An Inexpensive and Space Efficient Combination Jointer/Planer
Review by Thomas Keefe posted 55 days ago 1120 views 3 times favorited 20 comments Add to Favorites Watch
An Inexpensive and Space Efficient Combination Jointer/Planer An Inexpensive and Space Efficient Combination Jointer/Planer An Inexpensive and Space Efficient Combination Jointer/Planer Click the pictures to enlarge them
About a year ago, I took my first woodworking class (at the age of 51!). It was the first time I had actually used a jointer or a planer. Up to this point I had always purchased S2S lumber and been limited by whatever HD had to offer. After using both of these in class, I decided I needed to be able to do this at home. However, I have a very small workshop (10’ x 10’) and a limited budget. There was no way that they would both fit and no way my wife would let me buy them. So a benchtop jointer/planer combo seemed ideal. I purchased this from Woodcraft for ~$300 a year ago and am very pleased with it.
It has several limitations:
1) It has a short table (about 30” from end to end) which limits the size of the stock that can be jointed. However, with a 10’ x 10’ work area this kind of limitation is not new.
2) It is a combination machine so when going from jointing to planing the machine needs to be reconfigured. This requires that the dust shroud be moved from under the cutter head assembly to over it. Most of the time comes from cranking the planer bed all the way down and then most of the way up.
3) The blades (2) are somewhat thin (~1/16”) reducing the number of times they can be resharpened. I have only had the blades sharpened once. They seem OK but I am not sure I can do it again.
I am happy with the machine. It has been reliable and I think it does a nice job. I have used it mostly on white oak (some quarter sawn) and have been happy with the results. It doesn’t take up much space, but it is heavy and has a sturdy feel.
I have a few quality problems with the machine.
a) There is an extension outfeed table for the planar. This has adjustment so that the output table can be aligned with the planar bed to reduce snipe. However, the adjustment method provided did not work properly. Because of this, I had to shim the table to get it aligned.
b) At some point, checked and found that the infeed and outfeed table were not coplanar. It was off perhaps .01 over a range of 2’. I suspect the impact it had was pretty minor. I decided I had to do something about it. I called JET and was connected with a very knowledgeable technician immediately. He understood the problem immediately and sent me an email with instructions for fixing the problem. I applied the fix and haven’t any further issues.
I have attached some pictures from a brochure on JET’s website that shows various views of the machine along with an shot of the drive mechanism.
Again, I like this machine. It is reliable, does a good job, doesn’t cost much and doesn’t take up much space.
Tom
View Thomas Keefe's profile (online now)
Thomas Keefe
64 posts in 304 days
20 comments so far
View matt garcia's profile
matt garcia
721 posts in 568 days
posted 55 days ago
We are a Jet dealer at my job, and I always wondered how well these little machines worked! Great review!
-- Matt, Houston Texas
View Dusty56's profile (online now)
Dusty56
3468 posts in 584 days
posted 55 days ago
Nice review : )
View Mikeyf56's profile
Mikeyf56
103 posts in 117 days
posted 55 days ago
Great review Tom, thank you.
-- Powered by Smith & Wilson~~~
View dbhost's profile
dbhost
620 posts in 128 days
posted 55 days ago
Not the exact model I keep drooling over, but I totally understand wanting a combination machine… I have been drooling over the JJP-12… It is good to hear an actual owners perspective instead of the magazines….
-- Trying to follow the example of the master.
25802 posts in 1296 days
posted 55 days ago
Thanks for the review. It’s nice that they make tools like these for people like you that get a multipurpose tool.
View kkickback's profile
kkickback
234 posts in 112 days
posted 55 days ago
I too was thinking about buying this machine and talked to a Jet rep and he said Do not by this machine they were having a ton of issues with the beds being coplanner and there was no adjustment for this machine I guess they got that figured out… Glad it worked out for you…
-- christoper Blanchard, Michigan
Todd A. Clippinger
5648 posts in 995 days
posted 55 days ago
That is cool. I have never seen that one before.
I imagine that it would be perfectly suited to a shop the size of yours.
16862 posts in 473 days
posted 55 days ago
neat
View AaronK's profile
AaronK
409 posts in 360 days
posted 54 days ago
thanks for the review – this looks like it might work pretty well for me further on down the road.
how have the size constraints of this little bugger gone for you? that is, the 8” for jointing is good, but the tables are short, and 8” is kind of narrow for a planer. what say you?
Thomas Keefe
posted 54 days ago
AaronK: There have been a few times when a wider planer would have been helpful. Often after I glue up some boards side to side, even with cauls, the result may be cupped or not perfectly aligned. With a wide planer it might be possible to run it through and solve the problem. I generally resort to hand tools (e.g., hand plane, scraper, sand paper). So, I try to be really careful when I do this kind of glue up.
