| Review by Bothus | posted 62 days ago | 510 views | 0 times favorited | 5 comments | ![]() |
- Empire Top Saver
- Brand: Empire | Category: Tablesaw Accessories
This is an excerpt from my blog posting about restoring my Unisaw. I thought it worked as a review.
You can read the original/view the original post HERE.
I would have given the product 5 stars except that while it worked much better than I expected in reality it is only as good as the amount of elbow grease you use with it.
Enjoy!
Where da hail did you get those glasses? You look like yo Aint Bea in Shreveport.
Scrubbing away.
Top Saver first pass
Top Saver 3
Honey!
Top Saver summary
-- Professional kitchen designer, amature woodworker.
5 comments so far
mtnwild
home | projects | blog
2026 posts in 425 days
posted 62 days ago
I’m right with you on this product. I use it on rusty knives and my table surfaces. Will not stain handle material on the knives and does not build up. Good stuff!!!!!!!!!!!!
NBeener
386 posts in 72 days
posted 62 days ago
Your stuff just cracks me up!
Now … I know ab-so-lute-ly nothing about this, but …. can you (anybody) just use [whatever grade of] steel wool OR a Scotchbrite pad, and … WD-40??
In other words, is this product /really/ any better than what my gut would tell me I should consider using?
Maybe you can try an experiment on your Craftsman, using Top Saver on half the top and WD-40 on the other half??
Just curious.
Also, a few cut-up carrots (or other veggies) would have made a HUGE difference in your soup ;-)
-- -- Neil
CessnaPilotBarry
1288 posts in 601 days
posted 62 days ago
I like TS, too! It’s my favorite, with wax in-between TS annual treatments.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
Bothus
239 posts in 74 days
posted 62 days ago
Thanks to all for confirming my findings. I will wax it too.
NBeener:
CARROTS???! That’s what was missing. No wonder the little woman didn’t have seconds.
I’ll think about experimenting with the Craftsman top as you suggested.
J
blockhead
305 posts in 206 days
posted 57 days ago
I’ve also used the Top Saver and love it! TIP: I sprayed the surface with TS and put a 60 grit pad on my orbital sander and used that on a large piece of Scotchbrite pad to clean the surface and it worked great. It took all of the yuck off the table top. Note: DO NOT use the hooked pad of the sander directly on the Scothbrite pad. I did that once and it broke off all of the hooks on the sander pad and it wouldn’t hold sanding discs after that and had to replace the disc. I should’ve known better, hindsight is 20/20.
Great review Bothus!
-- Brad, Oregon- Wood, it's what's for dinner.
