| Review by thiel | posted 55 days ago | 567 views | 0 times favorited | 14 comments | ![]() |
- Lee Valley Glue Spreaders
- Brand: Lee Valley | Category: Gluing and Finishing Supplies
I hate the idea of tossing out acid brushes after a few uses (they’re steel!) and I’ve been looking for alternatives (for the record, there aren’t any :-) so I bought these little dealios.
Long story short, they are TERRIBLE for spreading glue. They act more like a squeegee—pulling glue away from your intended target. Which brings us to what they ARE good for, and that’s scraping glue off once its skinned over.
These things are a nice plastic, they are glue resistant, and they have a nice sharp edge. PERFECT for scraping off skinned over glue. They are also easily cut/shaped to odd shapes (like molding profiles) and that comes in handy too. I find them especially useful for scraping inside of spots that are too tight for anything else—they are too soft to hurt the wood.
So… don’t buy em to spread glue. Buy em to remove glue instead! They are about $3 for a whole pack.
-- Laziness - Apathy = Efficiency
14 comments so far
home | projects | blog
16577 posts in 469 days
posted 55 days ago
I like either acid brushes or my index finger. Thanks for the review.
20538 posts in 714 days
posted 55 days ago
Thanks for the review. Usually I have found Lee Valley products to be excellent quality so I appreciate the heads up on this one. However, like Jim I generally just use my index finger to spread glue and use acid brushes for hard to reach areas.
PurpLev
2732 posts in 540 days
posted 55 days ago
I use an old retired kitchen spatula – looks similar to the item you’re reviewing – but much bigger. what I did was notch small cuts in the spatula which lets the glue “escape” as you spread it as opposed to being removed. works pretty well – might also make these useful for their purpose. just my $0.02
Chris
300 posts in 249 days
posted 55 days ago
I picked up a set of three that look very similar sometime 5-10 years ago, although I don’t think I got them from Lee Valley. The ones I use are pretty flexible and I actually like and use them often for gluing edges (they’re only about 3/8 wide). The ones I have are not really stiff enough to scrape up glue with. I have a cheap plastic putty knife that does that great.
Of course, I do use my finger half the time anyway.
-- Chris
CanadaJeff
165 posts in 501 days
posted 55 days ago
I like the acid brushes a lot, I don’t understand why your throwing them away after a few uses. After you done gluing, rinse them in a little warm water and soap and dry them out. I have acid brushes from 2 years ago still in use.
OttawaP
53 posts in 618 days
posted 55 days ago
Gotta disagree 100% on this one. A steady hand and these babies are awesome aslo faster than acid brushes in my opinion. Best thing is when the glue dries it peels right off them, even epoxy does not stick.
Gunked up acid brushes are a p.i.t.a., I’d rather use my finger.
-- Paul
Demowen
113 posts in 289 days
posted 55 days ago
I’ve got a few very small scraps of some hide leather that works great to spread glue. Once the glue dries up it just cracks and peels right off!
I know that Marc Spagnolo takes a regular pint container with a hole cut in the top. He puts a little water in the bottom and its good to go till your next glue up.
-- Let the favor of the Lord our God be on us; establish the work of our hands- establish the work of our hands! Psalm 90:17
dustyal
442 posts in 367 days
posted 55 days ago
I cut the bristles a little shorter on my Harbor Freight cheap brushes… makes them a little stiffer to spread glue… Then, I like to use my wife’s credit card to peel off semi-dry glue squeeze out.
I saw these things, or something similar… didn’t think they’d spread as well as brush. Thanks for posting.
-- Al H. - small shop, small projects...
choppertoo
62 posts in 205 days
posted 54 days ago
I’ve got to agree with OttowaP. I like mine especially for spreading in a groove. They fit 1/2 out of the bag but are wasily cut down to 3/8 or 1/4. I don’t mind acid brushes but forget to rinse them & they’re shot.
-- The greatest danger for most of us is not that our aim is too high and we miss it, but that our aim is too low and we reach it.. Michelangelo
JayPique
33 posts in 180 days
posted 54 days ago
I’m partial to a brayer, like David Marks uses. You put down your bead of glue, and then roll it out smooth with the brayer. For bigger glue ups I’ll put glue in a paint tray and use an appropriately sized paint roller.
Most often, though, I just use my finger.
JP
choppertoo
posted 54 days ago
I’ve got to agree with OttowaP. I like mine especially for spreading in a groove. They fit 1/2 out of the bag but are easily cut down to 3/8 or 1/4. I don’t mind acid brushes but forget to rinse them & they’re shot.
ladywoodrat
3 posts in 71 days
posted 54 days ago
I like these little plastic spreaders for wood filler. They work great and like glue the filler comes off pretty easy if it drys on them.
-- LadyWoodrat
jsheaney
58 posts in 880 days
posted 54 days ago
I always seem to have plenty of really skinny cutoffs sitting around, so generally just use little bits of wood to spread glue (if not my finger). I’ll generally sharpen the end a bit on a sanding block. When I’m done I snip the end off with wire cutters.
-- Disappointment is an empty box full of expectation.
AaronK
409 posts in 356 days
posted 53 days ago
good idea jsheaney – i’m a bit tired of getting my fingers all gunky. plus, you can carve any pattern youd like… thanks!