There is a 10” version of this product as well. It cost a bit more and takes up a bit more space. But, it might be helpful at times.
Tom
View j_olsen_oh's profile
j_olsen_oh
32 posts in 67 days
posted 54 days ago
Thnaks for the review—I have the 10” being delivered on monday and hope that I have as much luck with it as you seem to have had
Jeff
-- Jeff - Dayton, OH
Beginningwoodworker
4187 posts in 569 days
posted 54 days ago
Thanks for the preview!
-- CJIII Future cabinetmaker
View new2wood's profile
new2wood
8 posts in 107 days
posted 54 days ago
I too have the 8” version after having debated over the 10”. I tested mine out on some purpleheart and it worked great. I too thought it was limiting to have a narrow planer, but I’ll be working with boards less than 8”, so it really doesn’t matter. Infeed/outfeed could be longer, but is suiting my purpose so far. All in all, I’m more than happy with my purchase since I get unsurfaced white oak and ash for free.
View kosta's profile
kosta
372 posts in 250 days
posted 46 days ago
having a small 8 in jointer is good but a 8in planner is to small for me
-- kosta brownsville brooklyn my home
View dustyal's profile
dustyal
447 posts in 371 days
posted 26 days ago
thanks for the review. I was thinking about the 10” model. I have a 12 inch planer (Delta tp-305) with only the bare essentials. Haven’t used it yet. I was thinking the 10” Jet jointer would match up will with the Delta and I would also have the Jet 10” planer. Point being, I’ve looked at 6” jointers and eveyone tells me to go bigger— like 8 inch. But those machines are 220V so I need to run electrical…. this Jet is still 110v at 10”.
But then, everyone tells me to go with long infeed tables which this jet doesn’t have… HELP… I think I am going in circles over this stuff…
-- Al H. - small shop, small projects...
new2wood
8 posts in 107 days
posted 26 days ago
http://www.youtube.com/watch?v=VPFfmGO2dxs
http://www.youtube.com/watch?v=FdPT4Qdg8mo
Here is a two part video that is on youtube. It features the 10” Jet jointer/planer. Like I stated earlier, I have the 8” and it is working great. It was easy to set up and use out of the box. I had very little snipe. Yes, the planer is only as wide as the jointer, but it works great. The switch over between the two tools takes a few minutes, but is very simple. Plus, I have to share my “shop” with two vehicles, so you can’t be the capabilities of an 8” jointer in a compact tool. In the video, the infeed and outfeed isn’t any bigger in the 10” compared to the 8”.
Overall, I’m more than happy to be able to surface my own lumber in my garage with this tool. Most of my tools are portable or bench top models. As my space grows, so will my stationary tool collection (the 12” Jet jointer/planer makes me drool).
View just_adam's profile
just_adam
9 posts in 37 days
posted 24 days ago
Man I’d buy anything Charles Neil tells me to :)
Wasn’t that the guy who did the video about a dovetail saw jig you make yourself from a chop saw…”Smart Tails” he called them?
Might have to get me one of these…
-- Oakland, CA
View Fish22's profile
Fish22
5 posts in 9 days
posted 8 days ago
Thanks for a great review. I was looking at this today and I thought it would be a good purchase for my shop. It is on the small side like yours. With the free shipping offer from Jet, really can’t beat the price.
-- Fish 22, South River, NJ
View David Craig's profile (online now)
David Craig
39 posts in 4 days
posted 2 days ago
Good review Tom, thank you for sharing. I recently bought this model. There is a way to make both the outfeed and infeed tables coplanar. There are two bolts that can be removed to form a pivot point for adjusting the outfeed side. Jet does not include these in the initial instructions but will email a diagram to you if you contact them. I had a bear of a time with chatter when I first bought the model and I attempted to readjust the knives probably a hundred times until the coplanar issue was explained to me. I agree with you on the knives and have had some success using Freud 8” blades instead of the Jet blades. Jet only recommends their own brand though. I did experience some issues with blade movement on mine. I think it is because of the stand I had it on and the fact it was sitting on a cement floor. The vibration can be pretty heavy and I think that is the culprit behind some of the bolts loosening. I did get some smooth cuts with it and I can’t complain about the end result of the boards.
Thomas Keefe
posted 23 hours ago
Hi David. I also got the information on adjusting the outfeed table and have not had any problems since.
Can you tell me more about which Freud blades you used and how they worked for you? Thanks.
Tom
