Great TS Upgrade For A Very Reasonable Price
Review by dfarr posted 61 days ago 668 views 1 time favorited 9 comments Add to Favorites Watch
Great TS Upgrade For A Very Reasonable Price Great TS Upgrade For A Very Reasonable Price Great TS Upgrade For A Very Reasonable Price Click the pictures to enlarge them
I’ve always struggled with the cheap blade adjustment cranks (pictured right) on my 70s vintage table saw. I found these cast iron handwheels (H3189 – Cast Iron Handwheel – 6”) and chromed handles (H3205 – 4” x 3/8”-16) on the Grizzly web site. The handwheels were only $8.50 and the handles were $2.95. This was a great deal compared to other places I’ve looked at similar handwheels. The wheels come with a small center hole that I had to bore out to 3/8” and I also had to drill and tap a 1/4-20 hole for a setscrew. TheYl came drilled and threaded to accept the 3/8”-16 threaded end on the handle. I replaced both my blade height adjustment and the angle adjustment. These handwheels make the adjustments extremely easy compared to the stock handles. I’m thinking I might upgrade the adjustment on my joiner to the same type handwheel. Grizzly’s delivery was very fast and I am extremely pleased with the price and the quality of these. I wish I would have thought to do this 20 years ago!
View dfarr's profile
dfarr
12 posts in 332 days
9 comments so far
View 559dustdesigns's profile
559dustdesigns
21 posts in 68 days
posted 61 days ago
That’s a very helpful post. Plastic or flimsy metal cranks shouldn’t be used on any machine. This upgrade would be worth every penny.
-- The difference between the impossible and the possible lies in a man's determination. - Tommy Lasorda
View skeeter's profile
skeeter
78 posts in 241 days
posted 60 days ago
you have my table saw. I bought it for 75 bucks and put a unifence on it and a phenolic plywood aux table.
-- My philosophy: Somewhere between Norm and Roy
View dbhost's profile
dbhost
627 posts in 132 days
posted 59 days ago
That’s a whopper of a handwheel! Looks really good though… Any interference issues due to the wheel size?
-- Trying to follow the example of the master.
View woodworm's profile
woodworm
8308 posts in 490 days
posted 59 days ago
My Ryobi benchtop Table Saw has height adjustment and tilt adjustment handwheels made of plastic. The handwheel was useless out of box. I’ve been searching for this type of handwheel for so long time
Thanks for this review. I really gives me hope for a new lease of my table saw’s life!
I wanted to buy 2 handwheel like yours, but I may have problem tapping the setscrew hole. I would be very gratefull if you can explain further “how to” drill & tap the setscrew hole.
Thanks!
-- masrol, kuala lumpur, MY.
woodworm
posted 59 days ago
The size of the shaft arbor (ie centre bore size of the handwheel is 3/8”)
Since my table saw is almost the same like your Craftsman TS, it may accept 4” to 6” handwheel.
25871 posts in 1300 days
posted 59 days ago
Great modification. Nice job.
Looks like you have caused a bunch of other people to jump into the upgrade waters.
dbhost
posted 58 days ago
woodworm,
Your handwheel looks like it came from a BT3100. A lot of users are filling the voids in them with epoxy and BBs to give the handwheel the needed strength, and heft. You might want to try that. I haven’t gone that route yet, but am SERIOUSLY considering it… Remember the shaft on these saws has 2 flat sides…
dfarr
posted 58 days ago
dbhost….The 6” wheel works great and no interference. The larger the diameter the greater the mechanical advantage and ease to turn for adjusments.
Woodworm…..Drilling and tapping the setscrew hole is quite simple if you have a drill press but it is possible to use a hand drill if you have a vise and a steady hand. The wheel’s odd shape makes it a bit tricky to secure in a vise in the proper position. I used a centering v-block clamped to by drill press table. Use a prick punch to mark the point where you want to drill to keep the bit from “walking” and to make it easier to get the drill bit started in the right spot. Drill the hole about mid-way on the hub portion of the handwheel inline and 90 degrees to the hubs center hole. For a 1/4-20 setscrew you need to drill a 7/32 hole. I actually used a 1/4-20 bolt rather than a setscrew. You can see the head of the bolt in the pictures. Tapping is easiest if you have a tap t-handle but you can get by using a wrench that fits the square shank on the tap. Some form of lubrication should be used and it’s best to keep backing the tap up every rotation or two to clean the threads and let the lubricant penetrate ahead of the tap. They make special tapping fluids but WD-40 or any light oil will work fine if you are only tapping a few holes.
Here’s a link with details about the metal tapping process:
http://en.wikipedia.org/wiki/Tap_and_die
woodworm
posted 55 days ago
dbhost,
thanks for the alternative solution. I think I should give it a try first before replacing it with cast-iron handwheel.
dfarr,
I appreciate your reply to my question about drilling & tapping the thread of setscrew hole. Thank you for your time and effort searching and attaching the link to the tapping process.
You all are very helpful and nice people!
