give the expensive tools (Veritas, Lie-Nielsen, Clifton etc..) a run for their money
Tony
posted 53 days ago
Aaron
Try WoodCraft click on the WoodRiver link above
posted 53 days ago
Thanks for the news Tony.
Mine were purchased about 3 years ago and the blades were about 2mm.
Looks like they may b listening to us for a change. <g>
I just bought a shoulder/rebate plane and am having to replace the blade before it will be serviceable.
For the $24.00 outlay I can afford to do that. <g>
http://www.leevalley.com/wood/page.aspx?c=2&p=53228&cat=1,230,41182,43698
http://www.leevalley.com/wood/page.aspx?c=2&p=42607&cat=1,41182,43698
AaronK
posted 53 days ago
ah gotcha. so “remarkably like” means “probably identical” lol. thanks!
Dick, & Barb Cain
7043 posts in 1196 days
posted 53 days ago
Thank you Tony,
This is excellent info for anyone on a smaller budget.
Chris Cunanan
223 posts in 377 days
posted 52 days ago
where can you get em?
Tony
posted 52 days ago
Read the post again, the links for the USA are shown
Napaman
3492 posts in 974 days
posted 51 days ago
nice review…planes are an area i have not ventured…
Chris Cunanan
posted 51 days ago
sorry to look stupid tony…but you said it was Like that one, so i figured ur source would be cheaper? is $120 really the cheapest Cheapest plane you can get new? i remember some $20-30 HF ones..
Tony
posted 51 days ago
Chris
The reason I said “remarkably like the WoodRiver Hand planes supplied by WoodCraft” was that I cannot confirm that they are by the same manufacturer.
You can buy much cheaper hand planes such as Anant, but my Anant hand planes are gathering dust, so much so that it is difficult to find them any more.
The old adage “you get what you pay for” does not apply in this case, I think that these planes are great value for money. I have used the Lie Neilson and Veritas #4 smothers and to be honest this plane is as good (a little fine tuning and tweeking, but the same for the more expensive planes).
So you can buy a $25 and you will probably spend another $50 on a new chip breaker & blade and hours upon hours fine tuning it and you may never get right. Or, you could spend $120 on a plane like this, get a better blade (full 1/8” thick Vs 3/32”) than is offered in the more expensive tools, save a fortune vs. the more expensive tools, it will work directly out of the box (sharpen the blade) and hard pushed to see the difference in quality, if any at all Vs the more expensive planes.
If you are near a Woodcraft store, I would recommend that you call in and ask for an in-store demo/trial, maybe Vs a L-N or Veritas, I am sure that you will be surprised at the quality of the lower cost version.
posted 51 days ago
This is one made by Anant in India. I beleive these are less expensive than the woodcraft offerings.
http://www.anant-tools.com/index.html
