| Review by Sawdust2 | posted 65 days ago | 714 views | 1 time favorited | 9 comments | ![]() |
- Fein Multimaster
- Brand: Fein | Category: Other
The task was to lower a bar stool 2 1/4”.
And not have the usual problem with not level legs when we got done.
We also had a Fein Multimaster and the new Porter Cable SoniCrafter
To ensure the same length was cut off each leg we cut a piece of PVC to 2 1/4”.The Fein and the PC each had a couple of blades that could be used but we took the round serrated blades as they were the same thickness.
We just ran the blades around the leg resting them on the PVC. That gave us a uniform height from the bench.
Fortunately we could not cut all the way through the leg at that point.
We could not cut all the way thru with the Fein because the housing stopped at the leg. We could not cut all the way thru with the PC because the dust collector butted up against the leg. Draw.
The weight is virtually the same. Draw.
The Fein is louder because the motor is slightly more powerful. Both appeared to vibrate about the same in our hands.
Both cut with equal ease. Draw
Fein’s power cord is 2x long as the PC power cord.
PC is about half the price of the Fein.
We decided that price had to be the deciding factor. If you are a professional you should get the Fein. If you are a hobbyest the PC will give you almost (95%) the same machine for half the price.
Neither machine is a one tool wonder. We are amazed at the different projects we have been able to use them on.
Why was it fortunate that neither machine could cut all the way through the leg? It allowed us to cut all the legs to the same height from the same reference point. We then turned them upside down and cut the nubs off with my duzuki saw. Which just fit in the kerf from the two saws.
9 comments so far
Mark Shymanski
home | projects | blog
1555 posts in 610 days
posted 65 days ago
Thanks for the comparison. These intrigue me, I just haven’t figured out how to start a project big enough to justify buying one but small enough to not get in the way of other projects :-)
Thanks for the review.
25806 posts in 1298 days
posted 65 days ago
lee a great review. I’ve got he Fein I also have the Bosch Fine Cut. The Fine Cut might not even be sold anymore, but it would have cut off the legs.
A Popular Mechanice review
Douglas Bordner
3427 posts in 961 days
posted 64 days ago
I finagled the Fein from the family budget when I had to remove petrified caulking from 10 old windows. Pam and I have used it for everything from removing peeling paint from exterior trim, to cutting a small tree out of the chainlink fence (I used the longer straight e-cut blades) and plunge angle cutting the bottom part of a rotting door casement in situ. It is one sweet tool, and I love that long cord.
Now I see Crapsman, er ah, Craftsman has a cordless version. I think I will be able to resist that siren’s song.
Chris Wright
360 posts in 379 days
posted 64 days ago
Wow, thanks for that. It’s nice to see the comparison of the two saws.
-- "At its best, life is completely unpredictable." - Christopher Walken
17020 posts in 475 days
posted 64 days ago
good review Lee
-- Jim from Heirloom Woodshop, custom furniture, woodworking school, heirloomwoodshop.com
jake
36 posts in 601 days
posted 64 days ago
Thanks, I have been looking at couple different versions and didnt know PC had one out. I am a little confused as the picture seems to show a Rockwell that I thought was made by the Positec group and not Porter Cable. Thanks though, I will look at a Sonicrafter and pocket the money for another tool purchase.
khop
97 posts in 574 days
posted 64 days ago
Dont’t forget the dremel Multitool. I got one on sale for $89. It came with some extras. I have used it many times and it works just as well as the others.
Thanks
KHOP
-- How am I doing? Better than I deserve.
Sawdust2
1186 posts in 985 days
posted 64 days ago
It is a Rockwell, not a PC.
Doesn’t change the review.
Russ Anderson
28 posts in 226 days
posted 30 days ago
Harbor Freight also sells one. I could get over the up front cost of the better Fein but I can’t get over the continued high pricing on the accessories that will need to be replaced. How many people own the Lamelo biscuit jointer compared to the PC and DeWalt models? I would guess not many because in the end they all get you to the same place. I’m with Khop, I would get the Dremel over the HF version because I have to drive 30 minutes to get to the nearest HF for accessories. I have a Lowe’s one mile away that sells the Dremel.
-- Russ
