| Review by Jim | posted 60 days ago | 969 views | 0 times favorited | 9 comments | ![]() |
- Grizzly G0490 8" Jointer Mod with Byrd Shelix cutterhead
- Brand: Grizzly | Category: Jointers
I’ve had my Grizzly 8” G0490 jointer for about 5 years. I’ve been very happy with this jointer. I wouldn’t hesitate to buy this same jointer again.
About 2 yrs ago I decided to modify it by replacing the cutterhead with a Shelix head. I was working with some highly figured koa and wanted to maximize the utilization of this expensive wood as much as possible by not losing any to tearout.
Many people want to know if the helical heads are worth the money. Short answer—maybe.
First, I received the head from Grizzly and had to replace my existing knife blade head. This was not an easy task. Not terrible, but not real easy either. Instructions were non-existent but I managed to get it installed and the adjustments to the machine were minor. Think twice about doing this yourself however. There’s a lot of potential for headaches (and smashed fingers).
Now for the results. The helical head definitely reduces tearout. It does however, leave some lines that knives don’t. The lines are faint and sand out easily. If you joint a lot of figured woods you’ll be very happy with this cutterhead. The current price is about $350. Not sure I’d pay that again but I could see paying $300 extra to get a new machine with the head already installed. But only IF you need to joint woods that are subject to tearout.
-- Jim, www.greenteawoodworking.com
9 comments so far
JayPique
home | projects | blog
33 posts in 183 days
posted 60 days ago
Thanks for the review. I’ve been thinking about carbide teeth for my jointer and planer for a while. Maybe you cold post back after some time and let us know about the longevity of the knives – how long they stay sharp. I’ve used one and was very, very pleased with the results. It’s much quieter, and I found I could pretty much just ROS it with 150grit and be done.
JP
20665 posts in 716 days
posted 60 days ago
Thanks for the review, Jim. I have been considering doing this but the price tag for a cutterhead from Powermatic was $900. So I was a little reluctant to put that kind of money into a replacement cutterhead. But the cost of the Shelix cutterhead in more in my price range. I will have to consider doing it but, at the same time, I do not work with a lot of highly figured woods.
socalwood
968 posts in 499 days
posted 60 days ago
I’ve been reading mixed reviews on these as replacement for original equipment. Again cost is a big factor , 3500$ for one of my planers . Haven’t decided whether it is worth it or not. My jointers use the Tersa knife system that I am very pleased with , and would not change . Thanks for the review .
Todd A. Clippinger
5643 posts in 994 days
posted 60 days ago
I have an 8” Grizzly jointer with the spiral head cutter and I have incredible results with it in figured wood.
I purchased my jointer with the spiral cutter head and so it has the Grizzly cutter head in it.
I think that you are right, in saying that it would be better to buy a unit with the head already installed. Tearing a heavy machine apart is akin to doing mechanic work on a motor and I am not really into that. My time is too valuable in other ways.
I get the lines also but they have been a non-issue.
The carbide knives stay sharp for a long, long, long time. When it is time to change them you just loosen the set screw and turn them to use the next edge and tighten into place. There is not setting of knives they are fixed. That is worth a lot.
The two key machines that have allowed me to work highly figured wood are the spiral head jointer and the drum sander for machining to thickness without tearout.
socalwood
posted 60 days ago
Thanks Todd
khop
94 posts in 571 days
posted 60 days ago
Jim, Sorry about your disapointment with the cutter head. I have the Grizzly G0586 Jointer with the H7654 spiral cutter head and I am very happy with it. I bought the cutter head later and installed it myself. It came with the mounts and pulley already on the unit. After the installation, I tweeked the outfeed table and added the existing metal shim to the pulley side and it is right on the money. It cuts sooo much better than the old beater bar method. Hope things work out for you.
KHOP
-- How am I doing? Better than I deserve.
mmh
1385 posts in 617 days
posted 60 days ago
I’ve been eyeing this type of cutterhead and surprised and a bit disappointed in your review as it was an intriguing tool I was highly considering when I purchase a new jointer. I wonder if the cutterhead you have is a newer model, maybe manufactured in a different country than the one that others who like this cutter head have?
Thanks for the review. I’ll still consider this option, but with more knowledge.
reggiek
712 posts in 165 days
posted 60 days ago
I purchased the Grizzly planer without the spiral…for cost reasons…and it was cheaper to upgrade later on…cheaper but complicated…..I haven’t had to upgrade though as the beater bars are doing just fine without much tear out or snipe (and I have run alot of highly figured cocobolo…and some of the rosewood I got from Bibb). I put in the upgraded carbide knives though. For now I will live with the knives…I have the spiral here to put on it (got it on sale and with free shipping)....but haven’t had the time or need to change it out… On the 20” planer the difference in price is $1,000.00 dollars….you can get the spiral head on sale for $600.00 with free shipping….(either a shellix or the grizzly)...I got the shellix as I got free shipping with it…Change out is not for the faint hearted though….you must remove almost the entire upper part of the machine (gears, pulleys…belts…)...I believe it is similar with the jointer…I don’t have a problem with that…and there are instructions included with the upgrade cutter.
kosta
371 posts in 249 days
posted 59 days ago
I have heard from a lot of people that these cutter heads are the best
-- kosta brownsville brooklyn my home
