Irwin Max Speed Speed Bore bit
Review by Mainiac Matt posted 01-31-2017 03:33 AM 2196 views 1 time favorited 13 comments Add to Favorites Watch
Irwin Max Speed Speed Bore bit Irwin Max Speed Speed Bore bit No-picture-s Click the pictures to enlarge them
I borrowed one of these from a carpenter in our crate shop at work and was really impressed with how fast and clean it cut. So when I saw them at Ace Hardware I picked up a 3/4” one.
Tonight I broke it out to drill some add’l holes in my bench. I like it a lot. It ate up the hard Maple like it was pine.
Pros:
1. Pilot grabs hold and pulls the bit right through the wood.
2. The three cutting edges really cut fast. They are very sharp.
3. Both the entry and the exit holes are clean.
4. The 1/4” hex drive shank won’t slip in your drill chuck.
Cons:
1. They are a little expensive
-- I yam what I yam and that's all what I yam
View Mainiac Matt 's profile
Mainiac Matt
8607 posts in 2562 days
13 comments so far
View Monte Pittman's profile
Monte Pittman
30126 posts in 2571 days
#1 posted 01-31-2017 03:37 AM
A little expensive isn’t a big issue if the tool is good and will last.
View Woodwrecker's profile
Woodwrecker
4211 posts in 3809 days
#2 posted 01-31-2017 05:44 AM
Thanks for the tip Matt.
View papadan's profile
papadan
3584 posts in 3602 days
#3 posted 01-31-2017 05:53 AM
I got a 3/4” a few years ago when Irwin had a free sample offer. They are very nice bits.
View Redoak49's profile
Redoak49
3731 posts in 2222 days
#4 posted 01-31-2017 12:19 PM
I used the 3/4” to drill the holes in my bench and worked very well. I also drilled a 2” thick block on my drill press to use as a guide to keep holes perpendicular.
Mainiac Matt
#5 posted 01-31-2017 02:40 PM
I chucked the bit in my 8 amp Dewalt spade handle drill…. which is quite the beast, and this bit pulls itself in very “assertively”. I really had to brace myself and hang on for the ride.
View waho6o9's profile
waho6o9
8539 posts in 2810 days
#6 posted 01-31-2017 11:33 PM
Good to know thank you.
View pottz's profile (online now)
pottz
3805 posts in 1218 days
#7 posted 02-02-2017 08:48 PM
i sell these bits and have also used them and the are as good as matt stated,i highly recommend.
View devann's profile
devann
2246 posts in 2926 days
#8 posted 02-03-2017 02:31 AM
Yes they are nice bits Matt. I’ve purchased them on a couple occasions, needed more holes drilled at the same time. When I’ve purchased them I was able to buy a package of three.
5/8’, 3/4”, 7/8”.
View jimintx's profile (online now)
jimintx
864 posts in 1818 days
#9 posted 02-03-2017 06:15 AM
I got a set of three from my local Lowes store a year or so back. They also offer a set of 6 in a plastic box that I wish I had gotten. They average about $5 per bit, with set of three for 15 bucks and six for 30.
I agree with all the positive comments. I have mainly used them in my drill press, and they do cut well.
-- Jim, Houston, TX
View Woodknack's profile
Woodknack
12455 posts in 2613 days
#10 posted 02-05-2017 01:12 AM
I have no complaints about Irwin bits
View oldnovice's profile
oldnovice
7378 posts in 3601 days
#11 posted 02-05-2017 09:01 PM
+1 Ricky M.
View metolius's profile
metolius
75 posts in 964 days
#12 posted 02-08-2017 07:14 PM
I bought the set of 6 ( 1/2 → 1-1/4 ) a couple years ago.
I was using the 5/8 on the press last weekend while thinking about how impressive they are.
View Roger's profile
Roger
20965 posts in 3037 days
#13 posted 02-18-2017 06:07 PM
I know. I’ve used one of these before and it’ll pull through anything.
