| Review by sry | posted 53 days ago | 499 views | 0 times favorited | 8 comments | ![]() |
- Wood River Single Flute Countersinks
- Brand: Wood River | Category: Drill-Driver Accessories
I had always heard that this style produces a very smooth cut, so I decided to pick some up when I was at Woodcraft. I bought the #6, #8, and #10. It really is amazing how smoothly and effortlessly they cut.
The second picture I uploaded shows just how smooth these things cut (#10 is shown, but the results are typical). On the far left is the Wood River single flute countersink, middle is one from HD (can’t remember the brand), and right is from a Ryobi countersink set. Lower board is poplar, upper is walnut. You can pretty clearly see that the single flute is the best, followed by the Ryobi, with the brand-less one in a distant third.
Gripes- I wish they had a 1/4” hex shank, simply for the incredible ease it offers
- If you try to drill too deep (ie counter sink then bore if you wanted to put a plug over the screw hole) the waste exit hole will drop below the work surface and it will clog
Score: 4 stars due to the clogging issue
5 stars otherwise
-- Steve -- University Heights, Ohio
8 comments so far
home | projects | blog
25800 posts in 1295 days
posted 53 days ago
It looks like the hole does not go all the way to the point. Is it hard to use in hard wood. How about in a portable drill or a drill press. Any difference?
sry
137 posts in 502 days
posted 53 days ago
That’s a really good point Karson. Since the cutting edge does not go all the way to the tip you need to make sure that you drill the pilot hole first. If you don’t drill the hole first it won’t work (might be able to force it on the drill press, but why would you want to?). If there is a pilot hole it cut like a hot knife through butter with both the drill press and a cordless drill.
2379 posts in 235 days
posted 53 days ago
thanks for the review ,
i always wondered about these ,
the star-point ones chatter ,
and leave a hex hole !
treeman
149 posts in 344 days
posted 53 days ago
I just got a similar set from Lee Valley and I agree with Steve. These are by far the best countersinks I have ever used.
Rev_John
17 posts in 783 days
posted 53 days ago
Wow, I wondered about these myself. It seems like there is now something else added to my shop list. (I’m sure my wife will thank you.) Thanks for the review.
-- John from Jackson, Michigan
Greg Wurst
716 posts in 727 days
posted 53 days ago
It is a much better countersink. Certainly the best I’ve used. The HF star-shaped ones are terrible!
Dusty56
3462 posts in 582 days
posted 52 days ago
Isn’t it strange that the more cutting edges there are , the worse the hole is.?
I also wasted too much money on the “star” shaped multi-cutter countersinks in the past.
I’ve had great results with my Insty-Bit combination (drill and countersink) bits , and they’re 1/4” hex drive as well : )
Greg
218 posts in 203 days
posted 52 days ago
I bought a set of these about a month ago after reading several positive reviews. I completely agree that they are the best countersinks I have used. I threw my old star type countersinks away after the first use of the new ones.
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
